1 Reply Latest reply on Mar 10, 2014 11:27 AM by Hoverdog
    Flash Builder crashes when searching for .swc
    Hoverdog
      As the title states, anytime I use flash builder to open a finder dialog to search for files, Flash Builder crashes.
      I have uninstalled FB and reinstalled.
      I have changed my default finder to open to a different directory instead of seeing 'All my files'.
      I have updated to AIR 4.0.
      My crash log,
      Process:         Adobe Flash Builder 4.7 [896]
      Path:            /Applications/Adobe Flash Builder 4.7/Adobe Flash Builder 4.7.app/Contents/MacOS/Adobe Flash Builder 4.7
      Identifier:      org.eclipse.eclipse
      Version:         4.7 (4.7)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [157]
      Responsible:     Adobe Flash Builder 4.7 [896]
      User ID:         501
      Date/Time:       2014-03-10 13:19:33.102 -0500
      OS Version:      Mac OS X 10.9.2 (13C64)
      Report Version:  11
      Anonymous UUID:  BE47340D-BA2E-7583-A6D0-B478E98A447E
      Sleep/Wake UUID: 9631B369-82AA-4555-9434-B89C9FE05558
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: EXC_I386_GPFLT
      Application Specific Information:
      objc_msgSend() selector name: _surface
      Java information:
      Exception type: Bus Error (0xa) at pc=7fff9338a097
      Java VM: Java HotSpot(TM) 64-Bit Server VM (20.65-b04-462 mixed mode macosx-amd64)
      Current thread (107001000):  JavaThread "main" [_thread_in_native, id=1999016720, stack(7fff5f400000,7fff5fc00000)]
      Stack: [7fff5f400000,7fff5fc00000]
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      j  org.eclipse.swt.internal.cocoa.OS.objc_msgSend_bool(JJJJ)Z+0
      j  org.eclipse.swt.internal.cocoa.NSRunLoop.runMode(Lorg/eclipse/swt/internal/cocoa/NSString ;Lorg/eclipse/swt/internal/cocoa/NSDate;)Z+31
      j  org.eclipse.swt.widgets.Display.sleep()Z+36
      j  org.eclipse.jface.window.Window.runEventLoop(Lorg/eclipse/swt/widgets/Shell;)V+30
      j  org.eclipse.jface.window.Window.open()I+49
      j  com.adobe.flexbuilder.project.ui.utils.FlexClasspathControl$13.widgetSelected(Lorg/eclips e/swt/events/SelectionEvent;)V+387
      j  org.eclipse.swt.widgets.TypedListener.handleEvent(Lorg/eclipse/swt/widgets/Event;)V+1080
      J  org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/swt/widgets/Event;)V
      j  org.eclipse.swt.widgets.Display.sendEvent(Lorg/eclipse/swt/widgets/EventTable;Lorg/eclips e/swt/widgets/Event;)V+24
      j  org.eclipse.swt.widgets.Widget.sendEvent(Lorg/eclipse/swt/widgets/Event;)V+9
      j  org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/widgets/Event;Z)V+73
      j  org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/widgets/Event;)V+4
      j  org.eclipse.swt.widgets.Widget.notifyListeners(ILorg/eclipse/swt/widgets/Event;)V+19
      j  org.eclipse.swt.widgets.Display.runDeferredEvents()Z+96
      j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+125
      j  org.eclipse.jface.window.Window.runEventLoop(Lorg/eclipse/swt/widgets/Shell;)V+23
      j  com.adobe.flexbuilder.editors.derived.ui.navigator.FlexPackageExplorerPropertyDialogActio n.run()V+10
      j  org.eclipse.jface.action.Action.runWithEvent(Lorg/eclipse/swt/widgets/Event;)V+1
      j  org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(Lorg/eclipse/swt/wi dgets/Event;Z)V+354
      j  org.eclipse.jface.action.ActionContributionItem.access$2(Lorg/eclipse/jface/action/Action ContributionItem;Lorg/eclipse/swt/widgets/Event;Z)V+3
      j  org.eclipse.jface.action.ActionContributionItem$5.handleEvent(Lorg/eclipse/swt/widgets/Ev ent;)V+60
      j  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptio nHandler;Lorg/eclipse/swt/widgets/Display;)V+9
      j  org.eclipse.ui.internal.Workbench.runUI()I+555
      j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
      j  org.eclipse.ui.internal.Workbench$7.run()V+55
      j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
      j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
      j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
      j  com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(Lorg/eclipse/equinox/app/I ApplicationContext;)Ljava/lang/Object;+130
      j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
      v  ~StubRoutines::call_stub
      j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
      j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
      j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
      j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
      j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
      j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
      j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
      Java Threads: ( => current thread )
        118031800 JavaThread "com.apple.appkit-heartbeat" daemon [_thread_in_native, id=334688256, stack(113eaf000,113f2f000)]
        118241000 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=437968896, stack(11a0ae000,11a1ae000)]
        117997000 JavaThread "Java indexing" daemon [_thread_blocked, id=462426112, stack(11b801000,11b901000)]
        1179fc800 JavaThread "Worker-6" [_thread_blocked, id=392765440, stack(117592000,117692000)]
        110bf2000 JavaThread "Worker-4" [_thread_blocked, id=390643712, stack(11738c000,11748c000)]
        115864000 JavaThread "Worker-2" [_thread_blocked, id=324579328, stack(11348b000,11358b000)]
        11825a000 JavaThread "com.google.common.base.internal.Finalizer" daemon [_thread_blocked, id=334151680, stack(113dac000,113eac000)]
        1158be800 JavaThread "Thread-6" [_thread_in_native, id=332816384, stack(113c66000,113d66000)]
        115abf800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=331755520, stack(113b63000,113c63000)]
        110b19000 JavaThread "Worker-1" [_thread_blocked, id=317091840, stack(112d67000,112e67000)]
        110af4800 JavaThread "Worker-JM" [_thread_blocked, id=308166656, stack(1124e4000,1125e4000)]
        10b92f800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=307023872, stack(1123cd000,1124cd000)]
        110952000 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=302481408, stack(111f78000,112078000)]
        1070e7800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=301420544, stack(111e75000,111f75000)]
        10710e000 JavaThread "State Data Manager" daemon [_thread_blocked, id=300359680, stack(111d72000,111e72000)]
        10710d000 JavaThread "Framework Active Thread" [_thread_blocked, id=299298816, stack(111c6f000,111d6f000)]
        10781e000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=295735296, stack(111909000,111a09000)]
        107085000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=294674432, stack(111806000,111906000)]
        10b803000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=293613568, stack(111703000,111803000)]
        107084800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=292552704, stack(111600000,111700000)]
        107083800 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=291491840, stack(1114fd000,1115fd000)]
        110874000 JavaThread "Finalizer" daemon [_thread_blocked, id=290430976, stack(1113fa000,1114fa000)]
        107806800 JavaThread "Reference Handler" daemon [_thread_blocked, id=289370112, stack(1112f7000,1113f7000)]
      =>107001000 JavaThread "main" [_thread_in_native, id=1999016720, stack(7fff5f400000,7fff5fc00000)]
      Other Threads:
        10b802800 VMThread [stack: 1111f4000,1112f4000] [id=288309248]
        107097000 WatcherThread [stack: 111a0c000,111b0c000] [id=296796160]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      par new generation   total 64768K, used 7781K [7b0000000, 7b4640000, 7b5330000)
        eden space 57600K,  13% used [7b0000000, 7b07994e0, 7b3840000)
        from space 7168K,   0% used [7b3840000, 7b3840000, 7b3f40000)
        to   space 7168K,   0% used [7b3f40000, 7b3f40000, 7b4640000)
      concurrent mark-sweep generation total 503040K, used 25639K [7b5330000, 7d3e70000, 7f0000000)
      concurrent-mark-sweep perm gen total 117152K, used 70330K [7f0000000, 7f7268000, 800000000)
      Code Cache  [108101000, 108382000, 10b101000)
      total_blobs=1094 nmethods=569 adapters=486 free_code_cache=47813824 largest_free_block=36544
      Virtual Machine Arguments:
      JVM Args: -Xms512m -Xmx1024m -XX:MaxPermSize=256m -XX:PermSize=64m -Xdock:name=Flash Builder -Xdock:icon=../Resources/fb_app.icns -XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts -Declipse.product=com.adobe.flexbuilder.standalone.producte36 -Declipse.application=com.adobe.flexbuilder.standalone.FlashBuilderApplication -Dfile.encoding=UTF-8
      Java Command: <unknown>
      Launcher Type: generic
      Physical Memory: Page Size = 4k, Total = 8192M, Free = 3728M
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   libobjc.A.dylib                         0x00007fff9338a097 objc_msgSend + 23
      1   com.apple.AppKit                        0x00007fff8fee70a4 -[NSScrollView _isConcurrentScrollingCompatible] + 255
      2   com.apple.AppKit                        0x00007fff8fee6d83 -[NSScrollView _shouldUseInclusiveLayersAutomatically] + 75
      3   com.apple.AppKit                        0x00007fff8fee6cc8 -[NSScrollView _updateAutomaticInclusiveLayerSupport] + 71
      4   libdispatch.dylib                       0x00007fff92ea51d7 _dispatch_call_block_and_release + 12
      5   libdispatch.dylib                       0x00007fff92ea22ad _dispatch_client_callout + 8
      6   libdispatch.dylib                       0x00007fff92ea9f03 _dispatch_main_queue_callback_4CF + 333
      7   com.apple.CoreFoundation                0x00007fff8d368679 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9
      8   com.apple.CoreFoundation                0x00007fff8d323954 __CFRunLoopRun + 1636
      9   com.apple.CoreFoundation                0x00007fff8d3230b5 CFRunLoopRunSpecific + 309
      10  com.apple.Foundation                    0x00007fff89d05adc -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 253
      11  libswt-pi-cocoa-3738.jnilib             0x00000001122e9cab Java_org_eclipse_swt_internal_cocoa_OS_objc_1msgSend_1bool__JJJJ + 58
      12  ???                                     0x0000000108111eee 0 + 4430307054
      13  ???                                     0x0000000108106a82 0 + 4430260866
      14  ???                                     0x0000000108106a82 0 + 4430260866
      15  ???                                     0x0000000108106a82 0 + 4430260866
      16  ???                                     0x000000010810685a 0 + 4430260314
      17  ???                                     0x0000000108106e48 0 + 4430261832
      18  ???                                     0x0000000108106d34 0 + 4430261556
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0   libsystem_kernel.dylib                  0x00007fff8e9fe662 kevent64 + 10
      1   libdispatch.dylib                       0x00007fff92ea443d _dispatch_mgr_invoke + 239
      2   libdispatch.dylib                       0x00007fff92ea4152 _dispatch_mgr_thread + 52
      Thread 2:
      0   libsystem_kernel.dylib                  0x00007fff8e9fde6a __workq_kernreturn + 10
      1   libsystem_pthread.dylib                 0x00007fff8aa36f08 _pthread_wqthread + 330
      2   libsystem_pthread.dylib                 0x00007fff8aa39fb9 start_wqthread + 13
      Thread 3:: Java: Exception Handler Thread
      0   libsystem_kernel.dylib                  0x00007fff8e9f9a1a mach_msg_trap + 10
      1   libsystem_kernel.dylib                  0x00007fff8e9f8d18 mach_msg + 64
      2   libsystem_kernel.dylib                  0x00007fff8e9f9613 mach_msg_server + 544
      3   libclient64.dylib                       0x000000010646c2e5 0x106458000 + 82661
      4   libclient64.dylib                       0x000000010646c2a9 0x106458000 + 82601
      5   libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      6   libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      7   libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      8   libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 4:: Java: Gang worker#0 (Parallel GC Threads)
      2   libclient64.dylib                       0x0000000106517a43 0x106458000 + 784963
      3   libclient64.dylib                       0x000000010646b9a0 0x106458000 + 80288
      4   libclient64.dylib                       0x00000001065179ee 0x106458000 + 784878
      5   libclient64.dylib                       0x00000001065178fd 0x106458000 + 784637
      6   libclient64.dylib                       0x000000010646b5af 0x106458000 + 79279
      7   libclient64.dylib                       0x00000001068d2110 0x106458000 + 4694288
      8   libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      9   libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      10  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      11  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 5:: Java: Gang worker#1 (Parallel GC Threads)
      Thread 6:: Java: Gang worker#2 (Parallel GC Threads)
      Thread 7:: Java: Gang worker#3 (Parallel GC Threads)
      Thread 8:: Java: Concurrent Mark-Sweep GC Thread
      2   libclient64.dylib                       0x0000000106517ad5 0x106458000 + 785109
      3   libclient64.dylib                       0x000000010652d326 0x106458000 + 873254
      4   libclient64.dylib                       0x00000001065178fd 0x106458000 + 784637
      5   libclient64.dylib                       0x000000010646b5af 0x106458000 + 79279
      6   libclient64.dylib                       0x000000010675a617 0x106458000 + 3155479
      7   libclient64.dylib                       0x000000010675a8b5 0x106458000 + 3156149
      8   libclient64.dylib                       0x000000010675a4a5 0x106458000 + 3155109
      9   libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      10  libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      11  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      12  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 9:: Java: VM Thread
      6   libclient64.dylib                       0x00000001064edd24 0x106458000 + 613668
      7   libclient64.dylib                       0x00000001064eda57 0x106458000 + 612951
      Thread 10:: Java: Reference Handler
      4   libclient64.dylib                       0x000000010652d717 0x106458000 + 874263
      5   libclient64.dylib                       0x000000010652d466 0x106458000 + 873574
      6   libclient64.dylib                       0x00000001064fb6a3 JVM_MonitorWait + 156
      7   libjvmlinkage.dylib                     0x0000000100791b0b JVM_MonitorWait + 59
      8   ???                                     0x0000000108111eee 0 + 4430307054
      9   ???                                     0x000000010810685a 0 + 4430260314
      10  ???                                     0x000000010810685a 0 + 4430260314
      11  ???                                     0x0000000108101438 0 + 4430238776
      12  libclient64.dylib                       0x00000001064eeef4 0x106458000 + 618228
      13  libclient64.dylib                       0x00000001064fb22e 0x106458000 + 668206
      14  libclient64.dylib                       0x00000001064fb120 0x106458000 + 667936
      15  libclient64.dylib                       0x00000001064fb0c0 0x106458000 + 667840
      16  libclient64.dylib                       0x00000001064faf5e 0x106458000 + 667486
      17  libclient64.dylib                       0x00000001064fad6f 0x106458000 + 666991
      18  libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      19  libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      20  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      21  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 11:: Java: Finalizer
      10  ???                                     0x00000001081069b3 0 + 4430260659
      11  ???                                     0x00000001081069b3 0 + 4430260659
      12  ???                                     0x0000000108101438 0 + 4430238776
      13  libclient64.dylib                       0x00000001064eeef4 0x106458000 + 618228
      14  libclient64.dylib                       0x00000001064fb22e 0x106458000 + 668206
      15  libclient64.dylib                       0x00000001064fb120 0x106458000 + 667936
      16  libclient64.dylib                       0x00000001064fb0c0 0x106458000 + 667840
      17  libclient64.dylib                       0x00000001064faf5e 0x106458000 + 667486
      18  libclient64.dylib                       0x00000001064fad6f 0x106458000 + 666991
      19  libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      20  libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      21  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      22  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 12:: Java: Surrogate Locker Thread (Concurrent GC)
      6   libclient64.dylib                       0x000000010646b516 0x106458000 + 79126
      7   libclient64.dylib                       0x000000010674252b 0x106458000 + 3056939
      8   libclient64.dylib                       0x00000001064faf5e 0x106458000 + 667486
      9   libclient64.dylib                       0x00000001064fad6f 0x106458000 + 666991
      10  libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      11  libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      12  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      13  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 13:: Java: Signal Dispatcher
      0   libsystem_kernel.dylib                  0x00007fff8e9f9a56 semaphore_wait_trap + 10
      1   libclient64.dylib                       0x000000010650b803 0x106458000 + 735235
      2   libclient64.dylib                       0x000000010650b2d0 0x106458000 + 733904
      3   libclient64.dylib                       0x00000001064faf5e 0x106458000 + 667486
      4   libclient64.dylib                       0x00000001064fad6f 0x106458000 + 666991
      Thread 14:: Java: C2 CompilerThread0
      7   libclient64.dylib                       0x0000000106511865 0x106458000 + 759909
      8   libclient64.dylib                       0x000000010650c64f 0x106458000 + 738895
      9   libclient64.dylib                       0x00000001064faf5e 0x106458000 + 667486
      10  libclient64.dylib                       0x00000001064fad6f 0x106458000 + 666991
      11  libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      12  libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      13  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      14  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 15:: Java: C2 CompilerThread1
      Thread 16:: Java: Low Memory Detector
      7   libclient64.dylib                       0x000000010650f03e 0x106458000 + 749630
      Thread 17:: Java: VM Periodic Task Thread
      4   libclient64.dylib                       0x0000000106510c20 0x106458000 + 756768
      Thread 18:: Java: Framework Active Thread
      4   libclient64.dylib                       0x000000010652d721 0x106458000 + 874273
      10  ???                                     0x0000000108106d34 0 + 4430261556
      Thread 19:: Java: State Data Manager
      3   libclient64.dylib                       0x0000000106661142 0x106458000 + 2134338
      4   libclient64.dylib                       0x000000010660f06c JVM_Sleep + 191
      5   libjvmlinkage.dylib                     0x000000010079265e JVM_Sleep + 62
      6   ???                                     0x0000000108111eee 0 + 4430307054
      7   ???                                     0x000000010810685a 0 + 4430260314
      9   ???                                     0x0000000108101438 0 + 4430238776
      10  libclient64.dylib                       0x00000001064eeef4 0x106458000 + 618228
      11  libclient64.dylib                       0x00000001064fb22e 0x106458000 + 668206
      12  libclient64.dylib                       0x00000001064fb120 0x106458000 + 667936
      13  libclient64.dylib                       0x00000001064fb0c0 0x106458000 + 667840
      14  libclient64.dylib                       0x00000001064faf5e 0x106458000 + 667486
      15  libclient64.dylib                       0x00000001064fad6f 0x106458000 + 666991
      16  libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      17  libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      18  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      19  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 20:: Java: Start Level Event Dispatcher
      Thread 21:: Java: Framework Event Dispatcher
      Thread 22:: Java: [Timer] - Main Queue Handler
      Thread 23:: Java: Worker-JM
      10  ???                                     0x0000000108101438 0 + 4430238776
      11  libclient64.dylib                       0x00000001064eeef4 0x106458000 + 618228
      12  libclient64.dylib                       0x00000001064fb22e 0x106458000 + 668206
      13  libclient64.dylib                       0x00000001064fb120 0x106458000 + 667936
      14  libclient64.dylib                       0x00000001064fb0c0 0x106458000 + 667840
      15  libclient64.dylib                       0x00000001064faf5e 0x106458000 + 667486
      16  libclient64.dylib                       0x00000001064fad6f 0x106458000 + 666991
      17  libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      18  libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      19  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      20  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 24:: Java: Worker-1
      Thread 25:
      2   com.apple.CoreFoundation                0x00007fff8d324155 __CFRunLoopServiceMachPort + 181
      3   com.apple.CoreFoundation                0x00007fff8d323779 __CFRunLoopRun + 1161
      4   com.apple.CoreFoundation                0x00007fff8d3230b5 CFRunLoopRunSpecific + 309
      5   com.apple.AppKit                        0x00007fff8ff3a16e _NSEventThread + 144
      Thread 26:: Java: Bundle File Closer
      Thread 27:
      0   libsystem_kernel.dylib                  0x00007fff8e9fda3a __semwait_signal + 10
      1   libsystem_c.dylib                       0x00007fff86e7fdc0 nanosleep + 200
      2   libBridgeTalk.jnilib                    0x0000000112ec904b ScObjects::Thread::sleep(unsigned int) + 59
      3   libBridgeTalk.jnilib                    0x0000000112ec38e3 ScObjects::BridgeTalkThread::run() + 163
      4   libBridgeTalk.jnilib                    0x0000000112ec9146 ScObjects::Thread::go(void*) + 166
      5   libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      6   libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      7   libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 28:: Java: Thread-6
      2   libBridgeTalk.jnilib                    0x0000000112ead126 mysleep(unsigned long) + 70
      3   libBridgeTalk.jnilib                    0x0000000112ead9ea Java_com_adobe_flexide_nativelibs_BridgeTalk_WaitForMessages + 106
      4   ???                                     0x0000000108111eee 0 + 4430307054
      5   ???                                     0x000000010810685a 0 + 4430260314
      6   ???                                     0x0000000108101438 0 + 4430238776
      7   libclient64.dylib                       0x00000001064eeef4 0x106458000 + 618228
      8   libclient64.dylib                       0x00000001064fb22e 0x106458000 + 668206
      9   libclient64.dylib                       0x00000001064fb120 0x106458000 + 667936
      10  libclient64.dylib                       0x00000001064fb0c0 0x106458000 + 667840
      11  libclient64.dylib                       0x00000001064faf5e 0x106458000 + 667486
      12  libclient64.dylib                       0x00000001064fad6f 0x106458000 + 666991
      13  libclient64.dylib                       0x000000010646b41a 0x106458000 + 78874
      14  libsystem_pthread.dylib                 0x00007fff8aa35899 _pthread_body + 138
      15  libsystem_pthread.dylib                 0x00007fff8aa3572a _pthread_start + 137
      16  libsystem_pthread.dylib                 0x00007fff8aa39fc9 thread_start + 13
      Thread 29:: Java: com.google.common.base.internal.Finalizer
      Thread 30:: com.apple.NSURLConnectionLoader
      5   com.apple.Foundation                    0x00007fff89d03967 +[NSURLConnection(Loader) _resourceLoadLoop:] + 348
      6   com.apple.Foundation                    0x00007fff89d0376b __NSThread__main__ + 1318
      Thread 31:: JavaScriptCore::BlockFree
      0   libsystem_kernel.dylib                  0x00007fff8e9fd716 __psynch_cvwait + 10
      1   libsystem_pthread.dylib                 0x00007fff8aa37c3b _pthread_cond_wait + 727
      2   com.apple.JavaScriptCore                0x00007fff8db099c5 JSC::BlockAllocator::blockFreeingThreadMain() + 261
      3   com.apple.JavaScriptCore                0x00007fff8dafec5f WTF::wtfThreadEntryPoint(void*) + 15
      Thread 32:: JavaScriptCore::Marking
      2   com.apple.JavaScriptCore                0x00007fff8db0a437 JSC::GCThread::waitForNextPhase() + 119
      3   com.apple.JavaScriptCore                0x00007fff8db0a2c8 JSC::GCThread::gcThreadMain() + 88
      4   com.apple.JavaScriptCore                0x00007fff8dafec5f WTF::wtfThreadEntryPoint(void*) + 15
      Thread 33:: JavaScriptCore::Marking
      Thread 34:: JavaScriptCore::Marking
      Thread 35:: Java: Worker-2
      Thread 36:: Java: Worker-4
      Thread 37:: Java: Worker-6
      Thread 38:: Java: Java indexing
      11  ???                                     0x0000000108106d34 0 + 4430261556
      Thread 39:: Java: [ThreadPool Manager] - Idle Thread
      Thread 40:: CVDisplayLink
      1   libsystem_pthread.dylib                 0x00007fff8aa37c77 _pthread_cond_wait + 787
      2   com.apple.CoreVideo                     0x00007fff87fab464 CVDisplayLink::waitUntil(unsigned long long) + 244
      3   com.apple.CoreVideo                     0x00007fff87faa998 CVDisplayLink::runIOThread() + 496
      4   com.apple.CoreVideo                     0x00007fff87faa78f startIOThread(void*) + 147
      Thread 41:
      Thread 42:
      Thread 43:
      Thread 44:
      Thread 45:
      Thread 46:: com.apple.appkit-heartbeat
      2   com.apple.CoreGraphics                  0x00007fff91963a1b _CGSSynchronizeWindowBackingStore + 97
      3   com.apple.CoreGraphics                  0x00007fff918e5830 _CGSLockWindow + 3765
      4   com.apple.CoreGraphics                  0x00007fff918e4743 CGSDeviceLock + 240
      5   libRIP.A.dylib                          0x00007fff872a4487 ripd_Lock + 43
      6   libRIP.A.dylib                          0x00007fff872aa9b4 RIPLayerBltImage + 296
      7   libRIP.A.dylib                          0x00007fff872aa6aa ripc_RenderImage + 262
      8   libRIP.A.dylib                          0x00007fff872b7efb ripc_EndLayer + 1295
      9   com.apple.CoreGraphics                  0x00007fff919431b5 CGContextEndTransparencyLayer + 53
      10  com.apple.AppKit                        0x00007fff900f315f -[NSButtonCell(NSDefaultButtonIndicatorPrivate) heartBeat:] + 2937
      11  com.apple.AppKit                        0x00007fff900f2545 -[NSWindow(NSWindow_Theme) heartBeat:] + 300
      12  com.apple.AppKit                        0x00007fff8fffdd2d -[NSUIHeartBeat _heartBeatThread:] + 868
      13  com.apple.Foundation                    0x00007fff89d0376b __NSThread__main__ + 1318
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x00000001003f5eb0  rbx: 0x00000001003f6710  rcx: 0x00007fff905cc600  rdx: 0x0000000000000000
        rdi: 0x00000001003f5eb0  rsi: 0x00007fff907e8b43  rbp: 0x00007fff5fbfc6c0  rsp: 0x00007fff5fbfc698
         r8: 0x0000000000000001   r9: 0x0000000000000001  r10: 0x00007fff907e8b43  r11: 0xd000000000000000
        r12: 0x00007fff77efbdd0  r13: 0x0000600000c71300  r14: 0x00000001003f5eb0  r15: 0x00007fff9338a080
        rip: 0x00007fff9338a097  rfl: 0x0000000000010246  cr2: 0x0000608000a7e000
      Logical CPU:     3
      Error Code:      0x00000000
      Trap Number:     13
      Binary Images:
             0x100000000 -        0x100003fff +org.eclipse.eclipse (4.7 - 4.7) <951E0416-90C6-C3B4-C42F-C4611750F7CD> /Applications/Adobe Flash Builder 4.7/Adobe Flash Builder 4.7.app/Contents/MacOS/Adobe Flash Builder 4.7
             0x1000dc000 -        0x1000e5fff +eclipse_1406.so (???) <76031737-38EC-3667-20AA-A98F3CC7E516> /Applications/Adobe Flash Builder 4.7/*/eclipse_1406.so
             0x10040a000 -        0x10040aff3 +cl_kernels (???) <296B819E-5023-4F6F-A73C-5D4279D72622> cl_kernels
             0x100419000 -        0x10041afeb +cl_kernels (???) <559796CE-ECF1-441B-96A9-DB436023CDCC> cl_kernels
             0x10041f000 -        0x100420ffa +cl_kernels (???) <AD0BE70A-A058-46DB-AE22-C285FD184745> cl_kernels
             0x100425000 -        0x100426fe6 +cl_kernels (???) <66D31A2D-3198-42E6-AE21-7E9774734664> cl_kernels
             0x100428000 -        0x100443ff9  com.apple.security.csparser (3.0 - 55471.14) <5D9AC0E2-2F0D-3D39-9991-DF2C1D4DD0CF> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
             0x10045b000 -        0x10045ffff  com.apple.qldisplay.Generic (5.0 - 622.7) <F9ED257D-2C3B-3738-AC0A-4031D5A17617> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/PlugIns/Generic.qldisplay/Contents/MacOS/Generic
             0x100778000 -        0x10077dfff  com.apple.JavaVM (14.9.0 - 14.9.0) <67BD63C5-D82F-3A31-BC43-C8810356D524> /System/Library/Frameworks/JavaVM.framework/JavaVM
             0x100785000 -        0x10078afff  JavaLaunching (1) <528DEA76-B869-36B5-87A6-D9B722968E16> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
             0x100791000 -        0x100798fff  libjvmlinkage.dylib (1) <B9B0CF65-39C3-3727-88B1-4F5F51AC9A21> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
             0x1007cf000 -        0x1007d7ff7  libverify.dylib (1.0 - 1.0) <5D7B9277-8506-3DFC-8A9E-D45E14C5E8CC> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
             0x1007dd000 -        0x1007e7fff  JavaNativeFoundation (1) <10006281-5A71-3A5E-BEC6-22F7BB31CF81> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
             0x104037000 -        0x104040ff7  com.apple.java.JavaRuntimeSupport (14.9.0 - 14.9.0) <AB4F1817-A2DE-36F2-8052-3CD334906F79> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.fram ework/Versions/A/JavaRuntimeSupport
             0x10404f000 -        0x10405cff7  libzip.jnilib (1) <F65FA31B-53CC-31CD-BE0F-F29EF7E39E47> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
             0x106458000 -        0x106a8bfff  libclient64.dylib (1) <8E334318-9E23-3E43-A51C-5878CCED301D> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libclie nt64.dylib
             0x106b5c000 -        0x106b7cfff  libjava.jnilib (1) <3AE5B8B7-766A-379F-8DB8-4F177F86623D> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
             0x110632000 -        0x110633fff +libunixfile_1_0_0.jnilib (???) /Users/USER/Documents/*/libunixfile_1_0_0.jnilib
             0x110649000 -        0x11064aff7 +libAMT_JNILib.jnilib (1) <9EF76F98-E44E-D705-C1B7-9802AF2BA8AD> /Applications/Adobe Flash Builder 4.7/*/libAMT_JNILib.jnilib
             0x11064e000 -        0x110651fff +libCrashReporterJNI.jnilib (1) <BB4FCF56-131F-830D-7452-BA535FBED5D9> /Applications/Adobe Flash Builder 4.7/*/libCrashReporterJNI.jnilib
             0x111b32000 -        0x111b32feb +cl_kernels (???) <056FC6A2-7F0B-436D-B31B-E13EE9E52EF9> cl_kernels
             0x111bac000 -        0x111badff9 +cl_kernels (???) <482506C9-D26E-460B-A6B3-7ADB0A263178> cl_kernels
             0x111c24000 -        0x111c24ff6 +cl_kernels (???) <85079E42-8431-4E43-8D75-ADA22A720827> cl_kernels
             0x111c34000 -        0x111c35fe2 +cl_kernels (???) <8D24E763-D48C-440B-BD2D-AE6AD1BE7B2D> cl_kernels
             0x111c51000 -        0x111c5efff  libnet.jnilib (1) <963FE51E-A35C-3F6F-BE1F-B48587382AB1> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libnet.jnilib
             0x111c64000 -        0x111c68fff  libnio.jnilib (1) <D55E350A-E8E4-3B36-8696-C03D3CB42D32> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libnio.jnilib
             0x1120fa000 -        0x1120fafe7 +cl_kernels (???) <AE1357EC-2E77-4E53-AB68-00D9238C8A87> cl_kernels
             0x112130000 -        0x112130ff7 +libJNIToNativeBridge.jnilib (1) <AF8C8EBB-93A4-5A86-5B92-202C576B0ACE> /Applications/Adobe Flash Builder 4.7/*/libJNIToNativeBridge.jnilib
             0x11213e000 -        0x11213ffef +cl_kernels (???) <88F7BE28-D3E2-459A-BC58-7571AF35B48F> cl_kernels
             0x1121ac000 -        0x1121adfee +cl_kernels (???) <CCF298BA-F234-4880-A61F-3F15382A28A7> cl_kernels
             0x112241000 -        0x112242ffa +cl_kernels (???) <CC353DC2-6BA2-4B41-900F-4DFEF69393A1> cl_kernels
             0x112258000 -        0x112258fec +cl_kernels (???) <3B293B5F-BFBF-4A58-A924-D74E8C3C6190> cl_kernels
             0x112287000 -        0x1122c0fff +libswt-cocoa-3738.jnilib (???) <BFDF4C6B-E2EC-1B0E-CEFA-D970BFE6A3EC> /Users/USER/Documents/*/libswt-cocoa-3738.jnilib
             0x1122d4000 -        0x1122fafff +libswt-pi-cocoa-3738.jnilib (???) <3D96EB35-A45B-A4BB-D784-954355811400> /Users/USER/Documents/*/libswt-pi-cocoa-3738.jnilib
             0x1123b5000 -        0x1123b5fff +cl_kernels (???) <6F81BD18-D453-41FE-A808-331032BE8F77> cl_kernels
             0x112eac000 -        0x112eeaff7 +libBridgeTalk.jnilib (1) <DEA9795A-B528-B126-A71D-0151FFE13271> /Applications/Adobe Flash Builder 4.7/*/libBridgeTalk.jnilib
             0x1133e2000 -        0x11345bfef +com.adobe.adobe_caps (adobe_caps 5.0.11.0 - 5.0.11.0) <24C4F136-9D5E-C3E3-9C10-B4AE0865A9AA> /Applications/Adobe Flash Builder 4.7/*/adobe_caps.framework/adobe_caps
             0x11346a000 -        0x113470fff +libHeadlights.jnilib (1) <71454B51-1569-45E3-5548-0F4A853DEBEA> /Applications/Adobe Flash Builder 4.7/*/libHeadlights.jnilib
             0x113475000 -        0x113479fff  com.apple.agl (3.2.3 - AGL-3.2.3) <E0ED4789-9DBC-3C88-95F7-CA79E196B4BE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x113480000 -        0x113484ff7 +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120720) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Flash Builder 4.7/*/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x1153df000 -        0x1154c3fe7 +com.adobe.amtlib (amtlib 6.0.0.75 - 6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe Flash Builder 4.7/*/amtlib.framework/Versions/A/amtlib
             0x115557000 -        0x11559dfff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Flash Builder 4.7/*/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
             0x1155b7000 -        0x11560ffeb +com.adobe.headlights.LogSessionFramework (2.1.2.1263) <3CCEC733-BC2D-63D5-7DD6-FA2616C67B9E> /Applications/Adobe Flash Builder 4.7/*/LogSession.framework/Versions/A/LogSession
             0x116000000 -        0x116042fef +com.adobe.pip (5.5.0.1265) <D81C0CE8-05D5-6072-E1CE-0EDD333D009D> /Applications/Adobe Flash Builder 4.7/*/AdobePIP.framework/AdobePIP
             0x1170f7000 -        0x1171ddfef  unorm8_bgra.dylib (2.3.58) <6E7397EF-CC78-3C15-8B21-05E7FB47F645> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
             0x11eb06000 -        0x11ebebfe7  unorm8_argb.dylib (2.3.58) <756ECD49-7245-38FA-81F5-79F614156A6C> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_argb .dylib
          0x123400000000 -     0x123400435ff7  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (8.24.11 - 8.2.4) <8A2F184C-3855-3597-9EB5-49DB5A9B81F8> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD5000GraphicsGLDriver
          0x7fff657af000 -     0x7fff657e2817  dyld (239.4) <2B17750C-ED1B-3060-B64E-21897D08B28B> /usr/lib/dyld
          0x7fff866c5000 -     0x7fff86717ff7  com.apple.Suggestions (3.0 - 137.1) <163A32DE-1E1D-3EBB-9F20-CF64774CF5A6> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
          0x7fff86718000 -     0x7fff8671bffc  com.apple.IOSurface (91 - 91) <812F4D48-6FD4-3DCB-8691-B077EBF981D7> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff86729000 -     0x7fff8673aff7  libsystem_asl.dylib (217.1.4) <B983CA60-F418-317B-B142-48A6376564FC> /usr/lib/system/libsystem_asl.dylib
          0x7fff8673b000 -     0x7fff8688eff7  com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <3511ABFE-22E1-3B91-B86A-5E3A78CE33FD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff86dbc000 -     0x7fff86e03fff  libFontRegistry.dylib (127) <A77A0480-AA5D-3CC8-8B68-69985CD546DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fff86e04000 -     0x7fff86e8dff7  libsystem_c.dylib (997.90.3) <6FD3A400-4BB2-3B95-B90C-BE6E9D0D78FA> /usr/lib/system/libsystem_c.dylib
          0x7fff86e8e000 -     0x7fff86e93fff  libmacho.dylib (845) <B2BE3C25-CF1F-309B-AB99-1F0B54621445> /usr/lib/system/libmacho.dylib
          0x7fff86ed5000 -     0x7fff86edefff  com.apple.DisplayServicesFW (2.8 - 360.8.14) <ABEE3950-3024-3741-AD4F-CC405EBEE89E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fff86edf000 -     0x7fff86edffff  com.apple.CoreServices (59 - 59) <67A369BA-2326-383F-995B-853DAD7BFF43> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff86f75000 -     0x7fff86f7cff3  libcopyfile.dylib (103) <6453487A-EDA5-353C-8351-1AABB3C7777C> /usr/lib/system/libcopyfile.dylib
          0x7fff86f7d000 -     0x7fff86fcbfff  libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
          0x7fff86fe4000 -     0x7fff87047ff7  com.apple.SystemConfiguration (1.13 - 1.13) <63B985ED-E7E4-3095-8D12-63C9F1DB0F3D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff87048000 -     0x7fff87096fff  com.apple.opencl (2.3.59 - 2.3.59) <8C2ACCC6-B0BA-3FE7-98A1-5C67284DEA4E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff87097000 -     0x7fff870cbfff  libssl.0.9.8.dylib (50) <B15F967C-B002-36C2-9621-3456D8509F50> /usr/lib/libssl.0.9.8.dylib
          0x7fff870df000 -     0x7fff871cdfff  libJP2.dylib (1042) <01D988D4-E36F-3120-8BA4-EF6282ECB010> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
          0x7fff871ce000 -     0x7fff871fbff2  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <9F8AC160-145F-3B35-954F-655AAEC05356> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
          0x7fff871fc000 -     0x7fff87220fff  libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib
          0x7fff87230000 -     0x7fff8725cff7  com.apple.framework.SystemAdministration (1.0 - 1.0) <6FD03EF6-32B6-397D-B9D7-D68E89A462F5> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
          0x7fff8725d000 -     0x7fff8729bff7  libGLImage.dylib (9.6) <DCF2E131-A65E-33B2-B32D-28FF01605AB1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff8729c000 -     0x7fff872c4ffb  libRIP.A.dylib (599.20.11) <D79461A6-2E24-3531-ADA2-EAC972384A7D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff872c5000 -     0x7fff872c7fff  libRadiance.dylib (1042) <B91D4B97-7BF3-3285-BCB7-4948BAAC23EE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
          0x7fff872c8000 -     0x7fff872cafff  com.apple.EFILogin (2.0 - 2) <84014F35-7E0E-3270-819A-48ECCADA687E> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
          0x7fff872cb000 -     0x7fff8762bff7  com.apple.FinderKit (1.2.2 - 1.2.2) <DDFA6886-82DC-32F4-BC8F-09BFD8EB5B85> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
          0x7fff8762c000 -     0x7fff87637fff  libkxld.dylib (2422.90.20) <EF476345-7A69-3AC0-95ED-0196FB8910CB> /usr/lib/system/libkxld.dylib
          0x7fff87638000 -     0x7fff8763ffff  libcompiler_rt.dylib (35) <2A890004-0A78-3E33-9AC5-A7D63BD4F879> /usr/lib/system/libcompiler_rt.dylib
          0x7fff876a3000 -     0x7fff876caffb  libsystem_info.dylib (449.1.3) <395D8CD6-616A-3BD3-A195-C6D68EB9AB22> /usr/lib/system/libsystem_info.dylib
          0x7fff876cb000 -     0x7fff876cbfff  com.apple.Accelerate (1.9 - Accelerate 1.9) <CFEF9CBE-4A1A-33FD-9174-D44314BB28F3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff876cc000 -     0x7fff8792dfff  com.apple.imageKit (2.5 - 774) <AACDE16E-ED9F-3B3F-A792-69BA1942753B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fff8792e000 -     0x7fff87936fff  libMatch.1.dylib (19) <021293AB-407D-309A-87F5-8E782F46753E> /usr/lib/libMatch.1.dylib
          0x7fff87937000 -     0x7fff87e5afff  com.apple.QuartzComposer (5.1 - 319) <8B90921F-911B-3240-A1D5-3C084F3E6A36> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fff87e5b000 -     0x7fff87e65ff7  com.apple.AppSandbox (3.0 - 1) <9F27DC25-C566-3AEF-92D3-DCFE7836916D> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
          0x7fff87e66000 -     0x7fff87e66fff  com.apple.Cocoa (6.8 - 20) <1482E95B-0C26-38AF-9A44-50ADE6C0876C> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff87efa000 -     0x7fff87f46ffe  com.apple.CoreMediaIO (407.0 - 4561) <BC8222A6-516C-380C-AB7D-DE78B23574DC> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
          0x7fff87f47000 -     0x7fff87f4afff  com.apple.TCC (1.0 - 1) <F25B5875-081A-3877-B70E-374D54B54C5F> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
          0x7fff87f4b000 -     0x7fff87f54ffb  com.apple.CommonAuth (4.0 - 2.0) <70FDDA03-7B44-37EC-B78E-3EC3C8505C76> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
          0x7fff87fa3000 -     0x7fff87fa6ff7  libdyld.dylib (239.4) <CF03004F-58E4-3BB6-B3FD-BE4E05F128A0> /usr/lib/system/libdyld.dylib
          0x7fff87fa7000 -     0x7fff87fa8fff  libunc.dylib (28) <C3737C9A-C06F-310C-B78C-7D8D882A35DE> /usr/lib/system/libunc.dylib
          0x7fff87fa9000 -     0x7fff87fceff7  com.apple.CoreVideo (1.8 - 117.2) <FE12553A-9B5A-337E-92BD-EA8A8194C91A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff87fcf000 -     0x7fff8806cfff  com.apple.imcore (10.0 - 1000) <DF924E35-74AB-389C-9279-1828518218F8> /System/Library/PrivateFrameworks/IMCore.framework/Versions/A/IMCore
          0x7fff8806d000 -     0x7fff88154ff7  libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
          0x7fff88155000 -     0x7fff881acfff  com.apple.ViewBridge (1.0 - 46.2) <4AF3CB98-7691-39A2-8DC3-ABE5CC55CE7F> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
          0x7fff881ad000 -     0x7fff881aeff7  libsystem_sandbox.dylib (278.11) <5E5A6E09-33A9-391A-AB34-E57D93BB1551> /usr/lib/system/libsystem_sandbox.dylib
          0x7fff881af000 -     0x7fff882a0ff9  libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib
          0x7fff882a1000 -     0x7fff882f2ff3  com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <EAC1821B-CD20-30E3-BF95-C1839CA97BF7> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff886cf000 -     0x7fff886d3fff  com.apple.IOAccelerator (98.14 - 98.14) <13EE735B-BD43-3E9B-9908-E423A17C4517> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
          0x7fff886d4000 -     0x7fff886dcff3  libCGCMS.A.dylib (599.20.11) <BB1E8D63-9FA1-3588-AC5D-1980576ED62C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
          0x7fff886dd000 -     0x7fff886deffb  libremovefile.dylib (33) <26266E3F-FDDC-3CFC-B27F-78B49BDC9BDC> /usr/lib/system/libremovefile.dylib
          0x7fff886df000 -     0x7fff88b12ffb  com.apple.vision.FaceCore (3.0.0 - 3.0.0) <30FD8146-D6EB-3588-A7E5-ADC3110B3DCC> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
          0x7fff88b13000 -     0x7fff88b15ff7  com.apple.diagnosticlogcollection (10.0 - 1000) <91AB5132-38E3-3976-8B54-D2E9A079D955> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/Diagnostic LogCollection
          0x7fff88b16000 -     0x7fff88b1bff7  libunwind.dylib (35.3) <95D4D118-3368-3474-989D-271DE18C8365> /usr/lib/system/libunwind.dylib
          0x7fff88b1c000 -     0x7fff88ba5fff  com.apple.ColorSync (4.9.0 - 4.9.0) <E7E0D542-D77A-3E32-B146-4D0FEAF282D3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff88ba6000 -     0x7fff88bcfff7  libc++abi.dylib (49.1) <21A807D3-6732-3455-B77F-743E9F916DF0> /usr/lib/libc++abi.dylib
          0x7fff88bd0000 -     0x7fff88d5dff7  GLEngine (9.6) <51D58F76-B9B3-3B4F-B65A-F6D213C2EED7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
          0x7fff88d5e000 -     0x7fff88d64fff  com.apple.AddressBook.ContactsFoundation (8.0 - 1369) <A5D1D494-2F84-3A97-A229-04DB308D4481> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
          0x7fff88d65000 -     0x7fff88d96fff  com.apple.MediaKit (15 - 709) <4AC5B9D8-7204-3CF2-AB58-69EFCDD964FC> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
          0x7fff88db1000 -     0x7fff88e24fff  com.apple.securityfoundation (6.0 - 55122.1) <1939DE0B-BC38-3E50-8A8C-3471C8AC4CD6> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff88e25000 -     0x7fff88e27ff7  com.apple.securityhi (9.0 - 55005) <405E2BC6-2B6F-3B6B-B48E-2FD39214F052> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff88e28000 -     0x7fff88e28ffd  libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
          0x7fff88e5d000 -     0x7fff88fcbff7  libBLAS.dylib (1094.5) <D862E2B7-91FA-3704-8F62-C1B65D381A84> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff88fcc000 -     0x7fff88fcefff  com.apple.Mangrove (1.0 - 1) <E588D4DE-2498-33EE-9227-8773DB65767F> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
          0x7fff89368000 -     0x7fff89452fff  libsqlite3.dylib (158) <447AA928-BCF7-3779-A7E5-210F264E0316> /usr/lib/libsqlite3.dylib
          0x7fff89453000 -     0x7fff89467fff  com.apple.aps.framework (4.0 - 4.0) <23BC5746-0914-3102-B84F-BEAB31A77AEC> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
          0x7fff8948b000 -     0x7fff89496ff7  com.apple.DirectoryService.Framework (10.9 - 173.90.1) <A9866D67-C5A8-36D1-A1DB-E2FA60328698> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x7fff89497000 -     0x7fff894d3ff7  com.apple.ids (10.0 - 1000) <632F7192-0399-34C8-B6BB-463D2F4370E0> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
          0x7fff896eb000 -     0x7fff89751fff  com.apple.framework.CoreWiFi (2.0 - 200.21.1) <977C796D-E8D7-3378-A76A-2E71A65DF389> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
          0x7fff89a8a000 -     0x7fff89a91fff  com.apple.NetFS (6.0 - 4.0) <D4FE0F16-3085-34AF-B860-3D46B98FAD2A> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff89a92000 -     0x7fff89a98ff7  libCGXCoreImage.A.dylib (599.20.11) <A787F160-6963-38B5-AF86-D5541E0492F1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A. dylib
          0x7fff89a9e000 -     0x7fff89aa1ffa  libCGXType.A.dylib (599.20.11) <C0B41DDE-0988-3652-B03B-9E5EB0DABAEB> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
          0x7fff89aa2000 -     0x7fff89b2aff7  com.apple.CorePDF (4.0 - 4) <5B7DEF8B-0C3C-3450-899C-71ED8820D523> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fff89b2b000 -     0x7fff89b52ff7  com.apple.shortcut (2.6 - 2.6) <73FEBA7B-F371-3D1C-8E42-08580DE241A7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
          0x7fff89b53000 -     0x7fff89b5bffc  libGFXShared.dylib (9.6) <E276D384-3616-3511-B5F2-92621D6372D6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff89b5c000 -     0x7fff89c8cff7  com.apple.desktopservices (1.8.2 - 1.8.2) <76D6ED93-9D5A-3941-8B88-A1773290AE74> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff89c8d000 -     0x7fff89c91fff  libpam.2.dylib (20) <A63D4DA2-06A4-3FB8-AC3F-BDD69694EE5E> /usr/lib/libpam.2.dylib
          0x7fff89c92000 -     0x7fff89c92fff  com.apple.quartzframework (1.5 - 1.5) <F66337F6-CC0A-3008-BB23-080282E917C9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fff89c93000 -     0x7fff89c94ff7  libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
          0x7fff89c95000 -     0x7fff89c9cff7  com.apple.phonenumbers (1.1.1 - 105) <C31E978D-C4CE-39CD-9E19-A43698ECC466> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
          0x7fff89c9d000 -     0x7fff89f9bfff  com.apple.Foundation (6.9 - 1056.13) <2EE9AB07-3EA0-37D3-B407-4A520F2CB497> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff89f9c000 -     0x7fff8a04cff7  libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff8a04d000 -     0x7fff8a49bfff  com.apple.VideoToolbox (1.0 - 1273.49) <27177077-9107-3E06-ADAD-92B80E80CDCD> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fff8a49c000 -     0x7fff8a528ff7  com.apple.ink.framework (10.9 - 207) <96A56EAC-B4AC-3C9A-8C40-64E6196753CC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff8a549000 -     0x7fff8a577ff7  com.apple.securityinterface (9.0 - 55047) <E64A6994-0176-39A1-866A-AB27F6A0034B> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
          0x7fff8a578000 -     0x7fff8a848ffc  com.apple.CoreImage (9.2.7) <BF88A02E-994E-3970-AC62-04248CA8DC46> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
          0x7fff8a849000 -     0x7fff8a87effc  com.apple.LDAPFramework (2.4.28 - 194.5) <4ADD0595-25B9-3F09-897E-3FB790AD2C5A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fff8a87f000 -     0x7fff8a8aefd2  libsystem_m.dylib (3047.16) <9D96AACD-5870-3A5C-B849-7F9C0F6EBB09> /usr/lib/system/libsystem_m.dylib
          0x7fff8a97a000 -     0x7fff8aa33fff  libcrypto.0.9.7.dylib (106) <BFE87BFA-7971-37DC-9B20-55F04E509A80> /usr/lib/libcrypto.0.9.7.dylib
          0x7fff8aa34000 -     0x7fff8aa3bff7  libsystem_pthread.dylib (53.1.4) <9DA50FD0-D9AC-3051-AD4B-BA0D745BC49C> /usr/lib/system/libsystem_pthread.dylib
          0x7fff8aa3c000 -     0x7fff8aa4cfff  libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
          0x7fff8aa73000 -     0x7fff8ad1dff5  com.apple.HIToolbox (2.1 - 697.4) <DF5635DD-C255-3A8E-8B49-F6D2FB61FF95> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff8ad3a000 -     0x7fff8ad43ff7  libcldcpuengine.dylib (2.3.58) <C8785704-6195-3129-86CA-20F0F3C20F15> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
          0x7fff8ad44000 -     0x7fff8ae85fff  com.apple.QTKit (7.7.3 - 2826.17) <ADA1EF77-57D2-3E7E-8526-8F0B732C1218> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff8ae86000 -     0x7fff8ae9fff7  com.apple.Kerberos (3.0 - 1) <59427E11-37D6-34C9-95BB-D4438BFACA5B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff8aea0000 -     0x7fff8af05ff5  com.apple.Heimdal (4.0 - 2.0) <523EC6C4-BD9B-3840-9376-E617BA627F59> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
          0x7fff8af10000 -     0x7fff8af11ff7  libSystem.B.dylib (1197.1.1) <A75BB8CD-CE51-3DF7-BCF4-8BDE25FA7F0C> /usr/lib/libSystem.B.dylib
          0x7fff8af4d000 -     0x7fff8af75ffb  libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
          0x7fff8af76000 -     0x7fff8af76ffd  com.apple.audio.units.AudioUnit (1.10 - 1.10) <486A97CD-C1F7-324D-87BC-B07F7A415B68> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff8afe2000 -     0x7fff8afecfff  libcommonCrypto.dylib (60049) <79B8E80F-E596-3302-8243-EC479B9546CA> /usr/lib/system/libcommonCrypto.dylib
          0x7fff8afed000 -     0x7fff8affaff4  com.apple.Librarian (1.2 - 1) <2F677B44-BCA3-313B-881E-EE322E865100> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
          0x7fff8affb000 -     0x7fff8b004ff3  libsystem_notify.dylib (121) <31F9FEF5-2897-328A-8441-B7BDFEDB10D4> /usr/lib/system/libsystem_notify.dylib
          0x7fff8b005000 -     0x7fff8b007ff3  libsystem_configuration.dylib (596.13) <B51C8C22-C455-36AC-952D-A319B6545884> /usr/lib/system/libsystem_configuration.dylib
          0x7fff8b03a000 -     0x7fff8b03bff7  libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
          0x7fff8b03c000 -     0x7fff8b040ff7  libheimdal-asn1.dylib (323.15) <B8BF2B7D-E913-3544-AA6D-CAC119F81C7C> /usr/lib/libheimdal-asn1.dylib
          0x7fff8b041000 -     0x7fff8b042fff  com.apple.AddressBook.ContactsData (8.0 - 1369) <BAF434EC-32B6-3F1C-8ABE-4419A15829FF> /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData
          0x7fff8b043000 -     0x7fff8b04bff7  com.apple.AppleSRP (5.0 - 1) <ABC7F088-1FD5-3768-B9F3-847F355E90B3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
          0x7fff8b1b3000 -     0x7fff8b1dcfff  com.apple.DictionaryServices (1.2 - 208) <A4E4EA9E-08A1-3F77-8B57-A5A1ADD70B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff8b1e6000 -     0x7fff8b1eeff7  com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <A816D8B1-6B7B-3E5B-9FAE-CBDA70192E7E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff8b1ef000 -     0x7fff8b1effff  com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff8b1f0000 -     0x7fff8b1f2fff  com.apple.marco (10.0 - 1000) <C8B6533A-A248-3A83-90E1-F308DADC5BD7> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
          0x7fff8b1f3000 -     0x7fff8b209fff  com.apple.CoreMediaAuthoring (2.2 - 947) <C8E92F35-7F4C-38CF-890A-6462D59B9D0F> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
          0x7fff8b20a000 -     0x7fff8b217ff0  libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
          0x7fff8b218000 -     0x7fff8b224ff7  com.apple.OpenDirectory (10.9 - 173.90.1) <E5EF8E1A-7214-36D0-AF0D-8D030DF6C2FC> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff8b225000 -     0x7fff8b47eff9  com.apple.security (7.0 - 55471.14) <3F7100A0-FE46-333D-9A4B-396580F1B4FE> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff8b507000 -     0x7fff8b508ff7  com.apple.print.framework.Print (9.0 - 260) <C4C40E2E-6130-3D73-B1EF-97FF3F70CF2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff8b509000 -     0x7fff8b566fff  com.apple.imfoundation (10.0 - 1000) <7DE171BB-F8AF-3E6B-84ED-235937DACE7E> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
          0x7fff8b567000 -     0x7fff8b56dff7  libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib
          0x7fff8b56e000 -     0x7fff8b59dff7  com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <E8190181-8F08-3DC3-9290-3AADBCEBB1F3> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
          0x7fff8b59e000 -     0x7fff8b5acfff  com.apple.CommerceCore (1.0 - 42) <398E733A-C4F6-3ECF-805C-A4887C16679E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
          0x7fff8b5ad000 -     0x7fff8b638fff  libCoreStorage.dylib (380) <D431A980-5CEF-32DA-8955-EC34B3DA64D9> /usr/lib/libCoreStorage.dylib
          0x7fff8b639000 -     0x7fff8b642fff  com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <383FB557-E88E-3239-82B8-15F9F885B702> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff8b643000 -     0x7fff8b672ff5  com.apple.GSS (4.0 - 2.0) <62046C17-5D09-346C-B08E-A664DBC18411> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
          0x7fff8b686000 -     0x7fff8b8ceff7  com.apple.CoreData (107 - 481.01) <DA339795-5D97-35B5-9B04-629830013720> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff8b8cf000 -     0x7fff8b9b3fff  com.apple.coreui (2.1 - 231) <A7942BEE-E6BA-3A68-8EA0-57A8A9066B2D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff8b9b4000 -     0x7fff8ba03ff7  com.apple.framework.internetaccounts (2.1 - 210) <D7175985-03A5-315B-B788-FBDC0019B0EA> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
          0x7fff8ba04000 -     0x7fff8ba43fff  libGLU.dylib (9.6) <EE4907CA-219C-34BD-A84E-B85695F64C05> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff8ba44000 -     0x7fff8bd2efff  com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff8bd2f000 -     0x7fff8bd67ff7  com.apple.RemoteViewServices (2.0 - 94) <B17FAA76-61DB-33D0-90B7-4117A72A2B28> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
          0x7fff8bd82000 -     0x7fff8be46ff7  com.apple.backup.framework (1.5.2 - 1.5.2) <A3C552F0-670B-388F-93FA-D917F96ACE1B> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
          0x7fff8be47000 -     0x7fff8be55fff  com.apple.opengl (9.6.0 - 9.6.0) <709F4A02-73A0-303C-86B5-85C596C8B707> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff8be56000 -     0x7fff8c12afc7  com.apple.vImage (7.0 - 7.0) <1DDB8AB7-03D5-3D20-9D77-C69074C6FD26> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff8c12b000 -     0x7fff8c14fff7  libJPEG.dylib (1042) <33648F26-A1DA-3C30-B15B-E9FFD41DB25C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
          0x7fff8c150000 -     0x7fff8c208ff7  com.apple.DiscRecording (8.0 - 8000.4.6) <FCBB5558-A702-3658-AEE4-7D129AFBF350> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
          0x7fff8c221000 -     0x7fff8c2a1fff  com.apple.CoreSymbolication (3.0 - 141) <37087FDB-874D-3FE2-9874-B047CC9BE910> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
          0x7fff8c2c6000 -     0x7fff8c319fff  com.apple.ScalableUserInterface (1.0 - 1) <19D73C6D-CA0A-3230-9644-7F01364137ED> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
          0x7fff8c31a000 -     0x7fff8c35ffff  libcurl.4.dylib (78.90.1) <818543D6-0CCE-3F18-9BF1-4D18B81018F3> /usr/lib/libcurl.4.dylib
          0x7fff8c3ac000 -     0x7fff8c3ddff7  libtidy.A.dylib (15.12) <BF757E3C-733A-3B6B-809A-A3949D46466E> /usr/lib/libtidy.A.dylib
          0x7fff8c3f8000 -     0x7fff8c40aff7  com.apple.MultitouchSupport.framework (245.13 - 245.13) <D5E7416D-45AB-3690-86C6-CC4B5FCEA2D2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fff8c44a000 -     0x7fff8c48cff7  libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
          0x7fff8c48d000 -     0x7fff8c5c3ff6  com.apple.WebKit (9537 - 9537.74.9) <CA0C0387-8A66-34D4-8B1C-F5CDDBDA76BB> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
          0x7fff8c606000 -     0x7fff8c665fff  com.apple.framework.CoreWLAN (4.3.2 - 432.47) <AE6FAE44-918C-301C-A0AA-C65CAB6B5668> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
          0x7fff8c666000 -     0x7fff8c6b3ff2  com.apple.print.framework.PrintCore (9.0 - 428) <A2F7B9D2-7907-31D8-8462-E2E2E7C3AF2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff8cbe0000 -     0x7fff8cbf3ff7  com.apple.AppContainer (3.0 - 1) <BD342039-430E-39FE-BC2D-8F97B557548E> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
          0x7fff8cbf4000 -     0x7fff8cc42ff9  libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
          0x7fff8cc43000 -     0x7fff8cda9fff  libGLProgrammability.dylib (9.6) <8807FAD2-11E2-3293-89D8-397B87334138> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff8ce25000 -     0x7fff8cef6ff1  com.apple.DiskImagesFramework (10.9 - 371.1) <D456ED08-4C1D-341F-BAB8-85E34A7275C5> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
          0x7fff8cf1e000 -     0x7fff8cf59fff  com.apple.bom (14.0 - 193.1) <EF24A562-6D3C-379E-8B9B-FAE0E4A0EF7C> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
          0x7fff8cf5a000 -     0x7fff8cf5cffb  libutil.dylib (34) <DAC4A6CF-A1BB-3874-9569-A919316D30E8> /usr/lib/libutil.dylib
          0x7fff8cf5f000 -     0x7fff8d295fff  com.apple.MediaToolbox (1.0 - 1273.49) <AB8ED666-6D15-3367-A033-F4A8AD33C4E0> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fff8d296000 -     0x7fff8d29bfff  com.apple.DiskArbitration (2.6 - 2.6) <A4165553-770E-3D27-B217-01FC1F852B87> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff8d29c000 -     0x7fff8d2a7fff  libGL.dylib (9.6) <A2EF4E15-EA08-396D-A1D4-29E1CED6876A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff8d2a8000 -     0x7fff8d2b2ff7  com.apple.CrashReporterSupport (10.9 - 538) <E4DA588F-C75A-39F6-9D2B-7B79F0245D39> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
          0x7fff8d2b3000 -     0x7fff8d498fff  com.apple.CoreFoundation (6.9 - 855.14) <617B8A7B-FAB2-3271-A09B-C542E351C532> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff8d499000 -     0x7fff8d4a8ff8  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2777524A-E7EF-3B7B-B15D-F58CDEEFC736> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff8d4a9000 -     0x7fff8d4deffb  com.apple.datadetectors (5.0 - 246.0) <1C4C33FE-F364-3DBA-A1BC-4A53E594CFD3> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
          0x7fff8d52f000 -     0x7fff8d530fff  com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fff8d596000 -     0x7fff8d5fdff7  com.apple.CoreUtils (2.0 - 200.34.4) <E53B97FE-E067-33F6-A9C1-D4EC2A20FB9F> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
          0x7fff8d5fe000 -     0x7fff8d605ff8  liblaunch.dylib (842.90.1) <38D1AB2C-A476-385F-8EA8-7AB604CA1F89> /usr/lib/system/liblaunch.dylib
          0x7fff8d606000 -     0x7fff8d84cfff  com.apple.AddressBook.framework (8.0 - 1369) <3D1A8D58-6A9E-366C-BDB8-ECC6F279DB24> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
          0x7fff8d84d000 -     0x7fff8d858ff7  com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
          0x7fff8d859000 -     0x7fff8d95fff7  com.apple.ImageIO.framework (3.3.0 - 1042) <6101F33E-CACC-3070-960A-9A2EA4BC5F44> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
          0x7fff8d960000 -     0x7fff8d963fff  com.apple.help (1.3.3 - 46) <6D71C959-D421-372B-A160-5317B4921F4D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff8d964000 -     0x7fff8d993fff  com.apple.DebugSymbols (106 - 106) <9F66640E-277C-317E-A01E-A1E5B13E2592> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
          0x7fff8d994000 -     0x7fff8d9b0fff  libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib
          0x7fff8d9b1000 -     0x7fff8d9b5ff7  libcache.dylib (62) <8C1EFC4F-3F51-3DE9-A973-360B461F3D65> /usr/lib/system/libcache.dylib
          0x7fff8d9b6000 -     0x7fff8da51fff  com.apple.PDFKit (2.9.1 - 2.9.1) <F4DFF4F2-6DA3-3B1B-823E-D9ED271A1522> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fff8da99000 -     0x7fff8dac3ff7  libsandbox.1.dylib (278.11) <9E5654BF-DCD3-3B15-9C63-209B2B2D2803> /usr/lib/libsandbox.1.dylib
          0x7fff8dac4000 -     0x7fff8daf4fff  com.apple.IconServices (25 - 25.17) <36811973-8777-3211-863A-76B2C20B0ED0> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
          0x7fff8daf5000 -     0x7fff8de6cffa  com.apple.JavaScriptCore (9537 - 9537.74.4) <0942FE6B-3152-30FC-B92A-92A1C29C5295> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fff8df01000 -     0x7fff8df1dfff  com.apple.frameworks.preferencepanes (16.0 - 16.0) <68BCF160-F85E-3F71-BD4E-8661DACDBE69> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
          0x7fff8df1e000 -     0x7fff8e04dfef  com.apple.MediaControlSender (2.0 - 200.34.4) <FC24EC8D-2E46-3F76-AF63-749F30857B96> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
          0x7fff8e075000 -     0x7fff8e306ff7  com.apple.AOSKit (1.06 - 176) <A5D6EC71-51E2-3D0D-8DA6-1927AC519277> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
          0x7fff8e307000 -     0x7fff8e3f6fff  libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff8e3f7000 -     0x7fff8e967fff  com.apple.CoreAUC (6.22.08 - 6.22.08) <D7F7D85D-896E-35D6-9FC4-DAF7920E38BB> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x7fff8e968000 -     0x7fff8e969ff7  libodfde.dylib (20) <71C1001F-044F-3C0F-BA95-EAC080176A16> /usr/lib/libodfde.dylib
          0x7fff8e995000 -     0x7fff8e999ff7  libGIF.dylib (1042) <C57840F6-1C11-3273-B4FC-956950B94034> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
          0x7fff8e99a000 -     0x7fff8e9e1ff7  libcups.2.dylib (372.2) <37802F24-BCC2-3721-8E12-82B29B61B2AA> /usr/lib/libcups.2.dylib
          0x7fff8e9e8000 -     0x7fff8ea04ff7  libsystem_kernel.dylib (2422.90.20) <20E00C54-9222-359F-BD98-CB79ABED769A> /usr/lib/system/libsystem_kernel.dylib
          0x7fff8ea05000 -     0x7fff8ea06fff  liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
          0x7fff8ea07000 -     0x7fff8ea0dff7  com.apple.XPCService (2.0 - 1) <7545EF91-BB7B-3DF3-BF87-F55309DA5838> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
          0x7fff8ea3b000 -     0x7fff8ea3efff  com.apple.AppleSystemInfo (3.0 - 3.0) <61FE171D-3D88-313F-A832-280AEC8F4AB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
          0x7fff8ea3f000 -     0x7fff8ea5cff7  com.apple.framework.Apple80211 (9.3.1 - 931.58) <D5B2DD15-3DCC-31F6-9320-3A20A887C5D5> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
          0x7fff8ea5d000 -     0x7fff8eb28fff  libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff8eb29000 -     0x7fff8eb2bff7  libquarantine.dylib (71) <973BE51D-6465-392F-9099-D4AB21BF0D25> /usr/lib/system/libquarantine.dylib
          0x7fff8eb36000 -     0x7fff8eb54fff  com.apple.facetimeservices (10.0 - 1000) <DED6A966-DF0E-3E58-BD34-D85ED82A99D7> /System/Library/PrivateFrameworks/FTServices.framework/Versions/A/FTServices
          0x7fff8eb77000 -     0x7fff8eb92ff7  libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
          0x7fff8ebb7000 -     0x7fff8ebb7fff  com.apple.ApplicationServices (48 - 48) <F250170A-8805-3731-9097-78CAD04481F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff8ebb8000 -     0x7fff8fa06fff  com.apple.WebCore (9537 - 9537.74.11) <9683BA7C-A04B-3E33-B195-DCF1C2CABF95> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
          0x7fff8fa07000 -     0x7fff8fa11ff7  libcsfde.dylib (380) <48C0E3BA-ECE7-3337-918C-E65B4A5F0593> /usr/lib/libcsfde.dylib
          0x7fff8fa12000 -     0x7fff8fbcaff3  libicucore.A.dylib (511.31) <167DDD0A-A935-31AF-B5B9-940268EC3A3C> /usr/lib/libicucore.A.dylib
          0x7fff8fbcb000 -     0x7fff8fbddfff  com.apple.ImageCapture (9.0 - 9.0) <D9269440-8E56-3C03-88F5-F8AD662D17DB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff8fbde000 -     0x7fff8fc42fff  com.apple.datadetectorscore (5.0 - 354.3) <B92E87D1-2045-3AB2-AE3F-8F948B30518A> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fff8fd1c000 -     0x7fff8fd75fff  libTIFF.dylib (1042) <51D02EEC-0D0C-34C1-91C8-D316473A3FEA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
          0x7fff8fd76000 -     0x7fff908ecfff  com.apple.AppKit (6.9 - 1265.19) <12647F2F-3FE2-3D77-B3F0-33EFAFF2CEA7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff909a3000 -     0x7fff909e4fff  com.apple.PerformanceAnalysis (1.47 - 47) <784ED7B8-FAE4-36CE-8C76-B7D300316C9F> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
          0x7fff909e5000 -     0x7fff909e5fff  com.apple.AOSMigrate (1.0 - 1) <6909D700-6E8A-3BFD-9B5D-FA94C1150E6E> /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOSMigrate
          0x7fff909e6000 -     0x7fff90a01ff7  libPng.dylib (1042) <36FF1DDA-9804-33C5-802E-3FCA9879F0E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
          0x7fff90a02000 -     0x7fff90a07ff7  com.apple.MediaAccessibility (1.0 - 43) <DDB8A42D-89D8-34F1-AA35-75D7659616C9> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
          0x7fff90a08000 -     0x7fff90a15ff7  libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
          0x7fff90a16000 -     0x7fff90a1efff  libsystem_dnssd.dylib (522.90.2) <A0B7CF19-D9F2-33D4-8107-A62184C9066E> /usr/lib/system/libsystem_dnssd.dylib
          0x7fff90bde000 -     0x7fff90caffff  com.apple.QuickLookUIFramework (5.0 - 622.7) <13841701-34C2-353D-868D-3E08D020C90F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fff90cb0000 -     0x7fff90cd9fff  GLRendererFloat (9.6) <16871296-2EB9-3FF6-AB00-3E2E55A45A63> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
          0x7fff90cda000 -     0x7fff90e4aff8  com.apple.CFNetwork (673.2.1 - 673.2.1) <AE407146-CCF2-33DD-AAEA-6887FD6F45BA> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
          0x7fff90eb5000 -     0x7fff90edcff7  libsystem_network.dylib (241.3) <A499D688-9165-3776-8C8E-C018897B5B13> /usr/lib/system/libsystem_network.dylib
          0x7fff90edf000 -     0x7fff9113cffd  com.apple.RawCamera.bundle (5.03 - 731) <99C18399-B160-3C4A-AEDC-A2FD4944FCC6> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff911c8000 -     0x7fff911d3fff  libGPUSupportMercury.dylib (9.6) <3E5636DB-5EED-3C31-8B6D-8CBFE965BC12> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
          0x7fff911d4000 -     0x7fff91264fff  com.apple.Metadata (10.7.0 - 800.23) <BFEE576F-D779-300B-B685-26A3A008710A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff91265000 -     0x7fff9127dff7  com.apple.openscripting (1.4 - 157) <B3B037D7-1019-31E6-9D17-08E699AF3701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff9127e000 -     0x7fff912cbfff  com.apple.AppleVAFramework (5.0.27 - 5.0.27) <484D6B2E-237D-34D8-9394-771F2F2294B8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fff9130b000 -     0x7fff91330ff7  com.apple.ChunkingLibrary (2.0 - 155.1) <B49408CD-ECE8-3785-84A4-45B03882574A> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
          0x7fff913c8000 -     0x7fff91437ff1  com.apple.ApplicationServices.ATS (360 - 363.3) <546E89D9-2AE7-3111-B2B8-2366650D22F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff91438000 -     0x7fff9143efff  com.apple.AOSNotification (1.7.0 - 760.3) <307D35A7-C2CB-3024-BFE1-288A0198C003> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
          0x7fff9143f000 -     0x7fff9144fffb  libsasl2.2.dylib (170) <C8E25710-68B6-368A-BF3E-48EC7273177B> /usr/lib/libsasl2.2.dylib
          0x7fff91450000 -     0x7fff9147cfff  com.apple.CoreServicesInternal (184.9 - 184.9) <4DEA54F9-81D6-3EDB-AA3C-1F9C497B3379> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
          0x7fff9147d000 -     0x7fff91494ffa  libAVFAudio.dylib (32.2) <C77A6482-46FA-3A17-B357-BBEA380B4E6C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
          0x7fff91495000 -     0x7fff91499fff  com.apple.CommonPanels (1.2.6 - 96) <5744A1F1-1FA5-35DD-B924-F8983E81FC76> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff914a0000 -     0x7fff91500fff  com.apple.ISSupport (1.9.9 - 57) <87137CF3-FE6A-3345-A2EC-95D73A15CC3A> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
          0x7fff91501000 -     0x7fff9151cff7  libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib
          0x7fff9151d000 -     0x7fff9163fff1  com.apple.avfoundation (2.0 - 651.12) <5261E6EA-7476-32B2-A12A-D42598A9B2EA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
          0x7fff91640000 -     0x7fff9164aff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <9556885C-22DD-3392-ACCB-2B413434D8D3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
          0x7fff9164b000 -     0x7fff916a6ffb  com.apple.AE (665.5 - 665.5) <3558CC9A-FD30-3DAD-AB40-FE6828E76FE1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff916ff000 -     0x7fff9170cfff  com.apple.Sharing (132.2 - 132.2) <3DFB1133-8FD3-3B60-8E9C-0FE62AACFD7B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
          0x7fff9170d000 -     0x7fff91737ff7  libpcap.A.dylib (42) <91D3FF51-D6FE-3C05-98C9-1182E0EC3D58> /usr/lib/libpcap.A.dylib
          0x7fff91738000 -     0x7fff917faff5  com.apple.CoreText (352.0 - 367.19) <24848DF1-67EC-3D41-9548-1F14C6DFBBF9> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
          0x7fff917fb000 -     0x7fff91865ff7  com.apple.framework.IOKit (2.0.1 - 907.90.2) <A779DE46-BB7E-36FD-9348-694F9B09718F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff91872000 -     0x7fff91872ff7  libkeymgr.dylib (28) <D7045F25-BFA4-3840-847D-AF95DF8B6CCA> /usr/lib/system/libkeymgr.dylib
          0x7fff91873000 -     0x7fff918cbff7  com.apple.Symbolication (1.4 - 129) <16D42516-7B5E-357C-898A-FAA9EE7642B3> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
          0x7fff918cc000 -     0x7fff921ebaf3  com.apple.CoreGraphics (1.600.0 - 599.20.11) <06212100-8069-31A1-9C44-F6C4B1695230> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
          0x7fff9226b000 -     0x7fff92283ff7  com.apple.GenerationalStorage (2.0 - 160.2) <DC0236CC-A0F7-31DA-A201-09D4319BE96E> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
          0x7fff92284000 -     0x7fff92295ff7  libz.1.dylib (53) <4C5FA1A5-4471-398E-9543-2E54D46E63E9> /usr/lib/libz.1.dylib
          0x7fff92296000 -     0x7fff922a7fff  com.apple.idsfoundation (10.0 - 1000) <D3E6646B-4118-30D3-B4F7-DA9A28B396E4> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
          0x7fff929f8000 -     0x7fff92ad7fff  libcrypto.0.9.8.dylib (50) <09DCEDDF-2892-32B8-B689-CBE31A549F2B> /usr/lib/libcrypto.0.9.8.dylib
          0x7fff92af4000 -     0x7fff92b45fff  com.apple.QuickLookFramework (5.0 - 622.7) <17685CEC-C94B-3F83-ADE1-B24840B35E44> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fff92c45000 -     0x7fff92e35ffd  com.apple.WebKit2 (9537 - 9537.74.9) <3F7B257F-D0DA-3AA8-BE8B-0C5474FE9806> /System/Library/PrivateFrameworks/WebKit2.framework/Versions/A/WebKit2
          0x7fff92e36000 -     0x7fff92e7bffe  com.apple.HIServices (1.22 - 467.2) <B7FCF008-C241-3862-BC63-E6EF4006A6E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff92e7c000 -     0x7fff92e7efff  com.apple.SecCodeWrapper (3.0 - 1) <DE7CA981-2B8B-34AC-845D-06D5C8F10441> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
          0x7fff92e89000 -     0x7fff92ea0ff7  com.apple.CFOpenDirectory (10.9 - 173.90.1) <38A25261-C622-3F11-BFD3-7AFFC44D57B8> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff92ea1000 -     0x7fff92ebbfff  libdispatch.dylib (339.90.1) <F3CBFE1B-FCE8-3F33-A53D-9092AB382DBB> /usr/lib/system/libdispatch.dylib
          0x7fff92ebc000 -     0x7fff92f07fff  com.apple.ImageCaptureCore (5.0 - 5.0) <605A78DB-E529-3E36-9667-A7E9973198B6> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fff92f08000 -     0x7fff92f2afff  com.apple.framework.familycontrols (4.1 - 410) <7964B5AE-F6C7-3E5C-A619-4EFE70D2D0C8> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x7fff92f2b000 -     0x7fff9330cffe  libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff9330d000 -     0x7fff93356fff  com.apple.CoreMedia (1.0 - 1273.49) <D91EC90A-BFF1-300D-A353-68001705811C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fff9337e000 -     0x7fff93380fff  libCVMSPluginSupport.dylib (9.6) <FFDA2811-060E-3591-A280-4A726AA82436> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
          0x7fff93381000 -     0x7fff93384fff  libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff93385000 -     0x7fff93532f27  libobjc.A.dylib (551.1) <F21C5742-7B9C-31F1-BBAE-1717BC6C2F1B> /usr/lib/libobjc.A.dylib
          0x7fff93604000 -     0x7fff9367bfff  com.apple.CoreServices.OSServices (600.4 - 600.4) <80E7B419-A0D5-373B-B2B5-88E6A8CD3AE6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff9367c000 -     0x7fff93688ff7  com.apple.HelpData (2.1.4 - 90) <546D6B21-CDCE-35C0-86F2-C38A4789F4EE> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
          0x7fff93689000 -     0x7fff9368dff7  libsystem_stats.dylib (93.90.3) <1A55AF8A-B6C4-3163-B557-3AD25DA643A8> /usr/lib/system/libsystem_stats.dylib
          0x7fff9369b000 -     0x7fff936a7ff3  com.apple.AppleFSCompression (56 - 1.0) <1EBCFC91-734D-338B-8796-4B93BDC53014> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
          0x7fff936a8000 -     0x7fff936c1ff7  com.apple.Ubiquity (1.3 - 289) <664F5B33-708D-33E9-81E1-C45CBE9AAB6E> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
          0x7fff936c2000 -     0x7fff936c2fff  com.apple.Carbon (154 - 157) <14069023-0BBB-3925-9BA9-EB2C9E9B8C75> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff936c3000 -     0x7fff936e7fff  com.apple.quartzfilters (1.8.0 - 1.7.0) <C45C3D45-CCB2-3661-A390-959E556B14B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fff93fac000 -     0x7fff93fafff7  com.apple.LoginUICore (3.0 - 3.0) <1ECBDA90-D6ED-3333-83EB-9C8232DFAD7C> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
          0x7fff93fb0000 -     0x7fff94079fff  com.apple.LaunchServices (572.26 - 572.26) <EF8A4A15-0861-35C5-9744-5E1BC5C26DD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff9407a000 -     0x7fff940e7fff  com.apple.SearchKit (1.4.0 - 1.4.0) <33298263-5B12-340D-BB9D-D52303849561> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff940ea000 -     0x7fff94286ff3  com.apple.QuartzCore (1.8 - 332.3) <80F1068F-4A34-34FB-9E05-A2DC0700D2F2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff94287000 -     0x7fff942d9fff  libc++.1.dylib (120) <2CB96D10-1E3E-39B1-B90D-C56C3818321E> /usr/lib/libc++.1.dylib
          0x7fff94377000 -     0x7fff943b0ff7  com.apple.QD (3.50 - 298) <5343278D-47B7-3AF2-9B4B-4B8B0F942CD1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      External Modification Summary:
        Calls made by other processes targeting this process:
          task_for_pid: 2
          thread_create: 0
          thread_set_state: 0
        Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
        Calls made by all processes on this machine:
          task_for_pid: 1889
          thread_create: 1
          thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=245.9M resident=122.1M(50%) swapped_out_or_unallocated=123.8M(50%)
      Writable regions: Total=2.7G written=267.3M(10%) resident=335.9M(12%) swapped_out=0K(0%) unallocated=2.4G(88%)
      REGION TYPE                        VIRTUAL
      CG backing stores                    40.8M
      CG image                             2812K
      CG raster data                        300K
      CG shared images                      180K
      CoreAnimation                        2200K
      CoreAnimation (reserved)              112K        reserved VM address space (unallocated)
      CoreImage                              52K
      Foundation                              4K
      IOKit                                14.7M
      Image IO                             2916K
      JS JIT generated code               256.0M
      JS JIT generated code (reserved)    768.0M        reserved VM address space (unallocated)
      JS VM register file                  4096K
      JS garbage collector                 2816K
      Java                                328.6M
      Java (reserved)                       1.0G        reserved VM address space (unallocated)
      Kernel Alloc Once                       8K
      MALLOC                              216.9M
      MALLOC (admin)                         48K
      MALLOC_LARGE (reserved)              4096K        reserved VM address space (unallocated)
      Mach message                            8K
      Memory Tag 241                        120K
      Memory Tag 242                         12K
      Memory Tag 251                         16K
      OpenCL                                144K
      OpenGL GLSL                          1664K
      SQLite page cache                     256K
      STACK GUARD                          56.2M
      Stack                                45.9M
      VM_ALLOCATE                          16.8M
      WebKit Malloc                        5560K
      __DATA                               31.5M
      __IMAGE                               528K
      __LINKEDIT                           68.1M
      __TEXT                              177.8M
      __UNICODE                             544K
      mapped file                          77.7M
      shared memory                          68K
      TOTAL                                 3.1G
      TOTAL, minus reserved VM space        1.3G
