14 Replies Latest reply on Mar 14, 2014 11:05 AM by bocking
    can't insert a image
    bocking Level 1
      hi, i can't insert image or drag and drop a image on dw-cs6, i get a pop-up box saying go to invisible elements in preferences, did that still can't insert image, please help
        • 1. Re: can't insert a image
          Jon Fritz II Adobe Community Professional & MVP
          What kind of image are you trying to insert?
          Have you tried any troubleshooting steps as of yet (restarting program/computer, clearing cache, etc)?
          What is the exact pop up message?
          • 2. Re: can't insert a image
            bocking Level 1
            image is jpg
            pop-up box saids you won't se this element unless you view >invisible elements is checked, and the preferences settings for this element is on
            i don't know how to clear cache
            • 3. Re: can't insert a image
              That's very odd, a .jpeg isn't an invisible element in DW, nor ar there any settings to make it invisible as I'm sure you've noticed.
              What are the exact steps you are taking to insert it?
              Where in the page are you trying to insert it? (pasting the code here in the forum may provide a clue)
              Maybe DW thinks you're trying to add something else, or you're adding it to the wrong location and it's getting confused.
              • 4. Re: can't insert a image
                Are you attempting to insert an image inside an APDiv?
                Try moving your cursor in Code view to a better insertion point inside your <body> tag.
                     <img src="your_image.jpg">
                Nancy O.
                • 5. Re: can't insert a image
                  bocking Level 1
                  insert image in front of Joshua<head>
                        <!-- Copyright 2000, 2001, 2002, 2003 Macromedia, Inc. All rights reserved. -->
                        <!-- MENU-LOCATION=NONE -->
                        <html xmlns:mmstring="http://www.macromedia.com/schemes/data/string/">
                        <head>
                  Joshua Tree National Park (see photo on  right), on the other hand, I often went a hour without seeing another human  being. The park&rsquo;s name, by the way, comes from the large number of giant  yuccas, which nineteenth-century Mormon settlers said reminded them of the  Biblical story when Joshua reaches his arms up to the sky in prayer. As well as  giant yuccas, the Joshua Tree National Park is notable for strange rock  formations, sculpted by the combination of volcanic action, water, and wind  erosion. Over time, flash floods have washed away the protective ground  surface, exposing piles of boulders.</p>
                  <h1> </h1>
                  • 6. Re: can't insert a image
                    bocking Level 1
                    not an APdiv Inserting image in front of paragrah <head>
                          <head>
                    <h1> </h1>
                    • 7. Re: can't insert a image
                      That's not a valid HTML document.  What application are you using?
                      Nancy O.
                      • 8. Re: can't insert a image
                        bocking Level 1
                        i'am practicing on a instructional website, i'am in split in css mode
                        • 9. Re: can't insert a image
                          bocking Level 1
                          hi, i have two computers the other one everything works just find why is that
                          • 10. Re: can't insert a image
                            bocking Level 1
                            hi, i have two computers on the other one everything works just find why is that
                            • 11. Re: can't insert a image
                              bregent Most Valuable Participant
                              I surprised one even works at all. DW works best with valid documents. Yours is not even close. You have no body tags. Start with a new valid document and I'm sure it will work.
                              • 12. Re: can't insert a image
                                bregent is absolutely right here. You are missing most of your document's required structural tags.
                                You are basically attempting to insert an image into your <head> section, which in and of itself is an invisible item to DW. The <head></head> section is for javascripts, css, page title, links to external scripts/files, meta information and a few other, very specific items.
                                Have a look at the tutorials here: http://w3schools.com/html and http://www.w3schools.com/css they should give you a good understanding of what's wrong with your page as it sits now.
                                • 13. Re: can't insert a image
                                  This makes absolutely no sense.  It doesn't even look like a Dreamweaver document.
                                        <head>
                                  Try this instead of what you have now.
                                  <!doctype html>
                                  <html>
                                  <head>
                                  <meta charset="utf-8">
                                  <title>Untitled Document</title>
                                  </head>
                                  <body>
                                  INSERT YOUR IMAGE HERE...
                                  </body>
                                  </html>
                                  Nancy O.
                                  • 14. Re: can't insert a image
                                    bocking Level 1
                                    fixed, uninstalled dw software then reinstalled it did not lose any files and i'am inserting images thanks for support
