7 Replies Latest reply: Mar 5, 2014 9:45 AM by straightlife RSS
    strange look in Index
    straightlife Community Member
      I can't figure this out.
      All the page numbers have these little lines between them like so...  I want to get rid of them.  Can anybody diagnose what's causing that?
      Way it Was, The  96, 101, 102, 103
      Winter Moon  262, 264, 265, 267, 268, 269, 270, 351
        • 1. Re: strange look in Index
          Salah Fadlabi Community Member
          In Generate Index check Between Page Numbers it may be there's _ after ,
          • 2. Re: strange look in Index
            Nope.  Can't figure out where it's coming from.
            I can go through the whole index and "fix" the character styles of all the page numbers, but there's got to be a better way than that.
            • 3. Re: strange look in Index
              You can search with Find/Change grep
              Find what: (?<=,)_
              change to : blank
              Find format: select index style
              note: when i copy the little line from your sample and paste in grep it covert to white space. but you can copy the line from the index and paste after (?<=,)
              • 4. Re: strange look in Index
                [Jongware] Community Member
                The comma's are underlined as well as the spaces, so this is consistent with a stray Underline code that gets applied to default text -- either directly or through a character style.
                Make sure you have nothing selected and check if a character style or Underline is set as a default.
                To remove it: use the Find Format dialog and check "Underlined" in the Find, *un*check "Underlined" in the Change parts. Or, if there is nothing you would want to underline in this index, select the entire text and press the Underline toggle or the hot key (Ctrl/Cmd + Shift + U)twice -- once to 'set', again to 'clear'.
                • 5. Re: strange look in Index
                  Obi-wan Kenobi Community Member
                  Hi straightlife,
                  Can you send us a little ID file with a part of text and the corresponding generated index?
                  Thanks.
                  • 6. Re: strange look in Index
                    If it is an "underlined"!
                    In this case, I have reproduced the problem but, here, this "underlined" can not be deleted directly by a search-and-replace.
                    Why?
                    Because, to do it, I have introduced a grep style associated with a character style:
                    Grep style: ,
                    [comma + space]
                    Char style: with only "Underlined" applied
                    This may help some people in other situations.
                    • 7. Re: strange look in Index
                      Well, thanks everybody!  I went to bed after my last post.  But before I turned off the lights I trashed a character style I'd been using.  It was an underline style.
                      This morning when I generated an index the problem was gone.
                      What's so strange is that that style was not used anywhere in the index formatting. It just sort of creeped in all by itself!
                      Now I've got to go back into my document and replace all those underlines manually.
