1 Reply Latest reply on Mar 16, 2014 1:27 AM by Trevorׅ
    ui Help
    JonnyDL Level 1
      I'm trying to build a small simple ui, but I am having trouble with some of the things I want to do with it. I'm trying to use location, size and spacing to arrange the items better in the dialog window. I also can't seem to figure out how to get a button to work an onClick action.
      (I've done it before), but my guess is the way I built the dialog, makes it more difficult to get the buttons working.
      Here is what I have built below.
      for example: I would like to add space between the panel and the radio buttons, and move the whole panel up and left.
      The other issue is I have a simple onclick test to check if the button works. I can't seem to get the onclic to work. Is it because I have it built in a group, and Im not acessing it correctly?
      var bleedGuideDialog = new Window ("dialog", "Bleed Guides");
      var topGroup = bleedGuideDialog.add ("group");
      topGroup.orientation = "row"
      topGroup. alignment="left";
      var radioPanel = topGroup.add("panel", undefined, "Guide Options");
          radioPanel.size = [140,75];
          var show = radioPanel.add("radiobutton",  undefined, "Show Guides", );
          show.value = true;
          show. alignment="left";
          var hide = radioPanel.add("radiobutton",  undefined, "Hide Guides");
          hide.value = false;
          hide. alignment="left";
      var directions = topGroup .add("statictext", undefined, "Export will create a PDF with the guides to show what items would be cut off thatare in the bleed area.",{multiline:true});
      //p1 = w.add ('edittext {preferredSize: [200, 100], properties: {multiline: true}}');
      directions.size = [130, 100]
      var middleGroup = bleedGuideDialog.add ("group");
      middleGroup.orientation = "row"
          var prgBar = middleGroup.add("progressbar", {x:20, y:12, width:200, height:12}, 0, 100);
          var exportbtn = middleGroup.add("button",  undefined, "Export");
      var cancelit = bleedGuideDialog.add("button",  undefined, "Cancel");
      cancelit.alignment = "right";
      bleedGuideDialog.show ( );
      exportbtn.onClick =function ()
      alert("click");
      Any help/Guidence would be appreciated.
