4 Replies Latest reply on Mar 14, 2014 8:38 AM by zeRafio
    Applescript: setting date for folder?
    ophello Level 1
      I have a script droplet for batch processing layouts and I have a part of the code that converts the date into a folder name.
      The problem is the date is output with one digit if it's a single-digit day. I need a zero before it.
      For example, a date of 3/6/14 goes through this part of the script:
                set shortDateString to short date string of (current date)
                set {oldTID, my text item delimiters} to {my text item delimiters, "/"}
                set dateBits to (text items of shortDateString)
                set my text item delimiters to ""
                set datePrefixString to (text item 3 of dateBits & text items 1 thru 2 of dateBits & "_Release") as text
                set my text item delimiters to oldTID
      And outputs this:
      1436_Release
      I need the output to be this:
      140306_release
      I can't figure it out -- your help is deeply appreciated!
        • 1. Re: Applescript: setting date for folder?
          Trevorׅ Adobe Community Professional
          I think you want something a bit more simple like
          set myDate to do shell script "date '+%y%m%d'" & "_release"
          HTH
          Trevor
          • 2. Re: Applescript: setting date for folder?
            This could be a long way which won't involve administrive rights issue's
            set yearstr to year of (current date) as string
            set yearstr to text -2 thru -1 of yearstr
            set monthnum to month of (current date) as integer
            if monthnum < 10 then
            set monthstr to "0" & (monthnum as string)
            else
            set monthstr to (monthnum as string)
            end if
            set daynum to (day of (current date)) as integer
            if daynum < 10 then
            set daystr to "0" & (daynum as string)
            else
            set daystr to (daynum as string)
            end if
            set myReleaseDate to yearstr & daystr & monthstr & "_release"
            • 3. Re: Applescript: setting date for folder?
              This would be a better way
              set myDate to (get current date)
              set y to year of myDate as text
              set d to day of myDate as integer
              set m to month of myDate as integer
              if d < 10 then
                  set d to "0" & d as text
              else
                  set d to d as text
              end if
              if m < 10 then
                  set m to "0" & m as text
              else
                  set m to m as text
              end if
              set y to text -2 thru -1 of y
              set myReleaseDate to y & d & m & "_release"
              • 4. Re: Applescript: setting date for folder?
                zeRafio Level 1
                For everyone who needs it in Applescript, this is a shorter way:
                With hyphens and date in 4 digits
                set a0 to short date string of (current date)
                set oldDelims to AppleScript's text item delimiters
                set AppleScript's text item delimiters to {"/"}
                set {a1, a2, a3} to text items of a0
                set AppleScript's text item delimiters to "-"
                set dateStamp to "20" & ({a3, a2, a1} as string)
                set AppleScript's text item delimiters to oldDelims
                Without hyphens and date in 2 digits
                set dateStamp to ({a3, a2, a1} as string)
