5 Replies Latest reply on Jul 12, 2015 11:32 PM by c.pfaffenbichler
    Get stroke color of shape
    tomashanacek
      I need get stroke color of shape in photoshop, but I only find how to get fill color, any suggestion?
      function getFillColor() {
         var ref = new ActionReference();
         ref.putEnumerated( stringIDToTypeID( "contentLayer" ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ));
         var ref1= executeActionGet( ref );
         var list =  ref1.getList( charIDToTypeID( "Adjs" ) ) ;
         var solidColorLayer = list.getObjectValue(0);
         var color = solidColorLayer.getObjectValue(charIDToTypeID('Clr '));
         var fillcolor = new SolidColor();
         fillcolor.rgb.red = color.getDouble(charIDToTypeID('Rd  '));
         fillcolor.rgb.green = color.getDouble(charIDToTypeID('Grn '));
         fillcolor.rgb.blue = color.getDouble(charIDToTypeID('Bl  '));
         return fillcolor;
      Thank you
        • 1. Re: Get stroke color of shape
          c.pfaffenbichler Level 9
          Does this work in Photoshop CC? (edited)
          // 2014, use it at your own risk;
          #target photoshop
          if (app.documents.length > 0) {
          ref.putEnumerated( stringIDToTypeID("contentLayer"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var layerDesc = executeActionGet(ref);
          var strokeSt = layerDesc.getObjectValue(stringIDToTypeID("AGMStrokeStyleInfo"));
          var strokeStyleColor = strokeSt.getObjectValue(stringIDToTypeID("strokeStyleContent")).getObjectValue(stringIDToTypeID("color"));
          alert (strokeStyleColor.getDouble(stringIDToTypeID("red"))+"\n"+strokeStyleColor.getDouble(stringIDToTypeID("grain"))+"\n"+strokeStyleColor.getDouble(stringIDToTypeID("blue")));
          • 2. Re: Get stroke color of shape
            CptMcBacon
            Sorry for reviving this old post but...
            I've been trying to get a shape's stroke color for a whole week now, with no success. Tried the ScriptingListener, didn't find anything useful (or it did for SETTING the color, not for GETTING it). The missing link was that "AGMStrokeStyleInfo" ID... how did you find it, if I may ask?
            I THANK YOU DEEPLY, SIR!
            Really you can't imagine just how much of a godsend this is for me right now! Haha!
            Cheers,
            Tudor.
            PS: I've tried the code on CC 2015 and works.
            • 3. Re: Get stroke color of shape
              I pretty much use code based on code by Mike Hale (though it may include contributions from Paul or xbytor and/or others) to get the parameters of Application/Document/Layer etc. as needed.
              // based on code by michael l hale;
              // 2015, use it at your own risk;
              //#target photoshop
              #target "photoshop-70.032"
              // the layer;
              ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
              // the application;
              //ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
              // the document;
              //ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
              checkDesc2 (layerDesc);
              ////// based on code by michael l hale //////
              function checkDesc2 (theDesc) {
              var c = theDesc.count;
              var str = '';
              for(var i=0;i<c;i++){ //enumerate descriptor's keys
                str = str + 'Key '+i+' = '+typeIDToStringID(theDesc.getKey(i))+': '+theDesc.getType(theDesc.getKey(i))+'\n'+getValues (theDesc, i)+'\n';
              alert("desc\n\n"+str);
              ////// check //////
              function getValues (theDesc, theNumber) {
              switch (theDesc.getType(theDesc.getKey(theNumber))) {
              case DescValueType.BOOLEANTYPE:
              return theDesc.getBoolean(theDesc.getKey(theNumber));
              break;
              case DescValueType.CLASSTYPE:
              return theDesc.getClass(theDesc.getKey(theNumber));
              break;
              case DescValueType.DOUBLETYPE:
              return theDesc.getDouble(theDesc.getKey(theNumber));
              break;
              case DescValueType.ENUMERATEDTYPE:
              return (typeIDToStringID(theDesc.getEnumerationValue(theDesc.getKey(theNumber)))+"_"+typeIDToStringID(theDesc.getEnumerationType(theDesc.getKey(theNumber))));
              break;
              case DescValueType.INTEGERTYPE:
              return theDesc.getInteger(theDesc.getKey(theNumber));
              break;
              case DescValueType.LISTTYPE:
              return theDesc.getList(theDesc.getKey(theNumber));
              break;
              case DescValueType.OBJECTTYPE:
              return (theDesc.getObjectValue(theDesc.getKey(theNumber))+"_"+typeIDToStringID(theDesc.getObjectType(theDesc.getKey(theNumber))));
              break;
              case DescValueType.REFERENCETYPE:
              return theDesc.getReference(theDesc.getKey(theNumber));
              break;
              case DescValueType.STRINGTYPE:
              return theDesc.getString(theDesc.getKey(theNumber));
              break;
              case DescValueType.UNITDOUBLE:
              return (theDesc.getUnitDoubleValue(theDesc.getKey(theNumber))+"_"+typeIDToStringID(theDesc.getUnitDoubleType(theDesc.getKey(theNumber))));
              break;
              default:
              break;
              For a Shape Layer with a Stroke this would get me
              Key 0 = name: DescValueType.STRINGTYPE
              Color Fill 1
              Key 1 = color: DescValueType.ENUMERATEDTYPE
              none_color
              Key 2 = visible: DescValueType.BOOLEANTYPE
              true
              Key 3 = mode: DescValueType.ENUMERATEDTYPE
              normal_blendMode
              Key 4 = opacity: DescValueType.INTEGERTYPE
              255
              Key 5 = layerID: DescValueType.INTEGERTYPE
              2
              Key 6 = itemIndex: DescValueType.INTEGERTYPE
              2
              Key 7 = count: DescValueType.INTEGERTYPE
              2
              Key 8 = preserveTransparency: DescValueType.BOOLEANTYPE
              false
              Key 9 = layerFXVisible: DescValueType.BOOLEANTYPE
              false
              Key 10 = globalAngle: DescValueType.INTEGERTYPE
              120
              Key 11 = background: DescValueType.BOOLEANTYPE
              false
              Key 12 = layerSection: DescValueType.ENUMERATEDTYPE
              layerSectionContent_layerSectionType
              Key 13 = layerLocking: DescValueType.OBJECTTYPE
              [ActionDescriptor]_layerLocking
              Key 14 = group: DescValueType.BOOLEANTYPE
              false
              Key 15 = targetChannels: DescValueType.LISTTYPE
              [ActionList]
              Key 16 = visibleChannels: DescValueType.LISTTYPE
              [ActionList]
              Key 17 = channelRestrictions: DescValueType.LISTTYPE
              [ActionList]
              Key 18 = fillOpacity: DescValueType.INTEGERTYPE
              255
              Key 19 = hasUserMask: DescValueType.BOOLEANTYPE
              false
              Key 20 = hasVectorMask: DescValueType.BOOLEANTYPE
              true
              Key 21 = layerKind: DescValueType.INTEGERTYPE
              4
              Key 22 = hasFilterMask: DescValueType.BOOLEANTYPE
              false
              Key 23 = userMaskDensity: DescValueType.INTEGERTYPE
              255
              Key 24 = userMaskFeather: DescValueType.DOUBLETYPE
              0
              Key 25 = vectorMaskDensity: DescValueType.INTEGERTYPE
              255
              Key 26 = vectorMaskFeather: DescValueType.DOUBLETYPE
              0
              Key 27 = adjustment: DescValueType.LISTTYPE
              [ActionList]
              Key 28 = bounds: DescValueType.OBJECTTYPE
              [ActionDescriptor]_rectangle
              Key 29 = boundsNoEffects: DescValueType.OBJECTTYPE
              Key 30 = useAlignedRendering: DescValueType.BOOLEANTYPE
              false
              Key 31 = generatorSettings: DescValueType.OBJECTTYPE
              [ActionDescriptor]_generatorSettings
              Key 32 = AGMStrokeStyleInfo: DescValueType.OBJECTTYPE
              [ActionDescriptor]_strokeStyle
              Then
              checkDesc2 (layerDesc.getObjectValue(stringIDToTypeID("AGMStrokeStyleInfo")));
              can be used to check out the details for AGMStrokeStyleInfo.
              • 4. Re: Get stroke color of shape
                CptMcBacon Level 1
                That code is a goldmine! I can't believe I haven't stumbled upon this for a week of searching pretty much everywhere... EVERYWHERE!
                Bookmarked this page and backed-up that code for safe-keeping.
                Thanks again, c.pfaffenbichler (and Mike and Paul and xbytor and/or others), my script is going a lot better since I've learned about this.
                You guys are awesome!
                Cheers,
                Tudor.
                • 5. Re: Get stroke color of shape
                  You’re welcome.
                  Good luck with your Scripting endeavours!
