3 Replies Latest reply on Mar 12, 2014 5:32 AM by Peter Spier
    can't save any file with any name-InDesign CC
    bunsworth
      can't save any file with any name-file DBTmp4376-863643269 is damaged (error code:0)
      InDesign CC, OS version 10.9.1
      I explored solutions to failure in background task alert which did not work. Been using adobe products since they came on the scene. Nothing like this. Please help.
        • 1. Re: can't save any file with any name-InDesign CC
          Joel Cherney Level 5
          Any file? As in, you start a brand-new file, you try to save, and you get the "DBtmp etc is damaged" error?
          If you have a file you're trying to work on now and cannot save, I expect that you can export an IDML and save your work.
          Have you updated InDesign CC to 9.2?
          • 2. Re: can't save any file with any name-InDesign CC
            bunsworth Level 1
            I'm using version 9.2.
            Yes, it started with a new file. Support gave me the solution to save it to my desktop which worked. When I put it back in the original folder and opened/save it would not save to that folder. Created a new folder and was able to open & save to the new folder. That seems to be a workable solution. How a folder can become corrupt is a bit scarey.
            In experimenting with solutions I received another error "failure in background task alert" and discovered CS5 problems with background task.
            However the solutions for CS5 did not work in my incidence.
            I sure would like to prevent this from happening again. If you have any insights please share them. Otherwise I will just accept the experience as another computer workaround and be thankful that I have it.
            Thanks for responding.
            • 3. Re: can't save any file with any name-InDesign CC
              Sounds like a permissions issue on the folder.
