• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Problem - Section numbers not autonumbering
New Here ,
Mar 04, 2014 Mar 04, 2014
I'm working on a book with the following document layout:
(Note: JHSV_Chapter_1.fm and JHSV_Ch1.fm are excluded documents.)
I have set Section 1-1 to start numbering at Section #: 1.  The remaining sections are set to Continue numbering from previous section in book:
I can't get the section header numbers to autonumber.  I need them to be Section 1.2, 1.3, and so on. As can be seen below, the section numbers have reset back to 1.1.  (The figure titles remain correct since I have not updated my references.)  My header paragraph format can also be seen in the image below.
I have fought with this all day yesterday.  At one point, it actually corrected itself (hence, the correct figure numbers).  But now it has reset.
Help!
Views
489
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
The Section Numbering is controlled by the <$sectionum> building block. I don't see you using that in your paratag auto-number format.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 05, 2014 Mar 05, 2014
Thank you.  That fixed it!
Sort of.
Now I have another related problem.  The section numbering is not continuing from previous section.  In order for this autonumbering to work, I have to manually set the section numbers, which I shouldn't have to do.
Below is a screen capture.  I have section 1 manually set.  Section 2, as well, since I wanted to conduct a test to see if the autonumbering worked.  But the following sections, as can be seen, are set to continue, but they're not doing so.
Votes
Translate
Translate
Report
Report
New Here ,
Ignore the prior post.  I learned something:
You cannot import formats unless the document is literally opened.  I thought you could just select the book (at the left) and import format.
And then one must be sure to Refresh the book for changes to take place.
All things that I didn't do, but now have and all is wonderful and good.
Thank you.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Well, actually you can import the formats to all files in a book, but you have to select the files within the book file panel first (not just the first line showing the book namee) in order to import to (and they don't have to be open).
If the files aren't open, FM will open the files, import, save and close, i.e. no undo. However, if you open the files first, then you control the save, i.e. you can throw away the import by not saving when you go to close the file (allows undo).
Votes
Translate
Translate
Report
Report
LEGEND ,
Did you set the Section building block at the book level for all relevant files? It looks like you did, but just checking (book always trumps file settings), i.e. did you also set it in the individual files?
Votes
Translate
Translate
Report
Report
