5 Replies Latest reply: Mar 11, 2014 1:51 AM by Apod42 RSS
    The order of running scripts in .jsx file
    Apod42 Community Member
      Hello all,
      I have a .jsx file which includes multiple scripts. It looks like this:
      Script 1 - open file 1.psd
      Script 2 - find and replace text in all opened documents
      Script 3 - open file 2.psd and 3.psd
      Script 4 - find and replace text in all opened documents
      Script 5 - open files 4.psd, 5. psd, 6.psd, 7.psd
      Script 2 and Script 4 are not identical, I need to run them both.
      My question: why do Script 2 and Script 4 also run for files  4.psd, 5. psd, 6.psd, 7.psd ? These files are opened after the scripts... How can I stop this from happening?
      Thank you!!
        • 1. Re: The order of running scripts in .jsx file
          c.pfaffenbichler Community Member
          How can we tell if you don’t post the Scripts?
          • 2. Re: The order of running scripts in .jsx file
            Sorry
            // 1. Open file
            var inFolder = new Folder("C:/Directory")
            if(inFolder != null){
            var fileList = inFolder.getFiles("1.psd");
            for(var a = 0 ;a < fileList.length; a++)
            var docRef = open(fileList[a]);
            // 2. Replace text
            var file = new File ("C:/text-strings.txt");
            file.open("r");
            var readhere = file.read();
            var replacehere = String(readhere).split("\\n").join("\r");
            var id3 = stringIDToTypeID( "replace" );
            var desc2 = new ActionDescriptor();
            var id4 = charIDToTypeID( "null" );
            var ref1 = new ActionReference();
            var id5 = charIDToTypeID( "Prpr" );
            var id6 = stringIDToTypeID( "replace" );
            ref1.putProperty( id5, id6 );
            var id7 = charIDToTypeID( "TxLr" );
            var id8 = charIDToTypeID( "Ordn" );
            var id9 = charIDToTypeID( "Al  " );
            ref1.putEnumerated( id7, id8, id9 );
            desc2.putReference( id4, ref1 );
            var id10 = charIDToTypeID( "Usng" );
            var desc3 = new ActionDescriptor();
            var id11 = stringIDToTypeID( "find" );
            desc3.putString( id11, "mytext" );
            var id12 = stringIDToTypeID( "replace" );
            desc3.putString( id12, replacehere );
            var id13 = stringIDToTypeID( "checkAll" );
            desc3.putBoolean( id13, true );
            var id14 = charIDToTypeID( "Fwd " );
            desc3.putBoolean( id14, false );
            var id15 = stringIDToTypeID( "caseSensitive" );
            desc3.putBoolean( id15, true );
            var id16 = stringIDToTypeID( "wholeWord" );
            desc3.putBoolean( id16, false );
            var id17 = stringIDToTypeID( "findReplace" );
            desc2.putObject( id10, id17, desc3 );
            executeAction( id3, desc2, DialogModes.NO );
            // 3. Open files
            var fileList = inFolder.getFiles("2.psd"|"3.psd");
            // 4. Replace Text
            #target photoshop
            if (app.documents.length > 0) {
            for (var n = 0; n < app.documents.length; n++) {
            app.activeDocument = app.documents[n];
            app.activeDocument.suspendHistory("replace text", "main()")
            function main () {
            var myDocument = app.activeDocument;
            var theTexts = readPref ("C:/text-strings2.txt");
            var theArray1 = theTexts[0];
            var theArray2 = theTexts[1];
            for (var b = 0; b < theArray1.length; b++) {
            replaceText (theArray1[b], theArray2[b])
            function replaceText (replaceThis, replaceWith) {
            var idreplace = stringIDToTypeID( "replace" );
            var desc22 = new ActionDescriptor();
            var idnull = charIDToTypeID( "null" );
            var ref3 = new ActionReference();
            var idPrpr = charIDToTypeID( "Prpr" );
            ref3.putProperty( idPrpr, idreplace );
            var idTxLr = charIDToTypeID( "TxLr" );
            var idOrdn = charIDToTypeID( "Ordn" );
            var idAl = charIDToTypeID( "Al  " );
            ref3.putEnumerated( idTxLr, idOrdn, idAl );
            desc22.putReference( idnull, ref3 );
            var idUsng = charIDToTypeID( "Usng" );
            var desc23 = new ActionDescriptor();
            var idfind = stringIDToTypeID( "find" );
            desc23.putString( idfind, replaceThis );
            desc23.putString( idreplace, replaceWith );
            var idcheckAll = stringIDToTypeID( "checkAll" );
            desc23.putBoolean( idcheckAll, true );
            var idFwd = charIDToTypeID( "Fwd " );
            desc23.putBoolean( idFwd, false );
            var idcaseSensitive = stringIDToTypeID( "caseSensitive" );
            desc23.putBoolean( idcaseSensitive, true );
            var idwholeWord = stringIDToTypeID( "wholeWord" );
            desc23.putBoolean( idwholeWord, false );
            var idignoreAccents = stringIDToTypeID( "ignoreAccents" );
            desc23.putBoolean( idignoreAccents, false );
            var idfindReplace = stringIDToTypeID( "findReplace" );
            desc22.putObject( idUsng, idfindReplace, desc23 );
            executeAction( idreplace, desc22, DialogModes.NO );
            function readPref (thePath) {
            if (File(thePath).exists == true) {
            var file = File(thePath);
            file.open("r");
            var textArray = [];
            textArray.push(file.readln().split("|"));
            file.close();
            return textArray;
            // 5. Open files
            var fileList = inFolder.getFiles("4.psd"|"5.psd"|"6.psd"|"7.psd");
            • 3. Re: The order of running scripts in .jsx file
              What I really don't get is why script 5 triggers before the text replace scripts... Javascripts are not supposed to run in order?
              • 4. Re: The order of running scripts in .jsx file
                A Script can perform many tasks in sequence, but if its one jsx-file it’s one Script.
                And indeed JavaScript should perform in sequence.
                To observe what happen when you could include alerts or $-writeln (to get messages in the JavaScript Console) in the Script.
                • 5. Re: The order of running scripts in .jsx file
                  As in the past, thank you again! Will get on to that!
