7 Replies Latest reply on Mar 6, 2014 3:30 PM by pixxxel schubser
    quick syntax question
    mec_os Level 4
      in the extendscript documentation it says you can assign a name to UI elements at creation like the example given below
      dlg.btnPnl.cancelBtn = dlg.btnPnl.add('button', undefined, 'Cancel',
      {name:'cancel'});
      but when i do it like that, the bject's name comes out as undefined when accessed like this
      dlg.btnPnl.cancelBtn.name
      or like this:
      dlg.btnPnl.children['name']
      but adding the object then naming like this works-
      dlg.btnPnl.cancelBtn.name = "Cancel";
      i'm using illustrator cc and the extendscript guide for cs6 (couldn't find a newer one).
      did the syntax change?
        • 1. Re: quick syntax question
          pixxxel schubser MVP & Adobe Community Professional
          Hi mec_os,
          I haven't CS6 here and no CC at work.
          But one syntax ever works since years ago (I don't need the name property):
          dlg.btnPnl.cancelBtn = dlg.btnPnl.add('button', undefined, 'Cancel');
          If you really want to try 'Your' syntax, here is an example written by artchrome.
          http://forums.adobe.com/message/2757538#2757538
          Have fun
          • 2. Re: quick syntax question
            CarlosCanto Adobe Community Professional & MVP
            use this syntax
            alert(dlg.btnPnl.cancelBtn.properties.name);
            • 3. Re: quick syntax question
              mec_os Level 4
              that works! thank you carlos. you are godly.
              i don't really need to name my UI object, i just got baffled why i couldn't make it work.
              • 4. Re: quick syntax question
                yeah, I did have to name a set of buttons on one of my scripts and I was pulling my hair trying get the name out of them...
                • 5. Re: quick syntax question
                  I'm a little bit confused.
                  Careful reading of the linked thread gives you the same answer.
                  artchrome wrote:
                  var ressource="dialog {  \
                  text: 'FRONT or BACK SELECTOR', frameLocation:[100,100], \
                  MyPanel: Panel { orientation:'column', alignChildren:['left','Top'], \
                                 text: 'Option FRONT&BACK', \
                                 title: Group { orientation: 'column',  \
                                           FrontVar: RadioButton { alignment:'left', text: 'FRONT select ?', value:true}, \
                                           BackVar: RadioButton { alignment:'left', text: 'BACK select ?', value:false}, \
                                                 CancelBtn: Button { text: 'Cancel', properties:{name:'cancel'} }, \
                                                 OkBtn: Button { text: 'Valid', properties:{name:'ok'} }, \
                  • 6. Re: quick syntax question
                    mec_os Level 4
                    the question was not how to create the button, but why when you created it in that specific syntax you can't use the syntax "button.name" to retrieve the name from the element. you have to use "button.properties.name" like carlos says. i couldn't figure that out.
                    if you assign the name property after creating the object you can.
                    example;
                    button.name = "name";
                    then you can call it like so;
                    "button.name"
                    sorry for the confusion.
                    • 7. Re: quick syntax question
                      Okay. I thought it would be clear.
                      In the linked script artchrome named his button with:
                      dlg - MyPanel - title - CancelBtn - properties:{name:'cancel'}
                      and of course you can call the name of the button with:
                      alert(dlg.MyPanel.title.CancelBtn.properties.name)
                      Regards
                      pixxxelschubser
