7 Replies Latest reply on Mar 14, 2014 4:17 PM by UncaPathy
    Unable to re-install Flash Player 12
    UncaPathy
      I have Windows 7 w/SP 1 and IE 10. Flash Player quit working morning of Mach 12; did work the evening before. I un-installed Flash Player after numerous attempts of following the help on enabling it. Then was unable to re-install. I have followed the uninstall/install instructions on the Flash Player web site many times without success.
      As a side note this is a fresh install of windows after re-formatting the HDD the last week of February this year.
        • 1. Re: Unable to re-install Flash Player 12
          Mike M Level 6
          You should be able to do a "clean install" http://forums.adobe.com/message/4041846
          • 2. Re: Unable to re-install Flash Player 12
            UncaPathy Level 1
            Already tried that, doesn't work.
            • 3. Re: Unable to re-install Flash Player 12
              maria__ Adobe Employee
              Hello,
              When you say "Then was unable to re-install." What do you mean?  Was there an error during installation, or did it install, but Flash does not display?
              Please post the contents of the FlashInstall.log file?  If you have a 64-bit OS, there will be two files, please post both.  Locations are:
              • C:\Windows\System32\Macromed\Flash
              • C:\Windows\SysWOW64\Macromed\Flash
              If the files are very large, you can post just the last portion, from March.
              Thank you in advance.
              Maria
              • 4. Re: Unable to re-install Flash Player 12
                UncaPathy Level 1
                No error messages displayed as long as I shut down IE at some point. Flash does not display and is not "found" by windows.
                64-Bit:
                =O====== M/12.0.0.77 2014-03-14+16-21-55.314 ========
                0000 [I] 00000010 "C:\Users\Harry\AppData\Local\Adobe\AIH.c1c0122cb42212923a4536ecd9576bc598161594\install_ flash_player_ax.exe" -install -iv 8 -au 1
                0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/12.0 2
                0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                0003 [I] 00000011 1
                0004 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0006 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_12_0_0_77.ocx
                0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
                0008 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
                0009 [I] 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
                0010 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                0011 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0012 [I] 00000012
                =X====== M/12.0.0.77 2014-03-14+16-21-58.016 ========
                • 5. Re: Unable to re-install Flash Player 12
                  UncaPathy Level 1
                  32-bit:
                  0003 [I] 00000011 1
                  0012 [I] 00000012
                  • 6. Re: Unable to re-install Flash Player 12
                    Hi UncaPathy,
                    The log files indicate a successful installation with no errors. Have you tried the troubleshooting steps posted at http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html, specifically the 'post-installation issues' section?
                    Maria
                    • 7. Re: Unable to re-install Flash Player 12
                      UncaPathy Level 1
                      Thank you very much! Of all the stupid little things, Shockwave had been disabled. Enabling it fixed the problem.
