1 Reply Latest reply on Mar 4, 2014 9:27 AM by Josh_Corey
    multiple choice fields - side by side.
    Xarc
      is it possible to create a multiple choice field that is side by side?
        • 1. Re: multiple choice fields - side by side.
          Josh_Corey Adobe Employee
          I am not sure if you want the choices to be side by side, or to have more than one multiple choice field in a row - you can do either.
          To change the orientation of the choices check or uncheck the box in the Properties panel for "Stack choices vertically", you can also change the position of the fields label in the Properties panel.
          You can also create another Multiple choice field adjacent an existing by clicking the "+" on the right side of the existing Multiple choice field and choosing Multiple choice from the form field toolbar that appears, you can also add an adjacent field from the context menu of a field, or by using Drag and Drop from another row.
          Josh
