2 Replies Latest reply on Jun 22, 2006 9:17 AM by >zero
    Programmatic movement problem
      Completely baffled by this:
      I have an mc (of a map) which I want to move around to specific coordinates in x and y axes in response to button clicks.
      It does this very well using the following code:
      //in the firstframe of the main movie
      //loads the map swf
      var startX = 0
      var startY = 0
      var speed = 10
      function moveMe(targ){
      And then this code is on every button in the main move:
      //target coordinates for the map to move to
      var endX = 290
      var endY = -30
      This works perfectly, making the map slide from position to position 'easing out' every time - except that for some reason, each time you click on a button - the map moves to its new coordinates slighly faster, until it appears to jump directly to the next position.
      I can't see how it's doing it - I think the 'speed' variable is always the same, so perhaps the setInterval is decreasing to cause this effect?
      I'd welcome any ideas on this!
