4 Replies Latest reply on Dec 18, 2007 8:01 AM by SyddyS
    Fireworks not listed in Open With in Vista
      can't get jpgs to Associate with Fireworks CS3 in Vista - if i select "Choose Default Program" and browse to Fireworks.exe it still won't show up in the dialog. also doesn't appear in Open With in the Context menu...
      in the Default Programs option in Control Panel it's the same issue.
      Anybody?
        • 1. Re: Fireworks not listed in Open With in Vista
          rodeto
          Yes, I had that same problem.
          Note: I run CS3 on Windows Vista x64 and therefore the prgrams are placed in Program Files (x64)
          I made a textfile and put the following text in it:
          <code>
          Windows Registry Editor Version 5.00
          [HKEY_CLASSES_ROOT\*\shell]
          [HKEY_CLASSES_ROOT\*\shell\Open with Fireworks CS3]
          [HKEY_CLASSES_ROOT\*\shell\Open with Fireworks CS3\command]
          @=C:\Program Files (x86)\Adobe\Adobe Fireworks CS3\Fireworks.exe %1
          [HKEY_CLASSES_ROOT\*\shell\Open with Dreamweaver]
          [HKEY_CLASSES_ROOT\*\shell\Open with Dreamweaver\Command]
          @=C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS3\Dreamweaver.exe %1
          [HKEY_CLASSES_ROOT\*\shell\Open with Photoshop CS3]
          [HKEY_CLASSES_ROOT\*\shell\Open with Photoshop CS3\command]
          @=C:\Program Files (x86)\Adobe\Adobe Photoshop CS3\Photoshop.exe %1
          </code>
          Make sure you put in the proper map name for programs if needed.
          Save this file and rename the extension from .txt to .reg. Than double clik the reg file and your registry will be updated with the above info. After that you will find three more options in the context menu.
          Hope this helps.
          • 2. Re: Fireworks not listed in Open With in Vista
            Camilo-USA
            Hello
            I do this but I see information:
            "Registry Error
            Cannot import C:\fire.reg: The specified file is not a registry script.
            You can only import binary registry files from within the registry editor. "
            Pls Helo
            What to do now ??
            Gracias
            • 3. Re: Fireworks not listed in Open With in Vista
              Level 7
              Camilo-USA wrote:
              > Hello
              > "Registry Error
              This is a user to user forum, and that kind of question is usually
              beyond our knowledge level. Contact Adobe Customer Support.
              http://www.adobe.com/support/contact/
              Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
              http://www.projectseven.com
              Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
              CSS Newsgroup: news://forums.projectseven.com/css/
              http://www.adobe.com/communities/experts/
              • 4. Re: Fireworks not listed in Open With in Vista
                SyddyS
                Ran into the same problem on XP, and didn't find much in the way of answers here or elsewhere. However, I spent some time playing with rodeto's reg file and made it into an apparently XP friendly version. Hopefully this will help anyone else who runs into this issue!
                I don't know about Vista, but the trick for getting it to work in XP was adding the quotes around the path, and adding the double slash marks. Apparently a single slash is used for special characters like Tab and LF, so double slash means "Actual Single Slash" :) That and also changing the path to the appropriate XP Program Files location.
                Good luck to anyone else who has been annoyed by this CS3 weirdness!
                -SyddyS
