1. Re: How To Install OS on Raid0?
Peru Bob Mar 12, 2014 3:06 PM (in response to Trevor Dennis)If you search this forum, you will find:
1) The Samsung Evo is not recommended. The Samsung Pro is.
2) Raid for the OS drive is of no significant benefit.
2. Re: How To Install OS on Raid0?
Trevor Dennis Mar 12, 2014 3:31 PM (in response to Peru Bob)Thanks for your input Bob.
My thought were that with a 500Gb C: drive with that much performance, I would be able to use it for more than the OS. Some of the things that I currently have on the other drives could stay on the C: drive. Note that Photoshop is by far my main use with this system.
I'll try and intercept the order and see if I am too late to change to the Pro drives. (their phone is engaged right now)
3. Re: How To Install OS on Raid0?
Trevor Dennis Mar 12, 2014 4:18 PM (in response to Trevor Dennis)OK, I was able to intercept the order and change it to a pair of Samsung 256Gb 840 Pro drives. I have also found threads discussing the difference between the EVO and Pro drives, so thanks Bob for the heads up in time for me to change the order.
I expect I can muddle through the set up and reinstall, with some help from Google, but I am just a bit nervous about the process, and specifically when I'll get the chance to install the Intel driver, and how on earth I install Windows to an array that won't exist until I install the driver.
4. Re: How To Install OS on Raid0?
Bill Gehrke Mar 12, 2014 4:49 PM (in response to Trevor Dennis)It is a major mistake to install your OS and APPs on a RAID 0 array. Recovery tools generally will not work on RAID arrays. Keep your OS and Apps on a single drive.
5. Re: How To Install OS on Raid0?
Trevor Dennis Mar 12, 2014 5:01 PM (in response to Bill Gehrke)Thanks Bill. We see so many systems with a raid0 boot drive nowadays, I didn't even consider it to be an issue. Noel Carboni on the Photoshop forum is proud of his multi drive SSD raid0 that he uses for _everything_, although Noel is only a Photoshop guy, and software engineer. I also have an MSI laptop that came as standard with two SSDs in a raid0 for the boot drive (MSI GT70).
Regards recovery tools, I have Shadow Protect, but have not used its boot drive image feature up to now. I don't know if that would cover me for a lost boot drive?
BTW I have worked out how and when to install the drivers. I am also committed to the two drives now, so just have to decide how to use them.
6. Re: How To Install OS on Raid0?
Peru Bob Mar 13, 2014 9:56 AM (in response to Trevor Dennis)Use one as an OS drive and clone it to the other one so you have a backup.
