1 Reply Latest reply on Mar 11, 2014 1:51 PM by vishu#13
    cfspreadsheet password
    anodynepres Level 1
      Adding a password to cfspreadsheet and saving the file has no effect.  I can still open the file without dialogs and edit anything.  This is true even if I use spreadsheetformatcell to change the lock status.  Does this actually work?  Anybody have an example that works?
        • 1. Re: cfspreadsheet password
          vishu#13 Level 3
          The password attribute action is for update and write : http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec17cba-7f 87.html
          Run the code mentioned below and then open the updatedFile.xls in excel. It will open in a protected view where you cannot make any modifications.
          CODE
          <!--- Read data from two datasource tables. --->
          <cfquery
                 name="courses" datasource="cfdocexamples"
                 cachedwithin="#CreateTimeSpan(0, 6, 0, 0)#">
                 SELECT CORNUMBER,DEPT_ID,COURSE_ID,CORNAME
                 FROM COURSELIST
          </cfquery>
          <cfquery
                 name="centers" datasource="cfdocexamples"
                 SELECT *
                 FROM CENTERS
          </cfquery>
          <cfscript>
              //Use an absolute path for the files. --->
                 theDir=GetDirectoryFromPath(GetCurrentTemplatePath());
              theFile=theDir & "courses.xls";
              //Create two empty ColdFusion spreadsheet objects. --->
              theSheet = SpreadsheetNew("CourseData");
              theSecondSheet = SpreadsheetNew("CentersData");
              //Populate each object with a query. --->
              SpreadsheetAddRows(theSheet,courses);
              SpreadsheetAddRows(theSecondSheet,centers);
          </cfscript>
          <!--- Write the two sheets to a single file --->
          <cfspreadsheet action="write" filename="#theFile#" name="theSheet"
              sheetname="courses" overwrite=true>
          <cfspreadsheet action="update" filename="#theFile#" name="theSecondSheet"
              sheetname="centers">
          <!--- Read all or part of the file into a spreadsheet object, CSV string,
                HTML string, and query. --->
          <cfspreadsheet action="read" src="#theFile#" sheetname="courses" name="spreadsheetData">
          <cfspreadsheet action="read" src="#theFile#" sheet=1 rows="3,4" format="csv" name="csvData">
          <cfspreadsheet action="read" src="#theFile#" format="html" rows="5-10" name="htmlData">
          <cfspreadsheet action="read" src="#theFile#" sheetname="centers" query="queryData">
          <h3>First sheet row 3 read as a CSV variable</h3>
          <cfdump var="#csvData#">
          <h3>Second sheet rows 5-10 read as an HTML variable</h3>
          <cfdump var="#htmlData#">
          <h3>Second sheet read as a query variable</h3>
          <cfdump var="#queryData#">
          <!--- Modify the courses sheet. --->
          <cfscript>
              SpreadsheetAddRow(spreadsheetData,"03,ENGL,230,Poetry 1",8,1);
              SpreadsheetAddColumn(spreadsheetData,
              "Basic,Intermediate,Advanced,Basic,Intermediate,Advanced,Basic,Intermediate,Advanced",
              3,2,true);
          </cfscript>
          <!--- Write the updated Courses sheet to a new XLS file   This one has the password--->
          <cfspreadsheet action="write" filename="#theDir#updatedFile.xls" name="spreadsheetData"
              sheetname="courses" overwrite=true password="test">
          <!--- Write an XLS file containing the data in the CSV variable.--->
          <cfspreadsheet action="write" filename="#theDir#dataFromCSV.xls" name="CSVData"
              format="csv" sheetname="courses" overwrite=true>
