1 Reply Latest reply on Mar 13, 2014 6:35 AM by bqui
    SOAP issues
    bqui
      I'm new to this comunity.
      And I'm not shure if this is the right place for my question...
      This discussion was in 'Acrobat SDK', but now I think it's better in this forum...
      I'm working with Acrobat pro 11.0.06 on Mac OS X 10.8.5
      I try to connect from a PDF to a webservice via SOAP to get a database connection.
      The script sends some data to the service and expects a response with product data.
      The webservice is written in PHP.
      When I connect to the service via a php-script it works fine.
      This is the JavaScript function that calls the webservice:
      function getData()
                var vartnr = "123456789";
                var vartnr_teil = "";//"3456789";
                var vpreis = "";//"0,36";
                try {
                          SOAP.wireDump = "true";
                          var strURL = "http://test.mydomain.de/webservice.wsdl";
                          var service = SOAP.connect(strURL);
                          var thedata = {
                                    artnr: vartnr,
                                    artnr_teil: vartnr_teil,
                                    preis: vpreis
                          var results = service.getData(thedata);
                          app.alert(results);
                catch(e)
                          app.alert(e);
      When the script is running, I get an error message:
      'SOAPError: SOAP-ERROR: Encoding: Violation of encoding rules'.
      In the JavaScript-debugger of Acrobat I see the following message:
      <?xml version="1.0"?>
      <SOAP-ENV:Envelope xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
                <SOAP-ENV:Body>
                          <ns0:getData SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns0="urn:getData">
                                    <artnr>
                                              <artnr xsi:type="xsd:string">123456789</artnr>
                                              <artnr_teil xsi:type="xsd:string"></artnr_teil>
                                              <preis xsi:type="xsd:string"></preis>
                                    </artnr>
                                    <artnr_teil xsi:nil="true"/>
                                    <preis xsi:nil="true"/>
                          </ns0:getData>
                </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      <?xml version="1.0" encoding="UTF-8"?>
      <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
                <SOAP-ENV:Body>
                          <SOAP-ENV:Fault>
                                    <faultcode>SOAP-ENV:Server</faultcode>
                                    <faultstring>SOAP-ERROR: Encoding: Violation of encoding rules</faultstring>
                          </SOAP-ENV:Fault>
                </SOAP-ENV:Body>
      The first XML seems to represent the data that Acrobat sends to the webservice. The second XML seems to be the answer of the service.
      I don't know what exactly this means... where to look for the fault script...
      I see, that there is a bug in the first XML: '<artnr>' is closed twice.
      But this XML is generated throu the SOAP-object of Acrobat. So, I don't know how to change it.
      Any suggestions what to do?
      Thanks.
        • 1. Re: SOAP issues
          bqui Level 1
          Hello again,
          now I tried the same with Acobat pro 7 (7.1.0) on Windows XP.
          I got the same result: 'SOAP-ERROR: Encoding: Violation of encoding rules'.
          Mybe there are some lines in the wsdl-file, that cause this problem:
          <?xml version ='1.0' encoding ='UTF-8' ?>
          <definitions name='myService'
                    targetNamespace='http://test.mydomain.de/getData'
                    xmlns:tns='http://test.mydomain.de/getData'
                    xmlns:soap='http://schemas.xmlsoap.org/wsdl/soap/'
                    xmlns:xsd='http://www.w3.org/2001/XMLSchema'
                    xmlns:soapenc='http://schemas.xmlsoap.org/soap/encoding/'
                    xmlns:wsdl='http://schemas.xmlsoap.org/wsdl/'
                    xmlns='http://schemas.xmlsoap.org/wsdl/'>
                    <message name='addRequest'>
                              <part name='artnr' type='xsd:string'/>
                              <part name='artnr_teil' type='xsd:string'/>
                              <part name='preis' type='xsd:string'/>
                    </message>
                    <message name='addResponse'>
                              <part name='result' type='xsd:string'/>
                    </message>
                    <portType name='addPortType'>
                              <operation name='getData'>
                                        <input message='tns:addRequest'/>
                                        <output message='tns:addResponse'/>
                              </operation>
                    </portType>
                    <binding name='addBinding' type='tns:addPortType'>
                              <soap:binding style='rpc'
                              transport='http://schemas.xmlsoap.org/soap/http'/>
                                        <soap:operation soapAction='urn:myserver#getData'/>
                                        <input>
                                                  <soap:body use='encoded' namespace='urn:getData'
                                                  encodingStyle='http://schemas.xmlsoap.org/soap/encoding/'/>
                                        </input>
                                        <output>
                                        </output>
                              </operation>
                    </binding>
                    <service name='addService'>
                              <port name='addPort' binding='addBinding'>
                                        <soap:address location='http://test.mydomain.de/myserver.php'/>
                              </port>
                    </service>
          </definitions>
          So again: Any suggestions what to do?
          Thanks.
