2 Replies Latest reply on Mar 12, 2014 3:14 PM by aslogrd
    I need help with InDesign Error messages (bad Plug-ins)
    aslogrd
      I get "Startup Alerts" when trying to launch InDesign. Does not recognize a series of Plug-ins.
      Error 1:
      Cannot load the Swatch Library Panel.InDesignPlugin plug-in. It is dependent on the Swatches Panel.InDesignPlugin plug-in, which failed to load. Please check documentation for the Swatches Panel.InDesignPlugin plug-in.
      Error 2:
      Cannot load the Transparency UI.InDesignPlugin plug-in. It is dependent on the Swatches Panel.InDesignPlugin plug-in, which failed to load. Please check documentation for the Swatches Panel.InDesignPlugin plug-in.
      Error 3:
      Cannot load the ObjectStylesUI.InDesignPlugin plug-in. It is dependent on the Transparency UI.InDesignPlugin plug-in, which failed to load. Please check documentation for the Transparency UI.InDesignPlugin plug-in.
      Error 4:
      Cannot load the Text Color Panel.InDesignPlugin plug-in. It is dependent on the Swatches Panel.InDesignPlugin plug-in, which failed to load. Please check documentation for the Swatches Panel.InDesignPlugin plug-in.
