2 Replies Latest reply on Mar 11, 2014 4:04 PM by JJMack
    how do i form collage in photoshop.Please help.
    FRAMES!!!!
        • 1. Re: how do i form collage in photoshop.Please help.
          And exactly? You need to explain or provide references. Nobody can explain to you how to create art in 5 minutes. If you have no prior experience, look up some tutorials and then come back with specific questions.
          Mylenium
          • 2. Re: how do i form collage in photoshop.Please help.
            Collages and Composites are one and the same thing they are documents with image layers  which are position and masked to form a composite.  PSD Template files are often used to aid the process of making such a composite.  I created a Photo Collage Toolkit to provide you with tools  that  can help if your using Photoshop.  Elements has a Collage Feature Photoshop does not for it easy to make them many diffent ways in Photoshop.  If you read the documentation for my toolkit you may see that Collages and Composite are the same only masking differs.
            Photoshop scripting is powerful and I believe this package demonstrates this.
            The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
            1. Size the photo collage templates for the print size you want - width, height and print DPI resolution.
            2. Photo collage templates must have a Photoshop background layer. The contents of this layer can be anything.
            3. Photo collage templates must have alpha channels named "Image 1", "Image 2", ... "Image n".
            4. Photo collage templates layers above the background layers must provide transparent areas to let the images that will be placed below them show through.
            There are twelve scripts in this package they provide the following functions:
            1. TestCollageTemplate.jsx - Used to test a Photo Collage Template while you are making it with Photoshop.
            2. CollageTemplateBuilder.jsx - Can build Templates compatible with this toolkit's scripts.
            3. LayerToAlphaChan.jsx - Used to convert a Prototype Image Layer stack into a template document.
            4. InteractivePopulateCollage.jsx - Used to interactively populate Any Photo Collage template. Offers most user control inserting pictures and text.
            5. ReplaceCollageImage.jsx - use to replace a populated collage image Smart Object layer with an other image correctly resized and positioned.
            6. ChangeTextSize.jsx - This script can be used to change Image stamps text size when the size used by the populating did not work well.
            7. PopulateCollageTemplate.jsx - Used to Automatically populate a Photo Collage template and leave the populated copy open in Photoshop.
            8. BatchOneImageCollage.jsx - Used to Automatically Batch Populate Collage templates that only have one image inserted. The Collage or Image may be stamped with text.
            9. BatchMultiImageCollage.jsx - Used to Automatically Batch Populate Any Photo Collage template with images in a source image folder. Easier to use than the interactive script. Saved collages can be tweaked.
            10. BatchPicturePackage.jsx - Used to Automatically Batch Populate Any Photo Collage template with an image in a source image folder
            11. PasteImageRoll.jsx - Paste Images into a document to be print on roll paper.
            12. PCTpreferences.jsx - Edit This File to Customize Collage Populating scripts default setting and add your own Layer styles.
            Documentatio, Examples and Download Link
            A Video Demo http://www.mouseprints.net/old/dpr/Populate911_720p.mp4
            http://www.mouseprints.net/old/dpr/BatchCollage/Collage_1_4_6x4+FDNYonTopG.jpg
