3 Replies Latest reply on Mar 5, 2014 10:16 AM by D Fosse
    OMG, here we go again - return of the sign-in...
    D Fosse Adobe Community Professional & MVP
      I don't believe this. What I did now was to connect an external drive for back-up purposes. I had the CC app open. Within 15 seconds of connecting the drive I was logged out.
      And then I had to go through the whole routine again with each single application.
      http://forums.adobe.com/thread/1416330?tstart=0
        • 1. Re: OMG, here we go again - return of the sign-in...
          Seems repeatable. Once back up and running, I rebooted a couple of times and launched all apps several times, all OK. Then I reconnected the external. Took about a minute, then I was signed out again.
          So what's the story with this http://helpx.adobe.com/creative-cloud/kb/unable-login-creative-cloud-248.html  ? Has this been around for a while, or is it new?
          I looked at the PDApp.log, but couldn't see the items mentioned. I saved out the entire log and can post it if required. I did find this, and some other similar entries:
          03/04/14 22:36:37:718 | [WARN] |  | ASU | ProvSwitcher | ProvSwitcher |  |  | 4268 | Unable to fetch AppSerialNumber from amtLib xml file. Unable to check for ProductInfo mapping!
          03/04/14 22:36:37:718 | [WARN] |  | ASU | ProvSwitcher | ProvSwitcher |  |  | 4268 | Dynamic XML Not Found
          03/04/14 22:36:37:718 | [ERROR] |  | ASU | ProvSwitcher | ProvSwitcher |  |  | 4268 | Recieved empty serial number, returning false
          03/04/14 22:36:37:718 | [ERROR] |  | ASU | ProvSwitcher | ProvSwitcher |  |  | 4268 | Product not running under subscription
          • 2. Re: OMG, here we go again - return of the sign-in...
            Ah, found it. It was buried deep within:
            03/04/14 22:35:23:194 | [WARN] |  | ASU | OPM | CryptEngine |  |  | 4180 | Failed in error: StreamTransformationFilter: invalid PKCS #7 block padding found
            03/04/14 22:35:23:194 | [WARN] |  | ASU | OPM | OPM |  |  | 4180 | Failed to decrypt in opm_getValueForKey using Key1
            03/04/14 22:35:23:194 | [ERROR] |  | ASU | OPM | OPM |  |  | 4180 | Failed to decrypt in opm_getValueForKey using Key2
            This is the red flag, apparently. I'll try the IMSLib Replacer (linked above) later today, and report back.
            • 3. Re: OMG, here we go again - return of the sign-in...
              Well. I signed out from CC and ran the IMSLib Replacer, which was very quickly done. Signed back in.
              Rebooted, launched several apps and everything's OK.
              Then I reconnect the external. Three minutes later I'm signed out.
              So that didn't work. Any other suggestions? As long as I don't do anything to the system, except open and close applications, everything seems to go well. Whether it's the USB disk or anything else I have no clue.
