4 Replies Latest reply: Jun 9, 2014 4:48 PM by bridobe RSS
    How do i set a page as a template page?
    SureKB Community Member
      I've tried copying the HTML coding from my page to a template page, but this isn't working.
      Why is this not working and how can i fix this?
        • 1. Re: How do i set a page as a template page?
          Liam Dilley CommunityMVP
          Hi there,
          You can not just copy html to a template page. A template requires {tag_pagecontent} to run as a template, this renders layouts, page content etc.
          Some info in the documentation for you here:http://helpx.adobe.com/business-catalyst/using/control-sites-look-feel.html#id_1911
          • 2. Re: How do i set a page as a template page?
            Hi Liam,
            Where would the {tag_pagecontent} have to appear in the html? The information in the link doesn't really tell me.
            I created my template in Muse, but i'd like to set templates for my system pages, which i can't edit in Muse.
            Thanks.
            • 3. Re: How do i set a page as a template page?
              Where your main content area will be. That is up to you in terms of the build.
              If you built a template in Muse that is slightly different, Probably already set up, I dont touch Muse so I am not to sure how it works fully.
              If you have a template though and you want to apply it to pages you need to log into your BC website, go to a web page and set the template to use.
              • 4. Re: How do i set a page as a template page?
                bridobe
                In Muse, create a new page based on your master page (or whatever master settings you want to use for the template). In Plan mode, right click on the new page you just created and select Menu Options > Exclude Page From Menus. Double click on the page to bring it up in Design mode.
                Now you should have a page with your master header, menu items and footer. The content area between header and footer is where you will have new content. From the top menu, select Object > Insert HTML.... In the pop up window, enter the BC tag like this {tag_pagecontent}. This will place an HTML object on your page, drag/resize the object to fill the area where you will want your new content. Make sure to resize the HTML object so that it goes all the way to the bottom of your page.
                Save your project and upload the new page to your BC site. In BC create a new template based on this new page. If it is to be used for the full site, select the option to make the page the default template.
                That should do it.
