1 Reply Latest reply on Mar 14, 2014 9:28 AM by Peter Spier
    Files reverting back to random saves
    jpuckett
      I'm working in Indesign CC. I've worked on a layout over the last several days and have finished several pages on the same document. then suddenly after creating a low-res pdf in acrobat my documnet reverted back to the blank document that it was on March 11 at 10:58 am. I then went to my Time Machine's hourly backup and the documents in all of those backup folders have reverted to March 11 10:58 am as well. So the work is gone on my local disk as well as my backups. How could all the files revert to a past save both locally and on several backup folders all at the same time. and more importantly can it be recovered?
        • 1. Re: Files reverting back to random saves
          Are you sure you saved to the same folder?
          If they're gone, they're probably gone for good. I make a habit of periodically saving a new version with a new name, usually each time I'm about to make a major change, or when I start a new editing session, so I have both an easy way to abandon a set of changes and a ready backup path in case of disaster.
