1 Reply Latest reply on Aug 7, 2006 5:17 AM by peterent
    Mouse Right Click Event
    Srihari_Ainumpudi Level 1
      I want to select a data row in DataGrid when i press mouse right button. I found that there is no event generated when i press mouse right button. Is there any alternative way to handle mouse right click in Flex.
      Help.....................
      --SriHari
        • 1. Re: Mouse Right Click Event
          peterent Level 2
          The right mouse click is devoted to the Context menu. It is either the one which contains "About Flash Player" or the edit context menu if you are over a text field.
          You can modify the context menu and add your own fields. If you are looking to switch left and right mouse button functions, use the operating system instead.
