I lose my Session variableas
Yasmin_lady Jun 22, 2006 7:19 AMI try to open a powerpoint presentetion form the server,
using the following code
<cfif not listLen(lst) is 0>
<cfoutput>
<frameset cols="*,110" border="5">
<frame src="#path#/#listGetAt(lst,1)#" name="hauptframe" noresize scrolling="auto" marginwidth="0" marginheight="0">
<frameset rows="*,100,0" border="0">
<frame src="#A_linkFile#?id=#id#" noresize scrolling="auto" marginwidth="0" marginheight="0">
<frame src="#A_topFile#?id=#id#&path=#path#" name="topframe" noresize scrolling="no" marginwidth="0" marginheight="0">
<frame src="#path#/gesamtdokument.ppt" name="printframe" noresize scrolling="no" marginwidth="0" marginheight="0">
<!---<frame name="printframe">--->
</frameset>
</frameset>
<noframes>
<body class="webShow" leftmargin="0" marginwidth="0" topmargin="0" marginheight="0">
<p>This page contains frames. You need a Web browser that supports frames
to view this page.</p>
</body>
</noframes>
</cfoutput>
<cfelse>
<body class="webShow">
<P>Could not find any data for your specified id=<cfoutput>#id#, #lst#</cfoutput></P>
</body>
</cfif>
I only get the mainframe, but the tubs nail in the smail fram can not be showed.
Got the follwing error.
Although i definded the Session.Abmeldung in my Application.cfm. Other page use it without troubles.
Need Help Urgently
Many thanks
Error Occurred While Processing Request
Element ABMELDUNG is undefined in SESSION.
The error occurred in D:\Sinntech\cfm\Application.cfm: line 184
182 : </cfif> --->
183 :
184 : <cfif ((Cookie.Username eq "") or (Cookie.pass eq "") or (Session.abmeldung is true))> <!---Cookie.Username , Cookie.pass sind die Benutzerdaten gespeichern ==> Auto login --->
185 : <cfif (findnocase("login.cfm",cgi.script_name,1) is 0 and
186 : findnocase("adduser.cfm",cgi.script_name,1) is 0 and
Please try the following:
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.0.3705; .NET CLR 1.1.4322; InfoPath.1; .NET CLR 2.0.50727)
Remote Address 158.226.253.145
Referrer https://sinntech.siemens.at/cfm/webshow_index.cfm?id=943
Date/Time 22-Jun-06 03:59 PM
Stack Trace (click to expand)
at cfApplication2ecfm1151475425.runPage(D:\Sinntech\cfm\Application.cfm:184)
coldfusion.runtime.UndefinedElementException: Element ABMELDUNG is undefined in SESSION.
at coldfusion.runtime.CfJspPage.resolveCanonicalName(CfJspPage.java:1049)
at coldfusion.runtime.CfJspPage._resolve(CfJspPage.java:1026)
at coldfusion.runtime.CfJspPage._resolveAndAutoscalarize(CfJspPage.java:1125)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:147)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:357)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:62)
at coldfusion.filter.CfincludeFilter.include(CfincludeFilter.java:30)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:93)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:80)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:47)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:35)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:43)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:105)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:249)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:457)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
<cfoutput>
</frameset>
</frameset>
<noframes>
</body>
</noframes>
</cfoutput>
<cfelse>
</body>
</cfif>
Need Help Urgently
Many thanks
182 : </cfif> --->
183 :
