19 Replies Latest reply on Mar 26, 2014 6:06 PM by A.T. Romano
    16:9 widescreen format question
    poke01 Level 1
      How do I create a project so my video will be in 16:9 widescreen format? I am using Premier Elements 12. As of now my videos are in 4:3 format when I upload them to Youtube.
        • 1. Re: 16:9 widescreen format question
          You start with widescreen video... what is your brand/model camera?
          The Elements Tutorial Links Page http://forums.adobe.com/thread/1275830 has information about setting up a project
          • 2. Re: 16:9 widescreen format question
            poke01 Level 1
            I used my iPhone 4 and my Panasonic video camera. Model SDR-H40
            • 3. Re: 16:9 widescreen format question
              the_wine_snob Level 9
              Welcome to the forum.
              As per John T's link, you can set your Project, as needed, and then check the box to Force that Setting.
              Then, when you Import the footage, you can manipulate it, to fit the chosen format, if needed.
              • 4. Re: 16:9 widescreen format question
                A.T. Romano Level 7
                poke01
                The usual drill is to set the project preset to match the properties of your source media so that the program is directed to set up the right space in the Edit area monitor for editing purposes. So, if you have 4:3 format, then your project preset would probably be NTSC DV Standard or it PAL counterpart.
                But, under the circumstances, look at this idea....
                Open your Premiere Elements 12 project to the Expert workspace and make sure that the project preset is the default 1080i30
                NTSC
                AVCHD
                Full HD1080i30
                or its PAL counterpart
                Import your 4:3 video into the project with Add Media/Files and Folders/Project Assets from where you drag your video to the Expert workspace Timeline.
                Click on the screen so that you see a bounding box around the image there and drag on the bounding box handles to scale the image just to display in the screen with no black borders.
                Publish+Share/Social Websites/YouTube with preset = High Definition Video for YouTube 1920 x 1080.
                What does that look like once it is uploaded to YouTube 16:9?
                The idea goes against the grain if you are starting with 720 x 480 (or PAL counterpart 720 x 576) and taking it to 1920 x 1080. But see if you can get away with it.
                In your scheme of things, are black borders acceptable. What I am asking you to try ends up with 16:9 with no black borders. But I am not too comfortable with the SD to HD.
                Please review and then let us know the outcome.
                In questions such as these, please give properties of the source media.
                Thanks.
                ATR
                • 5. Re: 16:9 widescreen format question
                  A.T. Romano Level 7
                  poke01
                  I did not see all the replies until after I posted mine.
                  Where did the 4:3 video comes from based on your initial post?
                  The iPhone 4 is reported to record 720p which is a 16:9 format as well as 480p 4:3 format.
                  That Panasonic id probably shooting MPEG2 4:3.
                  Are you recording 4:3 with both cameras?
                  If so, my post stands as written.
                  Please update us on your progress.
                  Thank you.
                  ATR
                  • 6. Re: 16:9 widescreen format question
                    poke01 Level 1
                    Thank you for all the replies and help. I will try all suggested options and update everyone tomorrow on the outcome. Thanks again!
                    • 7. Re: 16:9 widescreen format question
                      poke01 Level 1
                      Here are the two videos:
                      This one is the original with black borders:
                      http://www.youtube.com/watch?v=wc8GnfSjif8
                      This is the same video only I stretched the image to fill the entire box. I guess it worked?
                      http://www.youtube.com/watch?v=qdqDqrDtzTQ
                      • 8. Re: 16:9 widescreen format question
                        A.T. Romano Level 7
                        poke01
                        Looks good. You could do some panning if you wanted to get the player's face in one or two of the views. But, since the focus is the playing, looks OK.
                        It looks like you are using 4:3 footage, probably 640 x 480. Also, look at a 4:3 presentation on YouTube - see if better, the same, or not so good
                        Open Premiere Elements new project.
                        Go to File Menu/New/Project and set the project preset to NTSC DV Standard
                        Before you close out of there, in the final dialog, put a check mark next to "Force Selected Project Setting on this Project".
                        Then, in the Expert workspace, import your video with the program's Add Media/Files and Folders/Project Assets from where you drag the video into the Timeline.
                        For export....
                        Publish+Share
                        Social Websites
                        YouTube
                        with preset = Flash Video for YouTube
                        Then let us know what is happening.
                        Thanks for checking out the suggestions.
                        ATR
                        • 9. Re: 16:9 widescreen format question
                          poke01 Level 1
                          Sorry for the delayed update. I have opened the project preset settings before but for some reason can not figure out how to do it again.
                          • 10. Re: 16:9 widescreen format question
                            poke01 Level 1
                            My apologies, I remembered how to do it.
                            • 11. Re: 16:9 widescreen format question
                              A.T. Romano Level 7
                              poke01
                              Hope all is going well.
                              Just a reminder for anyone looking into your thread...
                              If you want to check to see project settings were set by you or the project, then in the Expert workspace
                              Edit Menu
                              Project Settings
                              General
                              and review the readings for Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio even if they look
                              grayed out.
                              If you want to set the project preset yourself, instead of letting the project do it automatically, then
                              Expert workspace
                              Change Settings
                              In New Project dialog pick the project preset that matches the properties of your source media
                              Then before you exit the area, in the last dialog there, put a check mark next to
                              "Force Selected Project Setting on This Project"
                              Back in the Premiere Elements 12 Expert workspace, Add Media/
                              ATR
                              • 12. Re: 16:9 widescreen format question
                                poke01 Level 1
                                Just uploaded a video and I followed the following directions:
                                For export....
                                Publish+Share
                                Social Websites
                                YouTube
                                This video had a nice picture but still had black borders on the side. With a nice picture, can I import it into a different setting in Youtube to get the 16:9 screen?
                                • 13. Re: 16:9 widescreen format question
                                  A.T. Romano Level 7
                                  poke01
                                  What is your source video, 4:3 or 16:9? My recollection that it was 4:3. If so and you want to try to get a 16:9 look from it...
                                  Set the project preset to NTSC DV Widescreen.
                                  Import your video. If it is 16:9, the fit into the Edit area monitor space will be right on..
                                  If you are starting with 4:3 video, then click on the Edit area monitor to bring up a bounding box (white frame with white point at corners and sides). Drag on one of the white points to scale the video so that it just fills the Edit area monitor space, just enough that you do not see any black borders.
                                  Then
                                  Publish+Share
                                  Social websites
                                  YouTube
                                  See what that looks like.
                                  We will be watching for your results.
                                  ATR
                                  • 14. Re: 16:9 widescreen format question
                                    poke01 Level 1
                                    Yes, I believe it's 4:3. It's off my iPhone. Interesting enough for what it's worth... if you use the front facing camera on the iPhone 4 you will get 640x480. If you use the rear facing camera you get 1280x720 with HD quality. Others probably knew that but for those who are reading this and didn't, hope that helps.
                                    I used the front facing camera so I recorded in 640x480. I will try your suggestion tonight and see how it comes out. Thanks again!
                                    • 15. Re: 16:9 widescreen format question
                                      A.T. Romano Level 7
                                      poke01
                                      My iPod Touch 4th generation's camera does the same as you are describing for you iPhone 4.
                                      Camera
                                      Back
                                      Videos are 720p (1280 x 720 @ up to 30 frames per second)
                                      Photos are 960 x 720 pixels
                                      Camera
                                      Front
                                      called "VGA quality"
                                      Videos and photos, 640 x 480 pixels
                                      ATR
                                      • 16. Re: 16:9 widescreen format question
                                        poke01 Level 1
                                        Well the video is up and it looks good. Looks the same as the other one I edited. I didn't edit the audio, I just put part of the video up to see how the screen looked. Now if I use the rear facing camera on the iPhone 4 with 1280x720 and HD quality, do I need to make adjustments to my project preset that I just set or will it work the same?
                                        Thanks again for all your help. This video editor program is fun.
                                        Here's a temporary link to view the video.
                                        http://www.youtube.com/watch?v=yCz4T8ywarA
                                        • 17. Re: 16:9 widescreen format question
                                          A.T. Romano Level 7
                                          poke01
                                          Looking good. The 1280 x 720 should be even better.
                                          The Premiere Elements 12 project preset for this 1280 x 720 (720p) should be
                                          NTSC
                                          AVCHD
                                          AVCHD-LITE 720p30
                                          Best do the manual setting of that project preset.
                                          In the Premiere Elements 12 Expert workspace
                                          In the New Project Dialog set for the project preset above.
                                          Then before you exit the final dialog in that area, be sure to put a check mark next to
                                          When back in the Expert workspace, use Add Media/Files and Folders/ to bring your
                                          video into Project Assets. From Project Assets, drag you video to the Timeline. You should
                                          not see any black borders in the Edit area monitor.
                                          Thanks for the follow ups with the good news.
                                          ATR
                                          • 18. Re: 16:9 widescreen format question
                                            poke01 Level 1
                                            I followed the above instructions and when I imported the video it came out perfect. The video covered all black borders with out having to stretch the video. Now once I am done editing and ready to upload to YouTube, what is the YouTube preset that I should use?
                                            Thank again!
                                            • 19. Re: 16:9 widescreen format question
                                              A.T. Romano Level 7
                                              poke01
                                              Great news.
                                              For your 1280 x 720p30 Timeline, lets go with
                                              Publish+Share
                                              Social Websites
                                              YouTube
                                              and the Presets = High Definition Video for YouTube - 1920 x 1080.
                                              We will be watching for the results.
                                              Thanks for the follow ups.
                                              ATR
