0 Replies Latest reply on Mar 5, 2014 9:32 AM by gwarmonger
    CFwheels..update by ID
    gwarmonger
      I've recently started using CFwheels. I am trying to update a database item by ID.
      Usually what I would do is have a hidden form field that passes an ID number in the value. Then I would run a query something like SET WHERE ID=#ID#.
      First problem...I am not sure how to set the value on the input control...I have -
      #checkBox(objectName="reqequip", property="#serial#", defaultValue="#serial#", label="")#
       #hiddenField(objectName="reqequip", property="#serial#", label="")#
      Which prints out this below. I thought property argument is supposed to define value but it is not. And also I do not even know where the 3rd item is coming from as I only have two form fields.
      <input id="reqequip-testatawetg" type="checkbox" value="1" name="reqequip[testatawetg]" defaultvalue="testatawetg"> <input id="reqequip-testatawetg-checkbox" type="hidden" value="0" name="reqequip[testatawetg]($checkbox)">
       <input id="reqequip-testatawetg" type="hidden" value="" name="reqequip[testatawetg]" label="">
      My controller is -
      <cffunction name="reqequip">
              <cfset reqequip = model("equips").new()>
              <cfset reqequip.update(status="Pending", properties=params.reqequip)>
          </cffunction>
      The whole form is in a loop...so each row has a different id...I want to select one row and then update the STATUS column for that row when I submit.. ..here is the whole form ---
      <cfoutput>
          #startFormTag(action="reqequip", id="reqequip")#
           #dateSelect(objectName="reqequip", property="startdate", order="day,month,year")#
            #dateSelect(objectName="reqequip", property="enddate", order="day,month,year")#
      <cfparam name="Form.startdate" default="#dateformat(now(), 'mm/dd/yyyy')#">
              <cfparam name="Form.enddate" default="#dateformat(now()+1, 'mm/dd/yyyy')#">
              <cfparam name="Form.selectdate" default="#dateformat(now(), 'mm/dd/yyyy')#">
          </div>
          <span class="label label-default">Equipment List</span>
          <table class="table table-bordered table-striped">
              <tr>
                  <td><b>Select</b></td>
                  <td><b>Name</b></td>
                  <td><b>Description</b></td>
                  <td><b>Status</b></td>
              </tr>
          <cfloop query = "equips">
              <tr>
                  <td>
                      <!---<input type="checkbox" name="status"  value="#serial#">Select:
                      <cfinput name="serial"type="text"style="display:none" value="#serial#">
                      <cfinput name="name"type="text"style="display:none" value="#name#">--->
                  </td>
                  <td>#equips.name#</td>
                  <td>#equips.descrip#</td>
                  <td>#equips.status#</td>
              </tr>
              </cfloop>
      </table>
            <!---<cfinput class="btn btn-default" type="Submit" value="Submit" name="reqequip"></cfinput>--->
            #submitTag(class='btn btn-default')#
          #endFormTag()#
      </cfoutput>
      Thanks!
