8 Replies Latest reply on Mar 30, 2014 5:45 AM by Kai Rübsamen
    Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
    The Gothamite Level 1
      Aloha everyone
      I'm in need of a bit of help. So I'm working on a Textile-conversion script and I'm almost done (with a lot of thanks to you guys), That last bit concerns tables. And all I need to do is basically take it out of the main text field and make a separate one.
      So this is a table with one header row as seen in Textile.
      |_. name |_. age |_. sex |
      | joan | 24 | f |
      | archie | 29 | m |
      | bella | 45 | f |
      And from this, I produce a table with the style "RedTable2" using this code.
      // current selection
      var curSel = app.selection[0];
      // reset searchparameters
      app.findGrepPreferences = app.changeGrepPreferences = null;
      // set search parameters
      app.findGrepPreferences.findWhat = "(\\|.+\\r)+\\|.+";
      var result = curSel.findGrep( true );
      app.findGrepPreferences = null;
      // loop through findings
      for ( var f = 0; f < result.length; f++ ) {
                // last finding
                var curRes = result[f];
                // convert to table
                var curTable = curRes.convertToTable("|");
                // delete first and last row
                curTable.columns[0].remove();
                curTable.columns[-1].remove();
                // fit table to frame (doesn't always quite work)
                var tFrame = curTable.parent;
                var fWidth = tFrame.geometricBounds[3] - tFrame.geometricBounds[1];
                curTable.width = fWidth;
                // make first table a header row
                curTable.rows[0].rowType = RowTypes.headerRow;
                // add Style
                curTable.appliedTableStyle = "RedTable2";
                // delete formatting that doesn't fit RedTable2
                curTable.clearTableStyleOverrides( true );
                // Delete Textile Header Row formatting
                app.findGrepPreferences.findWhat = "\\s+$|^\\s+";
                app.changeGrepPreferences.changeTo = "";
                curTable.changeGrep();
           app.findGrepPreferences.findWhat = "_\\. ";
      Now, that last bit I need is this.
      • The converted table should be in a new Text Field, separate from the source text I can find.
      • Can I set the text wrap of that new text field to Jump Object and add a top and bottom offset of 7mm?
        • 1. Re: Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
          Kai Rübsamen Level 4
          First of all, it is verry uncool, if you ask your questions in multiple forums. Feel free, to choose only one forum for your questions (see also your hyperlinks-thread)
          It seems that you posted my code here. As I told you at hds, it is always a good idea to provide some examples, before / after. It is not clear what "should be in a new Text Field" means and why you need that.
          • 2. Re: Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
            Hey Kai,
            Nice to see you here. I am very sorry to have offended you. While it's perfectly obvious that I shouldn't crosspost code-things, it seriously didn't occur to me in the heat of the moment. I apologize. I won't do it again.
            And after one of the busiest few days I've had in a long long while, I can follow this up with an example. As I don't do the content of the boxes, I work with a lot of example and Llorem ipsum. I'm just doing layouts. So you'll have to make do with silly text everywhere, I'm afraid.
            Let's say I have this.
            http://i.imgur.com/Ec1Y7qS.jpg
            And then I run my script. The script does its thing and this should be the outcome.
            http://i.imgur.com/frAImvI.jpg
            The settings on that table are TableStyle = "RedTable" and the text wrap is set to "Wrap around bounding box". Basically, I would be happy if the new text frame with the table inside it would float somewhere outside the text frame it came from. Basically, in sight of where it was found or something.
            I even had time to fidget around some code earlier today and I came up with this. This generates two text boxes for some reason.
                app.activeDocument.textFrames.add ();
                var myFrame = app.activeDocument.textFrames.add ();
                myFrame.geometricBounds = ["30pt", "30pt", "300pt", "200pt"];
            I suspect it has to do with the two 30s in there, but if I remove those, the code goes bust. I also fail to get the content from the textframe with the main text into the newly created textframe.
            • 3. Re: Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
              Sorry, I did not understand the target here …
              Please provide a idml-file with the start-state and your final-state. I must have a look at your table style and did not understand why you want to create a new textframe.
              btw: You get two texttframes, because you create two with "add".
              var curDoc = app.activeDocument;
              var curFrame = curDoc.textFrames.add( {geometricBounds: ["30pt", "30pt", "300pt", "200pt"]} );
              • 4. Re: Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
                The goal of the entire exercise is this: For ease of layout, the tables need to be in separate text fields. So the script will create the tables, put them in separate text fields and move them out of the way for the time being until a human comes along and drags them into the place where they fit best.
                And here's an IDML for you to experiment around with: http://www.sendspace.com/file/3jyi12
                Also, I don't understand where I create the second text frame there. According to me, I create only one where I give the four reference points needed for a text frame to be created. Where exactly are the bits that make a second frame? And how do I get it to no longer create a second frame?
                All in all, tables in InDesign are a neverending source of confusion for me.
                • 5. Re: Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
                  A quick answer to this part:
                  ... where you did this:
                      app.activeDocument.textFrames.add ();   #1
                      var myFrame = app.activeDocument.textFrames.add ();   #2
                  Capisce?
                  • 6. Re: Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
                    I haven’t the time, to investigate here further, sorry. As a script beginner, it needs much more time for me, than a pro would need for that. So maybe others could dive in here or you must investigate in a paid-script.
                    What I have so far:
                    1. To get the position of the frames, I would anchor them at the first position of the current found (and maybe release them later)
                    2. To have more control of the position, the next version of the script assumes a objectStyle "Marginalien" with custom anchored settings
                    3. There a two ways to bring your table in the anchored frame:
                    a) Create your table first and move the table to the new textFrame >> Did not know how to do that, since I had serveral problems with the index
                    b) Create the textframe first, move the found to the new frame and convert then to table >> In this case I’m wondering why I get no index issues, but it worked
                    // das aktuelle Dokument
                    // die aktuelle Auswahl
                    // die Sucheinstellungen zurücksetzen
                    // die Sucheinstellungen setzen
                    // eine Schleife durch die Fundstellen
                        // die letzte Fundstelle
                        var curResult = result[f];
                        var iP = curResult.insertionPoints[0];
                        var newTf = iP.textFrames.add({geometricBounds: [ 0, 0, "30mm", "80mm"]});
                        newTf.appliedObjectStyle = curDoc.objectStyles.itemByName("Marginalien");
                        var newContent = curResult.move(LocationOptions.AFTER, newTf.insertionPoints[0]);
                        // Fundstelle in Tabelle konvertieren
                        var curTable = newContent.convertToTable("|");
                        // Erste und letzte Spalte löschen
                        // Tabelle wieder an Textrahmen anpassen
                        // Erste Zeile in Kopfzeile wandeln
                        // Tabellenformat zuweisen
                        curTable.appliedTableStyle = "Redtable";
                        // vorsichtshalber Abweichungen vom Tabellenformat löschen
                        // den Whitespace säubern
                        app.findGrepPreferences.findWhat = "_\\.\\s|\\s+$|^\\s+";
                    For own interest:
                    It would be great, if someone could show me on a simple example, how I can add a frame before a given table and move the table (or the paragraph that holds the table) to that frame. At the moment I get a warning here, something like: You cannot move the content to the same position.
                    kai
                    • 7. Re: Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
                      I think I can help you with at least pointing you in a direction with that one. I have found a commandline that moves something from somewhere to somewhere else. I have very little idea of how it works, but it does as I have moved around things using that thing.
                      var myParagraph = myTextFrame.paragraphs.item(0);
                      var myDestinationTextFrame = myDestinationPage.textFrames.add(undefined, undefined, undefined, {geometricBounds:["30mm", "50mm", "200mm", "170mm"]});
                      myParagraph.move(LocationOptions.atBeginning, myDestinationTextFrame.parentStory);
                      Basically, at this point in my horribly broken and completely unusable piece of junk script, I create the table, assign the style, clear the cells and then move the created table to that textfield. Does that help at all? EDIT: Also, I read somewhere that InDesign doesn't like it when you're trying to move all text in a textframe. I haven't tried that one out yet, but I can believe it.
                      Also, yes, of course. I see now where I created the second text frame. I feel stupid now. As an excuse, I present this: I was too focused on the numbers.
                      • 8. Re: Textile-Conversion: Can create Table with Style applied, but need to have it in separate Textfield
                        Your lines are not really helpful!
                        The following code should solve your problem verry close to your example. At the moment the table will be anchored in the paragraph with content before. The position of the table-frame is controlled by the object style "Marginalien".
                            var curIP = curResult.insertionPoints[0].index;
                            var curStory = curResult.parentStory;
                            var IPs = curStory.insertionPoints.itemByRange(0 , curIP);
                            var nParas = IPs.paragraphs.length-1;
                            if ( curStory.paragraphs[nParas].contents == "\r" ) {
                                curStory.paragraphs[nParas].remove();
                                var a = curStory.paragraphs[nParas-1].insertionPoints[0];
                            else {
                            var a = curStory.paragraphs[nParas].insertionPoints[0];
                            var newTf = a.textFrames.add({geometricBounds: [ 0, 0, "30mm", "80mm"]});
                        // die überflüssigen Returns löschen
                        app.findGrepPreferences.findWhat = "(?<=\\r)\\r+";
                        app.changeGrepPreferences.changeTo = "\\r";
                        curDoc.changeGrep();
