1. Re: Unable to initialize Photoshop because the preferences file has been removed
Noel Carboni Mar 14, 2014 9:20 AM (in response to lola.marceau)lola.marceau wrote:
I tried to reset photoshop with keyboard shortcuts preferences,
Seems odd that such a problem would crop up on its own. That kind of sounds like a registry or permissions problem. What other things did you do with the computer between the time it worked and it didn't?
And if you're willing to uninstall / reinstall to try to recover operation, it might be prudent to try the Adobe cleaner tool to really be sure you've uninstalled everything...
http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation-problems.html
-Noel
2. Re: Unable to initialize Photoshop because the preferences file has been removed
Curt Y Mar 14, 2014 9:26 AM (in response to lola.marceau)What OS? What keyborad shortcuts are you uising? And what happens when you use them?
3. Re: Unable to initialize Photoshop because the preferences file has been removed
lola.marceau Mar 14, 2014 9:32 AM (in response to Noel Carboni)I used internet, and stuff like that ... Didn't delete anything ...
4. Re: Unable to initialize Photoshop because the preferences file has been removed
lola.marceau Mar 14, 2014 9:34 AM (in response to Curt Y)Mac OSX 10.9.2 I used shift and alt (i think). Can't remember but I found the shortcut in an adobe help video ... Nothing happens when I use them
5. Re: Unable to initialize Photoshop because the preferences file has been removed
JJMack Mar 14, 2014 9:36 AM (in response to lola.marceau)On a windows system you can rename or delete your userid Photoshop Preference folder. Then start Photoshop and it will create a new folder with Adobe default preferences for your user id.
6. Re: Unable to initialize Photoshop because the preferences file has been removed
Curt Y Mar 14, 2014 9:44 AM (in response to lola.marceau)Resetting preferences is a tricky operation and reqires perfect timing. Start PS and immediately hold down option/alt/shift keys. If fast enough you will get a reset window.
7. Re: Unable to initialize Photoshop because the preferences file has been removed
lola.marceau Mar 14, 2014 10:01 AM (in response to Curt Y)I did it a lot of times and it didn't work
8. Re: Unable to initialize Photoshop because the preferences file has been removed
the_wine_snob Mar 14, 2014 10:05 AM (in response to lola.marceau)I looked over the thread, but did not see one thing, that might be important: what version of Photoshop are you using? [I might have missed that, and if so, apologize.]
Normally, if the Ps Preferences File is not present, Ps just creates a new one - essentially what should happen during the Preferences Reset.
9. Re: Unable to initialize Photoshop because the preferences file has been removed
lola.marceau Mar 14, 2014 10:07 AM (in response to the_wine_snob)Oh yea right, I forgot to mention it, sorry. It's photoshop CS6
10. Re: Unable to initialize Photoshop because the preferences file has been removed
Curt Y Mar 14, 2014 10:10 AM (in response to lola.marceau)Does Bridge CS6 work? If so open and click on Updates and update PS if an option.
11. Re: Unable to initialize Photoshop because the preferences file has been removed
lola.marceau Mar 15, 2014 7:07 AM (in response to Curt Y)I did as you adviced, still doesn't work ...
12. Re: Unable to initialize Photoshop because the preferences file has been removed
Noel Carboni Mar 15, 2014 4:15 PM (in response to lola.marceau)Did you go through the full uninstall and reinstall as advised?
If that didn't work, consider reinstalling the operating system on your computer.
-Noel
13. Re: Unable to initialize Photoshop because the preferences file has been removed
lola.marceau Mar 18, 2014 4:24 AM (in response to Noel Carboni)How do I reinstall the operating system of my computer ?
14. Re: Unable to initialize Photoshop because the preferences file has been removed
lola.marceau Mar 18, 2014 4:46 AM (in response to lola.marceau)I only needed to rename my Adobe photoshop CS6 settings file. It now works perfectly !
