3 Replies Latest reply on Mar 7, 2014 9:31 AM by JRtist001
    Poster image not centering in browser
      My poster image (for viewing in IE8) is not centering in the browser window. It's displaying as left aligned with a big gap to the right of the image. How do I fix?
        • 1. Re: Poster image not centering in browser
          hemanthR Adobe Employee
          I believe you are talking about displaying the poster image in the down-level stage on IE.
          You can try by adding the below mentioned snippet with the '<style>' tag of your html file
          #<poster image name from elements panel>{
          position:static !important;
          • 2. Re: Poster image not centering in browser
            JRtist001 Level 1
            Thank you Hemanth, that is exactly what I am referring to. One final question though, as I am by no means an HTML guru...do I add the snippet while I'm in Edge or do I open the HTML file in Dreamweaver and add the code there?
            If in Edge, where do I access the code to add it (and where does it go)?
            If in Dreamweaver...here is the code for my file, where  would I place the snippet?
            <!DOCTYPE html>
                      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
                      <meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
            <!--Adobe Edge Runtime-->
                <script type="text/javascript" charset="utf-8" src="FEA2014_Invite_edgePreload.js"></script>
                    .edgeLoad-EDGE-450331542 { visibility:hidden; }
                body {
                      background-color: #000000;
            <!--Adobe Edge Runtime End-->
            <body style="margin:0;padding:0;">
                      <div id="Stage" class="EDGE-450331542">
            I GREATLY appreciate this advice!
            Many thanks,
            • 3. Re: Poster image not centering in browser
              JRtist001 Level 1
              Or I could (as I just discovered) just take my OAM file and place it in a Muse page, thus making sure that everything is centered as it should be.
              Thanks for chiming in though!
