3 Replies Latest reply on Mar 13, 2014 10:01 AM by MathPoli
    Generated index (TOC): order of paragraphs is messed up when using RTF import
    MathPoli
      I have a weird problem with a semi-automatic generated index (table of content) :
      A have a book containing two InDesign files: one index file and one chapter.
      The index file displays all the chapter numbers and corresponding page numbers:
      The chapter file contains one text frame. Within this text frame, real text is placed as well as paragraphs, which are imported from an RTF file:
      So far so good.
      The PROBLEM:
      In the semi-auto generated index, the order of the paragraphs is messed up: the index places the real text before the RTF-imported text, even if it is behind it!
      Why is that?
      Is there a solution to this?
      My System:
      InDesign 9.1 (CC)
      MacPro 2.8 GHz QuadCore Intel Xeon, 16GB RAM
      Mac OS X 10.9.1
      Regards
      Mathias
        • 1. Re: Generated index (TOC): order of paragraphs is messed up when using RTF import
          MathPoli Level 1
          I have just found out, that ID seems to "scan" a page from left-to-right to define the order of what goes where into the index. Is that correct?
          If so, it would be logical that ID also scans text frames from left-to-right. That would explain the strange behaviour I posted above.
          Can this be altered? Can I tell ID to scan "from top-to-bottom" instead of "from left-to-right"?
          • 2. Re: Generated index (TOC): order of paragraphs is messed up when using RTF import
            ID starts inthe upper left and reads down, then moves right and reads down again. I suspect that it's picking up the anchored frames after the normal text. Is there a reason you have to use anchored frames instead of pasting the text directly?
            • 3. Re: Generated index (TOC): order of paragraphs is messed up when using RTF import
              MathPoli Level 1
              Yes, the reason is this:
              the text portions (that reside within the RTF file) are texts that are used in multiple documents.
              For example, it could be a company adress that is used in 100 docs at various positions. In order to reduce maintenance work, (in case the adress changes: e.g. new phone number), the text frame is placed as a file and links to the RTF file. If I placed real / normal text directly, I would have 100 instances of the adress. This would mean much more maintenance work.
              Another advantage is, that if the length of the RTF text changes, I can tell the RTF text frame (in advance) to extend automatically (e.g. towards the bottom of the page). This enables a dynamic layout which reacts flexibly to changes.
              It's similar to using an image multiple times. But here, it's text. And flexible.
