Hi I am not a coder, and I need some coding help with google ClickTag parameters in AS3.
Any help would be greatly appreciated.
I’m doing a Flash banner for display network on google adwords, after completing the flash and tried to upload it to google I got this message:
“ClickTag is required, but not found.”
I went through clickTAG instructions from Google and got the code:
import flash.events.MouseEvent;
import flash.net.URLRequest;
someButton_or_displayObject_to_receive_mouseClick.addEventListener(
MouseEvent.CLICK,
function(event: MouseEvent) : void {
flash.net.navigateToURL(new URLRequest( root.loaderInfo.parameters.clickTAG), "_blank");
aswell as changing the “someButton_or_displayObject_to_receive_mouseClick” with the actual name of button that will receive the click.
I added a layer and created a “symbol” button with a (hit) that covers the full banner.
Made sure the name of the property and the button are “button”
I got it to the front of the banner and added this code:
button.addEventListener(
MouseEvent.CLICK,
I got no errors from flash professional and thought that it’s done.
But google adwords still say :
When I upload it !
I tried adding “root”. And tried “ _level0” but it didn’t work and got error messages.
I tried everything I found on the internet to fix this problem, but I wasn’t able to ….
Would appreciate if anyone can help me out figure whats wrong!
Thanks in advance
Normally the clickTAG parameter itself is defined in the html's swf embedding code. WHo manages that, you or Google?
It is better to not build the function in-line with the listener....
button.addEventListener(MouseEvent.CLICK, linkURL);
function linkURL(event: MouseEvent) : void {
Thanks for the reply,
I'm pretty sure that google embeds the code in here display platforms on the websites...
I never saw anything that needed embedding or any required "coding skills", and i did learn any when i took an adwords course.
non the less i took another look and seems to me that google manages and only needs the ad to support clickTAG ---
maybe i missed something ( English is my 3rd language so sorry for misspelling or for not misunderstanding)
i will quote:
Google doesn't allow Flash ads that don't support the clickTAG variable. The clickTAG is the tracking code assigned by Google to an individual ad. It allows Google to register where the ad was displayed when it was clicked and helps advertisers determine the effectiveness of their campaign.
- On any click, Flash ads should redirect to the URL specified in the clickTAG argument; there should be no other redirection in between.
- The variable name must be spelled "clickTAG" (upper-case TAG; no space between click and TAG) and not "click tag," "Click Tag," or any other form.
I manage my own adwords account and online marketing, though i always used the text ads and not displays and image/swf ones.
i was hoping you'll get here as i made a long search and saw this thread before posting and it kinda helped me get here :
http://forums.adobe.com/message/5669826#5669826
I changed the code to the one you sent me and i still get the clickTAG notice: ClickTag is required, but not found.
anything you think that i should try ?! (been trying stuff for hours and hours)
Is your Flash file an Actionscript 3 file? (I'm just fishing for ideas)
Thanks for trying
yes it's an actionscript 3 file ...
i used the preset advertising templates from flash and didn't do any changes in the Actionscript settings (which are set at AS3)
Awsome! It worked for me. Took me about 4 hours before I found this answer.
Thank you Ned
actually for google Ad-Words you'll need script like
button.addEventListener (MouseEvent.CLICK, goToLink);
function goToLink( event: MouseEvent ) : void {
if ( root.loaderInfo.parameters.clickTAG.substr (0,5) == "http:") {
flash.net.navigateToURL ( new URLRequest(root.loaderInfo.parameters.clickTAG), "_blank"
i've tried and it's working for now.
