Hi Flygirl555
IMHO, buttons and click boxes are essentially the same thing.
Both are designed to carry out a defined action when clicked upon
by the user. Personally, here is where I "draw the lines of
distinction as to when to use one over the other".
If my goal is to simply pause the movie until the user clicks
and I want a definite indication this is happening, I'll use
a simple text button containing the verbiage "Click here when ready
to proceed..." or something like that. But if my movie has areas
where the user should click (as in a screen capture of a dialog
with an "OK" button) I need a click box, because it will be
invisible and make the static image of a button "clickable".
Sorry, but I'm at a loss as to explain why buttons and click
boxes appear differently on the Timeline, with respect to the
"Active | Inactive" segments. I'm just making an assumption here,
but I suspect this may be used in a case where you don't really
want the button to disappear and just have the slide continue
playing to another segment. In this case, after clicking, the
button is still visible but won't do anything if the user clicks.
To make your button visible, but not active for the first
five seconds, consider inserting an image of the button in a
disabled state. Then at the five second point, insert the live
button. The end result should be that your user sees a button that
appears to be disabled (and since it's just an image and doesn't
have a click action assigned, it is truly disabled) then the button
springs to life as that five second mark is reached.
To prevent the items from "greying out", time the click box
so it pauses sooner. It's probably pausing the slide late enough
that the fade out on objects has occurred.
Hopefully this helps... Rick 🙂
