4 Replies Latest reply on Mar 12, 2014 12:30 AM by vinomannu
    Alert message need to be added?
    vinomannu
      Hi All,
      I need  to add alert message of number of unlock items in the following script.
      #target illustrator
      var myPageItems = myDoc.pageItems;
      var count = myPageItems.length;
      for ( var i = count-1; i >= 0; i-- ) {if ( ! myPageItems[i].locked){ myPageItems[i].selected = true; }
      {myPageItems[i].locked = false;{ myPageItems[i].selected = true;}}};
      this script unlock the items, but i need the information of lock items.
      Any help.
      Regards,
      Vinoth
        • 1. Re: Alert message need to be added?
          W_J_T Level 4
          So you want:
          - The ones that were locked, unlocked
          - An alert of how many were unlocked
          - Then have all page items selected
          If so, then how about this:
          var doc = app.activeDocument;
          var docPageItems = doc.pageItems;
          var unLockedCount = 0;
          for (var i = docPageItems.length - 1; i >= 0; i--) {
              pItem = docPageItems[i];
              if (pItem.locked == true) {
                  pItem.locked = false;
                  unLockedCount += 1;
              pItem.selected = true
          alert("Total Unlocked:\n" + unLockedCount);
          • 2. Re: Alert message need to be added?
            vinomannu Level 1
            Excellent, its working fine for me.
            Additonal help i requried the alert only if they are any unlocked elements in the images, now for all images i am getting the alert.
            Could this be solved.
            Regards,
            Vinoth
            • 3. Re: Alert message need to be added?
              W_J_T Level 4
              vinomannu wrote:
              i requried the alert only if they are any unlocked elements ... Could this be solved.
              Does this help, it will only alert if something locked was found.
              if (unLockedCount > 0) {
              Hope that is what you meant and helps.
              • 4. Re: Alert message need to be added?
                vinomannu Level 1
                Thanks for the update, it works.
