0 Replies Latest reply on Mar 7, 2014 2:00 AM by MinalL
    Play AVI File from local filesystem location on button click event
    MinalL Level 1
      Hi All,
      We need to create a acroform PDF template which will contain a button. On click event of that button field we want to play AVI file which is present in local filesystem.
      Can someone suggest what approach should be followed to make this work?
      If same AVI file is attached to PDF and opened via dataobjects then it was played. But this approach has limitations of increase in PDF size and causing slow operations.
      I have tried following code
      var args =  {
             doc: this.document,
             rendition:  {
                      altText: "My Sample Earth Video alteranate text",
               doc: this.document,
               fileName: urlToBeOpened,
               type: app.media.renditionType.media,
               uiName: "My Sample Earth Video"
             URL: urlToBeOpened,
             mimeType: "video/avi",
             fromUser: true,
             showAltText: true,
             settings:  {
                 autoPlay: false,
                 data: app.media.getURLData(urlToBeOpened,"video/avi"),
                 windowType: app.media.windowType.floating,
                 floating:  {
                     align: app.media.align.topCenter,
                     over: app.media.over.appWindow,
                     canResize: app.media.canResize.no,
                     hasClose: true,
                     hasTitle: true,
                     title: "My Sample Earth Video Title",
                     ifOffScreen: app.media.ifOffScreen.forceOnScreen,
                     width: 400,
                     height: 300
                 layout: app.media.layout.meet,
                 monitor: app.monitors.primary(),
                 page: 0,
                 showUI: true,
                 visible: true
         var player = app.media.createPlayer(args);
         console.println("Called createPlayer");
         if(player)
          console.println("Returned Player object.");
          player.close(app.media.closeReason.general);
          var result = player.open(true, false);
          printPlayerProperties(player);
          console.println("called open");
          if(result.code != app.media.openCode.success)
           console.println("Error in opening player object");
           player = null;
           app.media.alert
           ("Open", args, { code: result.code });
          else if(player.visible)
           console.println("Opened Player successfully");
           player.setFocus(); // triggers Focus event
      But this code gives error
      app.media.priv.createPlayer
      Called createPlayer
      Exception in line 36773 of function anonymous, script
      Exception in line 36781 of function anonymous, script
      Exception in line 1319 of function anonymous, script Document-Level:Script1
      Exception in line 1 of function top_level, script AcroForm:OpenAVIFile:Annot1:MouseUp:Action1
      InvalidArgsError: Invalid arguments.
      MediaPlayer.privOpen:-1:AcroForm:OpenAVIFile:Annot1:MouseUp:Action1
      Any help in this regards will be greatly appreciated.
      thanks,
      Minal
