1 Reply Latest reply on Mar 23, 2014 4:41 PM by Zenek Demar
    I'm having trouble finishing up with Compound Paths
    sbelleque
      OK, I'm a novice here so here's my script. It works really well like it sits. It basically takes two objects in a large group and aligns them. I want to make each two objects combinded into a single compound path. I have tried multiple things and they all just kick out errors and what not. I can't seem to get my head around the vocabulary for the scripting but the darkness is starting to fade the more I do.
      #target Illustrator
                var idoc = app.activeDocument;
                var pi =idoc.compoundPathItems;
                var numn = prompt ("How Many Names?", "Enter Number of Names");
                var dd = prompt ("How far below name is the number?", "Enter Drop Distance");
                var nH = prompt ("How tall are the names?", "Enter Name Height in Inches");
                dd = parseFloat (dd);
                numn = parseInt (numn);
                nH = parseFloat (nH);
      for (j=0; j<numn; j++) {
                          var num = j + numn;
                          var numpath = pi[num];
                          var npath = pi[j];
                          var nName = 'name' + j;
                          var numName = 'number' + j;
                          var centWidth = pi[j].width / 72;
                          var centN = pi[num].width / 72;
                          var adjNum = (centWidth - centN) / 2;
                          var fhp = j*9.5*72;
                          var fvp = 0;
                          var nhp = (j*9.5*72) + (adjNum * 72);
                          var nvp = ((dd*72) + (nH * 72))*-1;
                          pi[j].name = nName;
                          pi[num].name = numName;
                          npath.position = [fhp,fvp];
                          numpath.position = [nhp,nvp];
      // Would Like to combine the aligned items into a single compound item.
        • 1. Re: I'm having trouble finishing up with Compound Paths
          Zenek Demar Level 1
          select few objects and try this to build up a new compound path.
          #target illustrator
          var doc = activeDocument;
          var sel = doc.selection;
          var newCompPath = doc.activeLayer.compoundPathItems.add()
          if (sel.length > 0) {
             for (var i=0; i<sel.length; i++) {
                  sel[i].evenodd = true;
                  sel[i].move(newCompPath, ElementPlacement.INSIDE);
