Do some research on setting up an SMTP Mail Server. You need
one running somewhere on your box or on your network. Your box
would be 127.0.0.1 your network would be 10.x.x.xxx as given to you
by your network gurus. You may run into firewall issues also. Port
is typically 25. The SMTP server (the one that comes with IIS does)
often has settings to prohibit relays from external sources (CF
would be considered external). When I first got into this, I didn't
understand the concepts and tried to get my own IIS supplied SMTP
server up and running. It never worked (even efter permitting
relays), most likely due to the Corporate Network and security
properties and Firewalls etc. When I finally figured all this out ,
I was able to ask the Network Guru's, "Do we have an SMTP server I
can access?". Turns out they had something built into or bolted
onto MS Outlook Exchange Server, they gave me the IP, and presto,
everything worked as advertised.
