2 Replies Latest reply on Mar 6, 2014 4:41 AM by oddgames
    Why doesn't this code work in my extension? Retrieving generator settings from meta data
    oddgames
      Using the code below in my host.jsx file within my html 5 extension this code doesnt work:
      $._photoshop.setDocumentData('project.isXUI','true');
      alert($._photoshop.getDocumentData('project.isXUI'));
      Here's the error I get:
      Error: The requested property does not exist.
      It works perfectly from ExtendScript but the same lines of code do not work when called via "window.__adobe_cep__.evalScript". What am I missing?
      $._photoshop = {
      setDocumentData: function(key,value)
              try
                  var classProperty = charIDToTypeID('Prpr');
                  var propNull = charIDToTypeID( 'null' );
                  var classNull = charIDToTypeID( 'null' );
                  var typeOrdinal = charIDToTypeID('Ordn');
                  var enumTarget = charIDToTypeID('Trgt');
                  var classDocument = charIDToTypeID('Dcmn');
                  var classLayer = charIDToTypeID('Lyr ');
                  var propProperty = stringIDToTypeID("property");
                  var propGeneratorSettings = stringIDToTypeID("generatorSettings");
                  var propProperty = stringIDToTypeID(key); //unique name for the setting
                  var keyTo = charIDToTypeID( 'T   ' );
                  var actionSet = charIDToTypeID( "setd" );
                  //Make a property reference to generator settings for active layer.
                  //(use classDocument for the active document)
                  //NOTE: putProperty needs to come before putEnumerated
                  var theRef = new ActionReference();
                  theRef.putProperty(classProperty, propGeneratorSettings );
                  theRef.putEnumerated(classDocument, typeOrdinal, enumTarget);
                  //Build descriptor for your plugin settings, with 2 example settings, a boolean and a string
                  var mySettingsDesc = new ActionDescriptor();
                  mySettingsDesc.putString(propProperty,value);
                  //Execute the set action, setting the descriptor into the property reference,
                  //setting just the plugin's settings (propProperty == strMySettings)
                  var setDescriptor = new ActionDescriptor();
                  setDescriptor.putReference(propNull,theRef);
                  setDescriptor.putObject(keyTo,classNull,mySettingsDesc);
                  setDescriptor.putString(propProperty, "au.com.oddgames.xui");
                  executeAction( actionSet, setDescriptor, DialogModes.NO );
                  return true;
              catch (e)
                  var exception = {};
                  exception.target = "setDocumentdata";
                  exception.message = e.toString();
                  return exception;
          getDocumentData: function(key)
              try
                  var actionGet = charIDToTypeID( "getd" );
                  //Execute the get action, getting the descriptor for the property reference,
                  //getting just the plugin's settings (propProperty == strMySettings)
                  var getDescriptor = new ActionDescriptor();
                  getDescriptor.putReference(propNull,theRef);
                  getDescriptor.putString(propProperty, "au.com.oddgames.xui");
                  var actionResult = executeAction( actionGet, getDescriptor, DialogModes.NO );
                  //Extract the settings
                  var mySettingsDesc = actionResult.getObjectValue(propGeneratorSettings);
                  return mySettingsDesc.getString(propProperty);
              catch (e)
                  var exception = {};
                  exception.target = "getDocumentData";
                  return exception
        • 1. Re: Why doesn't this code work in my extension? Retrieving generator settings from meta data
          oddgames Level 1
          Ok the setting is only being saved for the last property, if I do this:
          $._photoshop.setDocumentData('project.name','hello');
          Only the project.name property will be saved when I try using getDocumentData so I guess I'm somehow overwriting something.
          • 2. Re: Why doesn't this code work in my extension? Retrieving generator settings from meta data
            oddgames Level 1
            Ok got it, I have to make sure I pull the descriptor back then save my settings over the top:
            $._photoshop = {
                setDocumentData: function(keys,values)
                    try
                        var strMySettings = "xui";
                        getDescriptor.putString(propProperty, strMySettings);
                        if (keys.indexOf(",") > 0)
                            keys = keys.split(',');
                            values = values.split(',');
                        else
                            keys = [keys];
                            values = [values];
                        for (var x =0; x < keys.length; x ++)
                            var key = keys[x];
                            var value = values[x];
                            var propMyStringProperty = stringIDToTypeID(key);
                            mySettingsDesc.putString(propMyStringProperty,value);
                        setDescriptor.putString(propProperty, strMySettings);
                        return true;
                    catch (e)
                        var exception = {};
                        return JSON.stringify(exception);
                    try
                        var strMySettings = "xui"; //unique name for your settings/plugin
                        var propMyStringProperty = stringIDToTypeID(key); //unique name for the setting
                        return mySettingsDesc.getString(propMyStringProperty);
                    catch (e)
                        var exception = {};
