1 Reply Latest reply on Mar 13, 2014 12:34 AM by vinomannu
    Need help?
    vinomannu
      Hi All,
      Using script listiner coding i have used the contac sheet plugin for some automate task, but every time i need to tigger the "OK" button on the contact sheet, can i skip this process,
      I want the script to be excute in one shot.
      #target photoshop
      var idzeroBsevenoneDtwotwooneFeightCEoneonedtwoBtwooneBzerozerozeroeightCsevenfiveBthreetwotw oC = stringIDToTypeID( "0B71D221-F8CE-11d2-B21B-0008C75B322C" );
          var desc14 = new ActionDescriptor();
          var idCSIISettings = stringIDToTypeID( "CSIISettings" );
          desc14.putString( idCSIISettings, """<ContactSheetIISettings>
        <source imageSource="Folder" path="D:\\test\\in" includeSubfolders="true" groupImages="false"/>
        <document units="inches" width="8" height="10" resolution="118.11" resUnits="pixels/inch" mode="RGB Color" bitDepth="8-bit" colorProfile="sRGB IEC61966-2.1" flattenLayers="true"/>
        <thumbnail place="across first" cols="1" rows="2" bestFit="false" useAutospacing="true" horz="0.014 in" vert="0.014 in"/>
        <caption enabled="true">
          <font name="ArialMT" size="12"/>
        </caption>
      </ContactSheetIISettings>""" );
          var idMsge = charIDToTypeID( "Msge" );
          desc14.putString( idMsge, """Settings for Contact Sheet II""" );
      executeAction( idzeroBsevenoneDtwotwooneFeightCEoneonedtwoBtwooneBzerozerozeroeightCsevenfiveBthreetwotw oC, desc14, DialogModes.NO );
      Regards,
      Vinoth
