1 Reply Latest reply on Mar 14, 2014 9:44 AM by JJMack
    What can I do to get my slice action to work. "the command "select" is not currently available"
    unnecessary experiment
      "the command "select" is not currently available"...well it should be. I just used to two seconds ago.
      I routinely can not perform most actions because some function is not available. If I open an image, and record a simple "divide slice" action, the action can not repeat it, even on the same image. What am I missing? it seems so trivial, but I can't get past it.
      photoshop CS6 extended.
        • 1. Re: What can I do to get my slice action to work. "the command "select" is not currently available"
          Photoshop has may select commands please post the action and a screen capture of the error showing photoshop window containing the image window and photoshops paletts  with the action expanded in the action panel showing.
          Supply pertinent information for quicker answers
          The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
          • Adobe product and version number
          • Operating system and version number
          • The full text of any error message(s)
          • What you were doing when the problem occurred
          • Screenshots of the problem
          • Computer hardware, such as CPU; GPU; amount of RAM; etc.
