1 Reply Latest reply on Dec 1, 2016 2:58 AM by Sumit_Garg
    How to generate Crash dump or Memory Dump of InDesign CS6 Release
    Nathan Durai
      I was wondering how I can generate a crash dump or memory dump of InDesign cs6 release version (windows). Especially my Indesign freezes at different point of time and I do not have any clue about why it just hangs to respond. I had to manually close the program by going to the Task Manager in Windows.
      I tried to copy the PMRuntime file from the MemoryTRacker folder of SDK to Indesign install folder. But I did not work. I dont see any memory dump files.
      Could you please tell me how can I generate a log or a crash dump file which will help me analyze why my Indesign freezes???
      I appreciate your help to the forum!!!!
        • 1. Re: How to generate Crash dump or Memory Dump of InDesign CS6 Release
          Sumit_Garg Adobe Employee
          Hi Nathan,
          This might be helpful for your request.
          For Windows, you can follow the following steps to generate the crash dump:
          1) Start Task Manager. To do this, use one of the following methods:
          • Right-click an empty area of the task bar, and then click Start Task Manager.
          • Press CTRL+SHIFT+ESC.
          2) Click the Processes tab.
          3) Right-click the name of the process that you want, and then click Create Dump File.
          Note: If you are prompted for an administrator password or confirmation, type your password or click Continue.
          A dump file for the process is created in the following folder:
          Drive: \Users\UserName\AppData\Local\Temp
          4) When you receive a message that states that the dump file was successfully created, click OK.
