9 Replies Latest reply on Mar 17, 2014 1:23 PM by rgg1880
    Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
    rgg1880
      I am currently using the 4.12.0 SDK.  I have a Spark DataGrid setup that makes use of an externally-defined itemRenderer:
      <s:DataGrid id="dgEquipment"
                  width="100%" height="100%"
                  doubleClickEnabled="true"
                  creationComplete="init()" doubleClick="popTab(event)">
        <s:columns>
          <s:ArrayList>
            <s:GridColumn itemRenderer="renderers.equipment.IconRenderer"
                          dataField="EXISTING"
                          width="22"/>
      The data provider is set programmatically after a remote call has returned a result.
      I have the renderer setup as follows:
      <s:GridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                          xmlns:mx="library://ns.adobe.com/flex/mx"
                          dataChange="init()" remove="dispose()">
        <s:layout>
          <s:VerticalLayout horizontalAlign="center" verticalAlign="middle"/>
        </s:layout>
        <fx:Script>
          <![CDATA[
            import mx.controls.Menu;
            import mx.events.MenuEvent;
            import spark.components.DataGrid;
            [Bindable]
            [Embed(source="../../../assets/images/Icon 1.png")]
            private var ico1:Class;
            [Bindable]
            [Embed(source="../../../assets/images/Icon 2.png")]
            private var ico2:Class;
            [Bindable]
            [Embed(source="../../../assets/images/Icon 3.png")]
            private var ico3:Class;
            private var isExisting:Boolean;
            private var popUp:Menu;
            private function init():void
              if (data)
                isExisting = data.EXISTING == 1;
            private function dispose():void
              if (popUp)
                popUp.removeEventListener(MenuEvent.ITEM_CLICK, popUp_click);
                popUp = null;
              if (imgActions)
                imgActions.removeEventListener(MouseEvent.CLICK, image_click);
                imgActions = null;
            override public function prepare(hasBeenRecycled:Boolean):void
              if (data)
                if ((data.TYPE == "A" || data.TYPE == "B") && !data.X && !data.Y)
                  disableLink();
                  imgActions.source = ico3;
                  imgActions.toolTip = "Blah blah.";
                else if (data.TYPE == "C" || data.TYPE == "D")
                  disableLink();
                else if (isExisting)
                  imgActions.source = ico1;  //******************************            imgActions.toolTip = "More blah blah.";
                  imgActions.addEventListener(MouseEvent.CLICK, image_click);
                else
                  imgActions.source = ico2;
                  imgActions.toolTip = "Even more blah blah.";
                  initPopUp();
            private function initPopUp():void
            private function popUp_click(event:MenuEvent):void
            private function image_click(event:MouseEvent):void
            private function disableLink():void
        </fx:Script>
        <s:Image id="imgActions"
                 height="18" width="18"/>
      </s:GridItemRenderer>
      When the code reaches the line where I have added a comment full of asterisks, I get the following error:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at renderers.equipment::IconRenderer/prepare()[C:\…\renderers\equipment\IconRenderer.mxml:81 ]
          at spark.components.gridClasses::GridViewLayout/initializeItemRenderer()[/Users/justinmclean /Documents/ApacheFlex4.12.0/frameworks/projects/spark/src/spark/components/gridClasses/Gri dViewLayout.as:1808]
          at spark.components.gridClasses::GridViewLayout/createTypicalItemRenderer()[/Users/justinmcl ean/Documents/ApacheFlex4.12.0/frameworks/projects/spark/src/spark/components/gridClasses/ GridViewLayout.as:1243]
          at spark.components.gridClasses::GridViewLayout/updateTypicalCellSizes()[/Users/justinmclean /Documents/ApacheFlex4.12.0/frameworks/projects/spark/src/spark/components/gridClasses/Gri dViewLayout.as:1374]
          at spark.components.gridClasses::GridViewLayout/measure()[/Users/justinmclean/Documents/Apac heFlex4.12.0/frameworks/projects/spark/src/spark/components/gridClasses/GridViewLayout.as: 875]
          at spark.components.supportClasses::GroupBase/measure()[/Users/justinmclean/Documents/Apache Flex4.12.0/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as:1156 ]
          at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::measureSizes()[/Users/justinmclean/Documents/ApacheFlex4.12.0/frameworks/projects/framework/src/mx/cor e/UIComponent.as:9038]
          at mx.core::UIComponent/validateSize()[/Users/justinmclean/Documents/ApacheFlex4.12.0/framew orks/projects/framework/src/mx/core/UIComponent.as:8962]
          at spark.components::Group/validateSize()[/Users/justinmclean/Documents/ApacheFlex4.12.0/fra meworks/projects/spark/src/spark/components/Group.as:1074]
          at mx.managers::LayoutManager/validateSize()[/Users/justinmclean/Documents/ApacheFlex4.12.0/ frameworks/projects/framework/src/mx/managers/LayoutManager.as:673]
          at mx.managers::LayoutManager/doPhasedInstantiation()[/Users/justinmclean/Documents/ApacheFl ex4.12.0/frameworks/projects/framework/src/mx/managers/LayoutManager.as:824]
          at mx.managers::LayoutManager/doPhasedInstantiationCallback()[/Users/justinmclean/Documents/ ApacheFlex4.12.0/frameworks/projects/framework/src/mx/managers/LayoutManager.as:1188]
      Running the debugger shows that this occurs with the first item in the data provider.  If I alter the prepare method to check for the existence of imgActions before doing anything, everything works fine after the first item.  So I'll have one row in the DataGrid with a missing icon, and all the rest will have icons.
      So the question is, is it normal for prepare to run before any children of the item renderer are created?  If so, how should I handle this?
      Many thanks in advance.
        • 1. Re: Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
          rgg1880 Level 1
          A little more info.  I added some event handlers to the renderer and the image (for events that I thought would be relevant), and here is the order of events based on trace statements within the handlers:
          griditemrenderer1_addedHandler
          griditemrenderer1_addedToStageHandler
          griditemrenderer1_preinitializeHandler
          imgActions_addedHandler
          imgActions_addedToStageHandler
          imgActions_preinitializeHandler
          imgActions_initializeHandler
          griditemrenderer1_elementAddHandler
          imgActions_addHandler
          griditemrenderer1_initializeHandler
          griditemrenderer1_addHandler
          prepare called
          imgActions_resizeHandler
          griditemrenderer1_resizeHandler
          imgActions_creationCompleteHandler
          imgActions_updateCompleteHandler
          griditemrenderer1_creationCompleteHandler
          griditemrenderer1_updateCompleteHandler
          griditemrenderer1_removeHandler
          griditemrenderer1_dataChangeHandlerTypeError: Error #1009: Cannot access a property or method of a null object reference.
          prepare called
              at renderers.equipment::IconRenderer/prepare()[C:\…\renderers\equipment\IconRenderer.mxml:91 ]
          imgActions_renderHandler
          griditemrenderer1_renderHandler
          • 2. Re: Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
            rgg1880 Level 1
            A little more info.
            First, imgActions is in existance before the addedToStage event occurs.
            Second, when the error occurs, the debugger shows the following:
            imgActionsnull
            this.getChildAt(0).idimgActions
            So apparently the image exists, but it also doesn't.
            Message was edited by: rgg1880 (added a table for values)
            Message was edited by: rgg1880 (add the first info item)
            • 3. Re: Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
              Flex harUI Adobe Employee
              You can try binding.  Declare a bindable variable:
              private var imgsrc:String;
              Set imgsrc in your code instead of imgactions
              Bind imgactions:
                <s:Image id="imgActions" source="{imgsrc}"
              • 4. Re: Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
                rgg1880 Level 1
                Just that one change will still leave me with the same error on the next line, where I set the image's tool tip.  I could use binding for that as well, but the line after that one (in certain situations) adds an event listener to the image.  Almost any path through the prepare method changes the image's properties, which won't work when the image suddenly becomes null.  Also, I thought writing out a prepare method was supposed to be a more efficient alternative to binding, but it pretty much defeats the purpose if the method is called when the renderer's children aren't available.
                • 5. Re: Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
                  You're right that binding has extra overhead.  The AS equivalent is to use try/catch to catch exceptions or check for null values before assigning.
                  • 6. Re: Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
                    rgg1880 Level 1
                    If at the start of the prepare method I check to make sure that data isn't null and that imgActions isn't null, it will, of course, avoid any errors.  But even though prepare initially works for the first item in my DataGrid, it eventually fails for that same item, and it doesn't fix itself.  Then all the other rows turn out as expected.  I'm currently using quite a hack: at the beginning of prepare, if data isn't null, I declare a local variable of type Image.  I set it to imgActions if it exists; if it doesn't exist and the first child of the renderer has an id of "imgActions," I set the variable to that child instead.  And so far it has worked.  It just makes a programmer feel like an English teacher reading an essay full of botched grammar.
                    • 8. Re: Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
                      rgg1880 Level 1
                      I got it down to this, and everything is working fine:
                      <!--?xml version="1.0" encoding="utf-8"?-->
                                          xmlns:mx="library://ns.adobe.com/flex/mx">
                        <fx:Script>
                          <![CDATA[
                            import spark.components.Image;
                            [Bindable]
                            [Bindable]
                            [Bindable]
                              if (data)
                                else if (data.EXISTING == 1)
                                else
                        </fx:Script>
                      I'm guessing the issue was with my disableLink() function, which modified some of imgActions' properties and (I assume) forced it to redraw.
                      • 9. Re: Overriding Spark DataGrid item renderer's prepare method - renderer's child is initially null
                        rgg1880 Level 1
                        Actually, the disableLink() function doesn't run before the null exception occurs.  I did, however, set a handler for the "remove" event on the GridItemRenderer, and that handler sets the image to null.  Apparently the renderer is removed before it's actually used, and when it's brought back, the image is still null.
