5 Replies Latest reply on Mar 17, 2014 1:34 PM by Erniegar
    Huge file size?
    Erniegar Level 1
      Hi all,
      I am creating as very basic Director file (or so i thought) in Director 10.1 with some pictures in.  There are about 20 images and each one is about 200-400kb each.
      Yet when I import them they come in as a huge filesize!?!?  This has never happened to me before...
      When I look at the side panel it tells me they are bitmaps with a file size of, for example, 23.7MB but I know its just a jpg of a few hundred kbs.
      As a result my dir file, and thereafter my dxr file, is huge when the content therein is just a few megabytes in total.
      I have never had this before - all my previous projects are a reasonable size?
      Please can anyone advise?
      Thanks...
        • 1. Re: Huge file size?
          jackblackweb Level 1
          Hey Ernieger,
          What platform?
          jpg files seem to be deprecating.
          png files may work.
          Jack
          • 2. Re: Huge file size?
            Sean_Wilson Adobe Community Professional
            If you publish the file to DCR you'll regain the file size. Director decompresses/expands JPEGs on import so that they display as quickly as possible, without requiring prior decompression
            • 3. Re: Huge file size?
              Milky_au Level 3
              just an idea...
              with the property inspector turned on
              select the bitmap tag
              under 'compression' change it from 'Movie Setting" to 'JPEG'
              I believe Director brings in all graphics uncompressed - only compresses them upon publishing
              So if you want to publish an .exe with lots of large graphics - and you don't turn on 'Compress Files (shockwave format)' under files - in the publish settings,
              or you wish to get your files even smaller - then you can play around with lower jpeg settings
              • 4. Re: Huge file size?
                Erniegar Level 1
                Hi all,
                Unfortunately these suggestions are not working...
                Its still a huge filesize when I import a png (bigger even!)
                Its already set on the jpeg settings and changing that does not help.
                I am instructed to submit in dxr format so need to do so.
                I am using 10.1 on Windows 7.
                With a deadline looming, I'd be very grateful for any more suggestions...?
                Thanks...
                • 5. Re: Huge file size?
                  Erniegar Level 1
                  I am now able to submit in dcr format, so alls well that ends well, with thanks to all....
