1 Reply Latest reply: Mar 13, 2014 8:34 AM by Steve Sommers RSS
    Database connnection error
    userCold9 Community Member
      I am have an issue with trying to verify the database connections from Cold Fusion administration to the MS SQL Server 2008.
      The two servers were fully backed up from a production environment and placed on two VM servers. The SQL Server had a DC connected to it but it was removed and the services were reassigned to another account by the DBA.
      All SQL Server services are up and running.
      The Cold Fusion services are up and running.
      The port from the Cold Fusion server to the SQL Server has been opened.
      I have stopped and restarted the Cold Fusion Services.
      Below is the information about the environment and error received:
      Environment
      SQL Server:
      SQL Server 2008 R2 Enterprise
      Cold Fusion Server:
      Cold Fusion 9 Enterprise
      When trying to verify the database connections from the Cold Fusion administration to the SQL Server the following message appeared:
      Connection verification failed for data source: BUS_ULTC_TRAINING
      java.sql.SQLException: Timed out trying to establish connection
      The root cause was that: java.sql.SQLException: Timed out trying to establish connection
      The message in the log file is:
      Thread: jrpp-10, processing template: D:\CFADMIN\CFIDE\administrator\datasources\index.cfm, completed in 30 seconds, exceeding the 30 second warning limit
      Note: I tried to look at the contents of the index.cfm and and the file looked like is was encrypted.
      Mike
        • 1. Re: Database connnection error
          Steve Sommers Community Member
          From my experience, the data path from the CF server to the SQL server is broken, the correct protocol is not being used by the client (CF) or the service and/or protocol has not been enabled on the SQL server. I almost exclusively use IP connectivity to SQL servers so these steps are geared toward IP diagnosis. On the SQL server:
          1. Check that the SQL server service is running
          2. Check and make sure the SQL server has the IP protocol enabled (with newer SQL versions it is not enabled by default)
          On the CF server, open a command prompt and try the following:
          1. If using SQL server name: ping [server name]
          2. See if you can connect via telnet: telnet [SQL server IP] 1433
          3. Again, if using SQL server name: confirm SQL client alias exists and has correct protocol selected
          4. I have learned to avoid the alias step by using IP address instead of name
          Hope this helps. Good luck.
