Problems with Premiere Elements 12
ColoradoGeorge Mar 8, 2014 6:11 AMI've been using Adobe's "Elements" applications since Vs 3.0. Each release seems to include undocumented features that cause problems, and don't get fixed until a next major release, for which we are charged a tidy sum.
"Premiere 12" and its associated "Organizer" are no exceptions. Background:
1. FINALLY am running a new PC considering I'm using AVCHD "m2ts" file formats generated by Sony HD Camcorder, for which previous PC and versions of Adobe Premiere Elements (8, 10, etc.) were fairly sluggish with their performance. New PC: Windows 8.1, 32GB RAM, >7TB HDD space, Intel i7 CPU, GIGABYTE MB, NVIDIA GeForec GTX 770 Video Adapter...plenty of computing power!
2. Installed Photoshop/Premiere Elements/Organizer on C: drive, default locations.
3. Experienced following problems, for which several have been kind enough to offer suggestions for repair, but none so far have worked.
a. When adding "text" captions, after a few have been created the control panel for text loses contact with the "Style" and "Effects" modules, making these capabilities non-functional.
b. When creating menus for discs, the DVD menu navigation operates correctly, but the Blu-ray menus do not. The "Stop" markers, while functional for DVDs, are not functional for Blu-ray discs. When a video is played that encounters a "stop" marker with a DVD build, the end action is properly realized with the main menu then making a reappearance, allowing one to make the next choice. When a video is played through to encounter a "stop" marker with a Blu-ray build, the video does NOT return to the main menu, but rather continues playing into the 2nd movie (or beyond) until it reaches the absolute end of content on the disc...at which time we are then returned to the main menu. Finally reading the manual, it indicates that this is a problem! FIX!?
c. "Organizer," which works with both Premiere and Photoshop Elements, is highly unstable when working with AVCHD files, while it performs "normally" with still images (photos, etc.). I have over 4,000 AVCHD (m2ts) video clips that I was attempting to bring into Organizer. My first attempt was to let Organizer "see" all of the files and to "bring them into" its catalog. However, after a short period of time, with less than 100 or so video clips identified and thumbnailed, Organizer either stops working and hangs, or crashes totally. I found that to get these 4,000 files into Organizer I had to manually pick around 50 or so files at a time, which Organizer seems able to begin its "first stage" of identifying, creates "placeholders" in the Organizer's screen, then crashes or hangs. At that point, I must restart Organizer, which will then continue on to successfully build thumbnails. This process was repeated until all 4,000+ files were recognized and ID'd. Regarding this issue: I just updated my "Nero" to "Nero 2014 Platinum," which comes with its own "Organizer" or "Media Manager." it is VERY similar in nature to Adobe's "Organizer," with one major difference...IT WORKS! Nero's manager imported not only the 4,000+ AVCHD files into its catalog, but rumaged around my entire system finding photos and video files I'd long since forgotten about! I've not yet used the new Nero video editing/production tools, but won't be surprized if I find that all works equally as well.
Not having any "fixes" for these problems, I find I am forced to use other applications (Vegas 12, Pinnacle 17, or perhaps now "Nero" as well) to get on with our production work. Note: I had been using Adobe Premiere 6.0, then CS-4, for a while but with changes in OSs found that these products as well evolved with issues of their own. Not going to spend the big bucks to purchase more expensive problems that don't otherwise get addressed without spending even more $$$ for the next major updates!
Help?
George
