5 Replies Latest reply: Jul 5, 2014 12:13 PM by hope4555 RSS
    [Android] Getting onActivityResult and onStart/onPause/.... events from AIR activity [solution]
    Vrvy Community Member
      I struggled for a while with this issue and finally found a solution. I haven't seen it posted anywhere so I thought I would share it here.
      • In ANE extension's native java project, we include runtimeClasses.jar from AIR's lib folder (AIR\lib\android\lib), along with FlashRuntimeExtension.jar. This gives us access to AIR's AndroidActivityWrapper class.
      • Since some interfaces in runtimeClasses are defined as protected, we need to make them accessible to our extension. So we create two interfaces in com.adobe.air package namespace:
      ActivityResultCallback.java
      package com.adobe.air;
      import com.adobe.air.AndroidActivityWrapper;
      public abstract interface ActivityResultCallback extends AndroidActivityWrapper.ActivityResultCallback
      StateChangeCallback.java
      public abstract interface StateChangeCallback extends AndroidActivityWrapper.StateChangeCallback
      • We can now register some callbacks in our extension:
      ExtensionContext.java
      package com.company.extension;
      import java.util.HashMap;
      import java.util.Map;
      import android.content.Intent;
      import android.content.res.Configuration;
      import com.adobe.air.ActivityResultCallback;
      import com.adobe.air.AndroidActivityWrapper.ActivityState;
      import com.adobe.air.StateChangeCallback;
      import com.adobe.fre.FREContext;
      import com.adobe.fre.FREFunction;
      public class ExtensionContext extends FREContext implements ActivityResultCallback, StateChangeCallback
          private AndroidActivityWrapper aaw;
          public ExtensionContext() {
              aaw = AndroidActivityWrapper.GetAndroidActivityWrapper();
              aaw.addActivityResultListener( this );
              aaw.addActivityStateChangeListner( this );
          @Override
          public void onActivityResult(int requestCode, int resultCode, Intent intent ) {
          @Override
          public void onActivityStateChanged( ActivityState state ) {
              switch ( state ) {
                  case STARTED:
                  case RESTARTED:
                  case RESUMED:
                  case PAUSED:
                  case STOPPED:
                  case DESTROYED:
          @Override
          public void onConfigurationChanged(Configuration paramConfiguration) {
          @Override
          public Map<String, FREFunction> getFunctions() {
              Map<String, FREFunction> functionMap = new HashMap<String, FREFunction>();
              return functionMap;
          @Override
          public void dispose() {
              if (aaw!=null) {
                  aaw.removeActivityResultListener( this );
                  aaw.removeActivityStateChangeListner( this );
                  aaw = null;
      • I hope this helps anyone.
        • 1. Re: [Android] Getting onActivityResult and onStart/onPause/.... events from AIR activity [solution]
          NativeTroll
          Thanks !
          Looks very useful
          Though im having difficulty creating an ANE build which doesnt crash.
          Any advice on what kind of options you used to build the ANE ?
          • 2. Re: [Android] Getting onActivityResult and onStart/onPause/.... events from AIR activity [solution]
            Delcasda Community Member
            I just implemented this on a FREObject call to get result from an activity and works like charm. Thanks for the good stuff
            • 3. Re: [Android] Getting onActivityResult and onStart/onPause/.... events from AIR activity [solution]
              NativeTroll Community Member
              Sorry It worked great ! Some garbage was left inside my project.
              Thanks for Tip !
              • 4. Re: [Android] Getting onActivityResult and onStart/onPause/.... events from AIR activity [solution]
                Finally I had to remove onActivityOnResult implementation because in FB 4.7 the ANE worked fine on debug but I was not able to get in run on release version . I tried even adding the runtimeClasses.jar manually to the ANE package but it simply did not work. See below error from adb logcat
                I/NativeAlert(14030): initialize
                I/dalvikvm(14030): Failed resolving Lcom/adobe/air/ActivityResultCallback; interface 76 'Lcom/adobe/air/AndroidActivityWrapper$ActivityResultCallback;'
                W/dalvikvm(14030): Link of class 'Lcom/adobe/air/ActivityResultCallback;' failed
                I/dalvikvm(14030): Failed resolving Lcom/delcasda/contactsANEext/selectContacts; interface 75 'Lcom/adobe/air/ActivityResultCallback;'
                W/dalvikvm(14030): Link of class 'Lcom/delcasda/contactsANEext/selectContacts;' failed
                E/dalvikvm(14030): Could not find class 'com.delcasda.contactsANEext.selectContacts', referenced from method com.delcasda.contactsANEext.ContactANEContext.getFunctions
                W/dalvikvm(14030): VFY: unable to resolve new-instance 128 (Lcom/delcasda/contactsANEext/selectContacts;) in Lcom/delcasda/contactsANEext/ContactANEContext;
                D/dalvikvm(14030): VFY: replacing opcode 0x22 at 0x004d
                D/dalvikvm(14030): DexOpt: unable to opt direct call 0x01c1 at 0x4f in Lcom/delcasda/contactsANEext/ContactANEContext;.getFunctions
                W/System.err(14030): java.lang.NoClassDefFoundError: com.delcasda.contactsANEext.selectContacts
                W/System.err(14030):    at com.delcasda.contactsANEext.ContactANEContext.getFunctions(ContactANEContext.java:41)
                W/System.err(14030):    at com.adobe.fre.FREContext.VisitFunctions(FREContext.java:134)
                W/System.err(14030):    at com.adobe.air.customHandler.callTimeoutFunction(Native Method)
                W/System.err(14030):    at com.adobe.air.customHandler.handleMessage(customHandler.java:22)
                W/System.err(14030):    at android.os.Handler.dispatchMessage(Handler.java:99)
                W/System.err(14030):    at android.os.Looper.loop(Looper.java:137)
                W/System.err(14030):    at android.app.ActivityThread.main(ActivityThread.java:5455)
                W/System.err(14030):    at java.lang.reflect.Method.invokeNative(Native Method)
                W/System.err(14030):    at java.lang.reflect.Method.invoke(Method.java:525)
                W/System.err(14030):    at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1187)
                W/System.err(14030):    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1003)
                W/System.err(14030):    at dalvik.system.NativeStart.main(Native Method)
                • 5. Re: [Android] Getting onActivityResult and onStart/onPause/.... events from AIR activity [solution]
                  hope4555
                  This path was looking promising
                  But for me, the Application crash
                  Do i need to add this Jar manually?
