1 Reply Latest reply on Mar 11, 2014 10:06 AM by c.pfaffenbichler
    scripting help needed!!
    jcpphotography
      i have a school photography shoot coming up soon each child will have 2 shots which need to be saved into a folder there are 200 children i would like to script this so the first 2files in a folder in sequence are saved or moved to folder 1 {or a choice of folder name} the next 2 shots in sequence into the next folder etc
      the folder ideally would be the name of the first image which would mean that i could rename the images in lightroom to a barcode type system for easy finding of the images later
      if this can be created for lightroom even better but i dont mind batch processing in photoshop
      any ideas?
        • 1. Re: scripting help needed!!
          c.pfaffenbichler Level 9
          Does this help (it messes up the date/s, though)?
          // thanks to michael l hale;
          // 2014, use at your own risk;
          var theFolder = Folder.selectDialog ("select folder");
          if (theFolder) {
          var theFiles = theFolder.getFiles(/\.(jpg|tif|eps|psd|png)$/i);
          theFiles.sort();
          var theNumber = theFiles.length;
          if (String(theNumber/2).indexOf(".") == -1) {
          for (var m = theNumber/2 - 1; m >= 0; m--) {
          var theImage = theFiles[m*2];
          var theImage2 = theFiles[m*2+1];
          var basename = theImage.name.match(/(.*)\.[^\.]+$/)[1];
          new Folder(theFolder.fullName+"/"+basename).create();
          var success = theImage.copy(theFolder.fullName+"/"+basename+"/"+theImage.name);
          if (success == true) {theImage.remove()};
          var success = theImage2.copy(theFolder.fullName+"/"+basename+"/"+theImage2.name);
          if (success == true) {theImage2.remove()};
