2 Replies Latest reply on Mar 5, 2014 7:11 AM by FrozenMushroom
    Writing Adobe Image Resource Block to a Tiff file
    FrozenMushroom
      Background :
      I am working on a small .NET application which reads the tiff file and performs some metadata related operations on it.
      The program works fine with all of the tiff Images that are taken from photoshop. I have recieved a tiff file from the client which does not work with the program.
      I checked the metadata info for the file using imagemagik following is the output
        Format: TIFF (Tagged Image File Format)
        Mime type: image/tiff
        Class: DirectClass
        Geometry: 6986x3754+0+0
        Resolution: 96x96
        Print size: 72.7708x39.1042
        Units: PixelsPerInch
        Type: TrueColorAlpha
        Base type: TrueColor
        Endianess: MSB
        Colorspace: sRGB
        Depth: 8-bit
        Channel depth:
          red: 8-bit
          green: 8-bit
          blue: 8-bit
          alpha: 8-bit
        Channel statistics:
          Red:
            min: 37 (0.145098)
            max: 255 (1)
            mean: 215.041 (0.843299)
            standard deviation: 48.8483 (0.191562)
            kurtosis: 0.845012
            skewness: -1.09632
          Green:
            min: 25 (0.0980392)
            max: 255 (1)
            mean: 213.399 (0.836859)
            standard deviation: 50.853 (0.199424)
            kurtosis: 0.908226
            skewness: -1.09806
          Blue:
            min: 21 (0.0823529)
            max: 255 (1)
            mean: 210.495 (0.825471)
            standard deviation: 53.6527 (0.210403)
            kurtosis: 0.124965
            skewness: -0.929882
          Alpha:
            min: 64 (0.25098)
            max: 255 (1)
            mean: 254.948 (0.999796)
            standard deviation: 2.56957 (0.0100768)
            kurtosis: 2437.44
            skewness: 49.3893
        Image statistics:
          Overall:
            min: 0 (0)
            max: 255 (1)
            mean: 159.747 (0.626458)
            standard deviation: 44.321 (0.173808)
            kurtosis: 48.4205
            skewness: -8.00071
        Rendering intent: Perceptual
        Gamma: 0.454545
        Chromaticity:
          red primary: (0.64,0.33)
          green primary: (0.3,0.6)
          blue primary: (0.15,0.06)
          white point: (0.3127,0.329)
        Background color: white
        Border color: srgba(223,223,223,1)
        Matte color: grey74
        Transparent color: none
        Interlace: None
        Intensity: Undefined
        Compose: Over
        Page geometry: 6986x3754+0+0
        Dispose: Undefined
        Iterations: 0
        Compression: LZW
        Orientation: TopLeft
        Properties:
          date:create: 2014-02-15T21:18:37+06:00
          date:modify: 2014-02-09T16:29:10+06:00
          signature: a5c4a9415437ee2d3b0c3d860b30c5367f73fe7553c3f54923caf6da4b9e4623
          tiff:alpha: unassociated
          tiff:endian: lsb
          tiff:photometric: RGB
          tiff:rows-per-strip: 3754
        Artifacts:
          filename: C:\Users\Jane\TiffPathOperation\bin\Debug\Example1client_no_path.tiff
          verbose: true
        Tainted: False
        Filesize: 14.6MB
        Number pixels: 26.23M
        Pixels per second: 54.64MB
        User time: 0.484u
        Elapsed time: 0:01.479
        Version: ImageMagick 6.8.7-4 2013-10-26 Q16 http://www.imagemagick.org
      Unlike other tiff images this image does not contain 8bim profile information, which is required for proper execution of the program
      Profiles:
        Profile-8bim: 11720 bytes
        Profile-icc: 3144 bytes
          Description: sRGB IEC61966-2.1
          Manufacturer: IEC http://www.iec.ch
          Model: IEC 61966-2.1 Default RGB colour space - sRGB
          Copyright: Copyright (c) 1998 Hewlett-Packard Company
        Profile-xmp: 19368 bytes
      Possible solution :
      I would have to add the Image resource block data to such image in which the profile information is missing.
      Problem :
      I would have to write metadata for the tag 34377 as given in the Adobe Specification for the listed resource Id
      How am I suppose to write this entire block and assign it to the Tag 34377 in C#?
      What values should be added for each resource Id ?
      Tiff Image : http://1drv.ms/NtzbCr
        • 1. Re: Writing Adobe Image Resource Block to a Tiff file
          Silkrooster Adobe Community Professional & MVP
          I would think instead of adding metadata to the file, use an if statement to check if that tag is missing, then take steps to bypass that portion of the file.
          I certainly do not know enough about the tiff format to be of any real help, but I would think that checking for missing tags is doable.
          • 2. Re: Writing Adobe Image Resource Block to a Tiff file
            FrozenMushroom Level 1
            Bypassing the portion of the file is not a option in my case since a part
            of the program reads the bytes and performs operation on the image when it
            reads 8bim.
            The image if re-saved in Photoshop gets the required metadata. (Can be seen
            by using imagemagik's identify utility)
            Only option that I have is to write the information for the resource in
            side the Image resource block tag.
            How am I suppose to write this resources when I am using BitmapMetadata
            class?
            Regards,
            Charanraj Golla
