14 Replies Latest reply: Mar 6, 2014 2:42 PM by www.aimiecaprice.com RSS
    Where is .svg support... where the heck is SUPPORT?
    shawninvancouver Community Member
      Pardon me if I am completely wrong but I am diving into Dreamweaver for the first time since about CS3 and right away, I am annoyed because of:
      1. No .svg support?
        Seriously, I shouldn't even be asking for this! This is a standard vector image format that all modern browsers support. What the heck?
        I found a plug-in from a few years ago but it doesn't work.
        How do the rest of you handle vector images?
        Why isn't there outrage over this terrible image support?
      2. Where's the documentation support for Dreamweaver CC?
        Seriously, again... I should not have to ask!
        Clicking on Help (F1) brings up, "Dreamweaver Help / CS6 Help and tutorials" with a bunch of defined topics.
        There are two search areas:
        a) Top right side search results default to every Adobe product since the beginning of time. Utterly USELESS. There is, however, a pull-down menu to narrow your search to a single product. Tried it, it doesn't appear to work
             very well as the results still show non-Dreamweaver CC entries!
        b) The other search option is Adobe Community Help. Well, I am here! But this is not a good substitute for good documentation.
        BTW, I was able to find this: http://helpx.adobe.com/pdf/dreamweaver_reference.pdf but it doesn't include any reference to .svg images (only one about unrelated font support)
        NOTE TO ADOBE! Help should be topical and specifically related to the product and VERSION that I am currently using.
      Am I wrong? Am I missing something?
      But most important, where is the .svg support! Is Dreamweaver a serious web design tool?
      I expect A LOT more from a product suite that is costing me (us) about $6000 every 10 years for life! Okay, I'm done my rant. I hope that someone is able to show me that I'm an idiot. :-)
        • 1. Re: Where is .svg support... where the heck is SUPPORT?
          Nancy O. CommunityMVP
          1. No .svg support?
          DW isn't a browser.  At best, Design View is an approximation of what you might expect to see in some older browsers.  Live View is a little better because it emulates a webkit/Chrome engine.  But if you want to see advanced CSS level 3 properties like Gradients & SVG images, you'll need to preview in a browser.  I keep mine open all the time to check my work.
          Feel free to submit a feature request.  If enough people ask for it, there's a good chance we'll see it in a future update.
          https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
          There's a fair amount of crossover between DW CS6 and DW CC.   If you know how to use CS6, apart from a few menu changes & the new CSS Designer Panel, things aren't terribly different.
          Learn DW CC (videos)
          http://tv.adobe.com/show/learn-dreamweaver-cc/
          Creating your first web site in DW CC - (5-part tutorial)
          http://www.adobe.com/devnet/dreamweaver/articles/first_website_pt1.html
          New CSS Designer Panel
          http://helpx.adobe.com/dreamweaver/using/css-designer.html
          Nancy O.
          • 2. Re: Where is .svg support... where the heck is SUPPORT?
            hans-g. CommunityMVP
            Hello Shwan,
            hmm, let me answer only to svg support at the first moment (I'm smitten over a bit ): I fear it's not directly a question of DW it's so too a browser thing. Have a look to my example I made for a Japanese friend an try it in IE and in FF, the first can't show it (you have to unblock), in contrast to it FF. Here the link: http://hansgd.de/DWTest/svgO/object_data.htm.
            And here two svg links, given as an example to insert the codes into your DW to "play" with:
            http://www.w3schools.com/svg/svg_inhtml.asp
            http://demosthenes.info/blog/428/Using-SVG-In-Web-Pages
            Hans-Günter
            • 3. Re: Where is .svg support... where the heck is SUPPORT?
              Thanks for the replies everyone.
              I understand that DW is not a browser, however, I should be able to drag/drop .svg images into the editor (as I can with .png) and the .svg images should display.
              I know I can use the code editor to manually code in .svg but if I wanted to manually code/insert a .svg image, I would just use NotePad ++ editor or Aptana Studio.
              Thanks again folks.
              • 4. Re: Where is .svg support... where the heck is SUPPORT?
                Hello Nancy,
                I certainly appreciate your response but you didn't address my question. I don't really care (at this point) about videos or tutorials... I think a basic requirement is documentation in a searchable HTML format or as a PDF that is specific to the software's version (yes, I know CS6 is still essentially the same as CC). I find it impossible to fathom that besides the PDF I found, there isn't anything else. Again, I might be wrong.
                What I do know is that selecting Help, from inside Dreamweaver, does not open up to content specific help. That is absolutely ridiculous!
                • 5. Re: Where is .svg support... where the heck is SUPPORT?
                  Jon Fritz II CommunityMVP
                  Thanks again folks.
                  While it's not drag and drop, you can add an SVG as an image in DWCC pretty easily
                  Ctrl + Alt + i > Choose All Files from the dropdown > Pick an .svg that's in your site folder
                  It shows up like any other script include/embed, just a gray box in Design View.
                  Works fine in Live.
                  • 6. Re: Where is .svg support... where the heck is SUPPORT?
                    John Waller CommunityMVP
                    FWIW, I agree with you.
                    I have always found Adobe's online help cumbersome, meandering and vague at best and poorly structured or irrelevant to my immediate question at worst. I've never found targetted, context sensitive help that way.
                    I always find my answers (in Adobe resources or 3rd party sites or forums) via a Google search. It's quicker and more relevant to the question at hand. I usually get answers (or at least clues to solve it myself) in seconds.
                    • 7. Re: Where is .svg support... where the heck is SUPPORT?
                      Herbert2001 Community Member
                      John, I agree with you. I used to tell my students this joke:
                      "Once you really understand how to work in DW/PH/Illy/InD you might begin to work out what the help files are telling you".
                      Or in other words: the help files are a great reference AFTER you learned how to use these applications.
                      Otherwise, google is your friend. As are the people in this community.
                      • 8. Re: Where is .svg support... where the heck is SUPPORT?
                        Yup, agreed.
                        My paraphrase: the help files are written by experts, for experts - or for those with lots of time to wade through the meandering novice-level verbosity to find the occasional nugget of gold.
                        • 9. Re: Where is .svg support... where the heck is SUPPORT?
                          pziecina CommunityMVP
                          No .svg support?
                          Hi
                          Welcome fellow voice in the wilderness .
                          Dw does have good svg, (stand alone document) code support, providing one does not mind coding by hand, and one does not wish to do so inside an html5 document.
                          Live views svg is on-par with Chrome, (which does not say much, as Chrome fails miserably in my opinion).
                          I have been asking for better svg support since CS5, but until many others also ask for better support, Dw development will not take notice of the requirement. Adobes current thinking appears to be that we can create svg in Illustrator, edit the svg in Dw, and then embed/link-to in the html. Which is all very well but as svg is an integral part of html5, I think Dw should support direct svg code editing in an html5 document.
                          SVG is not actually an image until it is translated in a browser or svg viewer, until that time it is nothing more than code, so editing svg as an image should I think still be done in Illustrator or Inkscape, as one can apply the same argument to svg as normal image editing, it is best done in the correct program, (PhotoShop).
                          If you want better svg support then you, (and anyone else wishing this) should file a feature request, (link supplied in Nancy's post).
                          PZ
                          • 10. Re: Where is .svg support... where the heck is SUPPORT?
                            Jon Fritz II wrote:
                            While it's not drag and drop, you can add an SVG as an image in DWCC pretty easily Ctrl + Alt + i > Choose All Files from the dropdown > Pick an .svg that's in your site folder
                            Works fine in Live.
                            I understand that but what is the point of the [sort of] WYSIWYG editor, if I am unable to dynamically size my .svg, choose image display properties, etc... I can do that already in Aptana and Notepad ++.
                            No point in beating a dead horse so as an alternative, Dreamweaver better have great WYSIWYG support for tables.   Because one of the reasons why I decided to install Dreamweaver was to avoid hand coding tables (the one bit of html code I dislike the most). If it doesn't have great support, I'ma gonna be real mad!
                            • 11. Re: Where is .svg support... where the heck is SUPPORT?
                              Thanks everyone. Although I didn't get the answers I was looking for (can't always have my way ), I appreciate the time taken to offer your thoughtful responses.
                              I am also happy this didn't turn into an Adobe hate thread - even with the fodder I threw in.   Some quality folks in this forum.
                              • 12. Re: Where is .svg support... where the heck is SUPPORT?
                                www.aimiecaprice.com Community Member
                                GOOGLED: ADOBE TV SVG
                                found this resource...among others
                                http://tv.adobe.com/watch/learn-illustrator-cc/responsive-svg-in-illustrator-cc/
                                here is the manual
                                I found it by googling"dreamweaver cc help pdf"
                                This resource is a good one too
                                Google is always the better search engine, always look there for your adobe pdf manuals. You'll find them.
                                Once the pdf comes up you can do ctrl+F to find what you are looking for
                                Hope this helps. Happy coding
                                • 13. Re: Where is .svg support... where the heck is SUPPORT?
                                  here is the manual
                                  I had already posted that link in my original question.
                                  Perhaps for Adobe products but I'd say it Adobe is one of the few software companies where that might be true. Most other companies offer excellent context sensitive and version exact help... most? No, perhaps all but Adobe.
                                  Again, HELP (F1) should work! It doesn't. Opening to a generic help page (that defaults to search all products and ALL VERSIONS) is inexcusable for such an expensive product. Yes, you are correct. In Adobe's case, Google is much more effective for finding help... even better, these forums.
                                  • 14. Re: Where is .svg support... where the heck is SUPPORT?
                                    Shawn,
                                    I am sorry for your struggles. I have been there. Keep your chin up... your
                                    time spent researching will not be a waste.
