7 Replies Latest reply on Mar 15, 2014 7:35 AM by Unique
    Go to cell and alert contents
    Unique
      Hi, I want to find and alert contens of a cell in a table. Matrix method.
      I found a stupid idea to find it.
      Well i could get the Number of Column and row. but i cant able to select the contents of a cell (3,1).
      (I'm trying to get alert of a content which is having header "Mate" and reference number 71247.
      TitleSongMateFilmTwo
      50%25050027052071247
      11%125FeckeriNJAMANRAH71248
      13222IQUEWATERWAFER71246
      UNIQUEFARESTFARTABVALUE71249
      var every = app.activeDocument.pages.everyItem(0).textFrames.everyItem().tables.everyItem().cells.eve ryItem().getElements();
      var T = [];
      var m = [];
      for(i=0; i<every.length; i++) {
      if(every[i].contents =="Mate") {
      app.findGrepPreferences.findWhat = "71247";
                app.activeDocument.findGrep(true);
                var fnd = app.activeDocument.findGrep();
            for(y=0; y<fnd.length; y++) {
                          if(fnd[y].length>0 &&
                  T.push(fnd[y].parent.name));
                  m.push(every[i].name);
                          var f= (m).join("\r").replace(":", ".");
                          var e = (T).join("\r").replace(":", ".");
                           var u = e-f;
                          var n = [];
                          n.push(u);
      alert(n);
      Many thanks for the support.
        • 1. Re: Go to cell and alert contents
          Kai Rübsamen Level 4
          first I realize that with InDesign CC everyItem() is verry slow, even I have only two tables on one page?!
          Why has your last column no header "Mate"? If I understand the question correct, I would do it in this way:
          var curDoc = app.activeDocument;
          var everyHeaderRow = curDoc.pages.everyItem(0).textFrames.everyItem().tables.everyItem().rows[0].getElements();
          for( var i = 0; i<everyHeaderRow.length; i++ ) {
            var curHR = everyHeaderRow[i];
            var allHC = curHR.cells;
          for ( var j = 0; j < allHC.length; j++ ) {
            if ( allHC[j].contents == "Mate" ) {
              var curCol = allHC[j].columns[0];
                for ( var c = 0; c < curCol.cells.length; c++ ) {
                  var curCell = curCol.cells[c];
                    if ( curCell.contents == "71247" ) {
                      curCell.select();
                      var cellName = curCell.name;
                      var co = Number(curCell.name.split(":")[0])+1;
                      var ro = Number(curCell.name.split(":")[1])+1;
                      alert("Found\r" + "Column: " + co + "\r" + "Row: " + ro + "\r" + "Contents: " + curCell.contents);
          • 2. Re: Go to cell and alert contents
            Unique Level 1
            Sorry for the confusion Kai,
            I do want to find the contents which is in column "Mate" and row 71247.
            just a x-y co-ordinates which meet at the column Mate and Row which has cell contents "71247"
            thanks for the reply Kai.
            • 3. Re: Go to cell and alert contents
              @Unique – every cell has a parentRow property. So if you found a cell, look at its parentRow.cells[-1] to get the last cell of that parent row and read out its contents.
              Uwe
              • 4. Re: Go to cell and alert contents
                @Unique – there is a fantastic documentation of the DOM (Document Object Model) where you can look up all properties and methods for the objects. I recommend downloading the chm-files, because they are  easily searchable:
                Jongware
                InDesign JavaScript Reference Guide
                http://www.jongware.com/idjshelp.html
                Uwe
                • 5. Re: Go to cell and alert contents
                  If you want to find 500 try this:
                      var curCol = allHC[j].columns[0].index;
                      var curTableCells = curHR.parent.cells;
                        for ( var c = 0; c < curTableCells.length; c++ ) {
                          var curCell = curTableCells[c];
                              var curRow = curCell.parentRow.index;
                                      var x = curCol + ":" + curRow;
                                      var curName = curTableCells.item(x);
                              alert(curName.contents);
                  • 6. Re: Go to cell and alert contents
                    Unique Level 1
                    Hi Laubender & 5.Kai Rübsamen,
                    Many apologise for my request.
                    I m not a programmer like you people.
                    I tried in this way before i got answer from you people.
                    // Would be so cool:
                    var T = [];
                    var m = [];
                    var sn = [];
                    if(every[i].contents =="71247") {
                    app.findGrepPreferences.findWhat = "Null";
                                        r = [];
                                        r.push(e.split('.')[0]);
                                        //alert (r);
                    g = [];
                                                  g.push(f.split('.')[0]);
                              //alert(g);
                                        var u = f-e;
                                        var n = [];
                                        n.push(u);
                                        Found = [];
                                        Found.push(g-r);
                                        app.select((every[i-Found]));
                                        sn.push(every[i-Found].contents);
                    alert (sn);
                    Sorry for troubling you guys. I want to learn the proper method to create script like you people have created. I m really happy the way you have presented. and im ashamed of what i have done. but i want to simply my method.
                    Laubender. As far i known, whenever anyone post in the forum you and jump_over [jareak] would always answer for any kind of stupid questions.
                    thanks Laubender and let me know how can i learn from you.
                    my id. is. raji27_siva@yahoo.co.in.
                    many thanks.
                    • 7. Re: Go to cell and alert contents
                      Unique Level 1
                      i got what i need from you,
                      Kai Rübsamen,
                      my is is raji27_siva@yahoo.co.in.
                      many many thanks or this kai.... please keep in touch with me...
