• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How can I get the effect of spinning movement on a photo?
New Here ,
Mar 04, 2014 Mar 04, 2014
I am making a fun music video and am new to Adobe Premiere 11. I have a photo (of a magician) that I'd like to get the Effect of circular spinning movement. I tried "Twirl" in Effects, but no spinning happens. I want the magician's face to appear, and then spin, so I split the frame into 2 segments and tried several Effects on the 2nd segment, especially "Twirl", but no spinning happens. How can I get it to spin in rotation at that point? Help! Thanks.
Views
42.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Select the clip on your timeline and click the Adjust button on the upper right of interface.
In the Applied Effects panel, open Motion effects to reveal the Rotate property.
If you apply keyframed animation to this effect, you'll get the spin you're trying for.
Votes
Translate
Translate
Report
Report
New Here ,
Steve, thanks for your reply. I tried your suggestion but still am not getting the Effect I envision. When I adjust "Rotate", all that happens is the photo tilts, and holds in that position. But I'm hoping for an animated continuous spinning in that keyframe. Am I doing something wrong? I'm having a hard time adjusting the variojus settings in  "Twirl" effect..
Votes
Translate
Translate
Report
Report
LEGEND ,
I'll have to check out PrE 11, but I think that it has the same Rotational capabilities as PrPro has, where you can have the Rotation occur many times, say by plugging in 3x in the attributes area.
Steve probably knows this, without looking, and will beat me to the answer...
Votes
Translate
Translate
Report
Report
New Here ,
Hi Hunt. I'm such a novice, especially compared to you guys. BTW, I don't see an "Attributes Area" when I bring up the various adjustment settings (Motion, Opacity, Twirl) on the Twirl (Distort choice) effect.
Votes
Translate
Translate
Report
Report
LEGEND ,
My Adobe Premiere 11
Were you looking for a spinning globe type effect similar to what I created in this demo for a how to on the subject.
http://youtu.be/NC-DhLx_UU8
Or is what you seek just
For Premiere Elements 11
Hunt's Attributes area = Applied Effects Tab/Applied Effects Palette/Motion Panel and Opacity Panel (as the default panels).
When you expand the Motion Panel there, you will find the properties of Postion, Scale, and Rotation.
ATR
Votes
Translate
Translate
Report
Report
New Here ,
Hello A.T. Thanks. I got an error message when I tried to open your YouTube spinning globe effect, but that would be a great effect for me, if there was a way to see how to do it. I would most like the magician's head appear, and then spin (probably by splitting the frame (photo) with an added key frame and then apply the spinning effect there.
Votes
Translate
Translate
Report
Report
LEGEND ,
Please try the YouTube link again. I have two spinning globe video samples on YouTube, the first is not working today, the other is.  The link that is in this post now is the one that is working. Please let me know if you continue to have problems with the link.
Later today I will apply my video spinning techniques to a face instead of a globe and give you the details.
How long in this video is the face's going to be spinning, and it is in only one instance in the movie?
ATR
Votes
Translate
Translate
Report
Report
New Here ,
I'll try to see your YouTube instructional video again. The spinning face will only last for about one second, or so, and will happen only one time in the music video.
Votes
Translate
Translate
Report
Report
LEGEND ,
I will work on this later today and get you a sample of the results with how to instructions to follow if you like the look of it.
Thanks for the follow ups.
ATR
Add On...Do you have Photoshop Elements 11 as well as Premiere Elements 11?
Votes
Translate
Translate
Report
Report
Guest
Feb 21, 2016 Feb 21, 2016
Hello,
Sorry to revive an old thread. but is there a good tutorial on this somewhere?
The effect I am looking for specifically, is as seen in the attached video as of 0:28.
Votes
Translate
Translate
Report
Report
Community Expert ,
The video does not load. best is to give a link to a youtube example.
Votes
Translate
Translate
Report
Report
Guest
Here is a direct link to the dailymotion video:
GuyP1 - Video Dailymotion
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
That needs some work but you can draw an oval (actually half an oval to make the illusion the oval is under the player) and keyframe the position about every so often frame.
Votes
Translate
Translate
Report
Report
Community Expert ,
Rotating your clip won't make it spin, MyAdobe. You need to create the animation of the spin using keyframes.
Votes
Translate
Translate
Report
Report
New Here ,
Hi Steve. Just don't know how to get that spinning effect, when I would add a keyframe.
Votes
Translate
Translate
Report
Report
Community Expert ,
I've got a free tutorial called Basic Keyframing on my website, Muvipix.com. Once you understand how keyframing works, it should be clear how to apply it to Rotation.
*** Basic Keyframing with Premiere Elements ***
Votes
Translate
Translate
Report
Report
